Old 01-24-2012, 06:18 PM   #271
c4lvin
c4lvin is an unknown quantity at this point
Originally Posted by nativG20 View Post
I hope this is the right place to post this.
I have a pair of 18x8 +42 inch Racing Harts C2s that i would like to get new outter lips for. the lips are 40 hole lip. Effectivly i want a 9.5 or 10 wide wheel.
Here is a Picture to try and illustrate what size lips i have
Im pretty sure the lips i have now are only 1 inch lips given you are supposed to measure the width of a rim from bead to bead, so the curved edge seen in the pic above shouldnt be measured (please correct me if im wrong)
Again my Wheels are 18x8 +42 as of current
Here are my Calculations (provided i do have a 1 inch lip) If i add a 3 inch lip to my existing face and barrels i will be adding (-24) offset to the wheel which would make my wheels 18x10 +18.
(please correct me if i am wrong)
and 10 wide may be too wide so i was thinking just adding a Lip that is just 1.5 wider or a total of 2.5 wide which would give me 18x9.5 +25.
It'd be 18x9.5 +22, not 25.
c4lvin is offline   Reply With Quote
Old 01-25-2012, 11:41 AM   #272
nativG20
nativG20's Avatar
nativG20 is an unknown quantity at this point
I forgot to divide the difference of the witdh, thanks
in an attempt to make this less confusing:
18x8+42 wheel + outter lip that is 2 inches wider than existing lip = 18x10 +18.
18x8+42 wheel + outter lip that is 1.5 inches wider than existing lip = 18x9.5 +22
^^^ if my calculations are correct
Thanks for all the help
WTF IS JUICE?? I WANT THAT PURPLE DRANK!!!
nativG20 is offline   Reply With Quote
Old 01-25-2012, 11:51 AM   #273
c4lvin
18x8+42 wheel + lip that is 2 inches wider than existing lip = 18x10 +18.
18x8+42 wheel + lip that is 1.5 inches wider than existing lip = 18x9.5 +22
Easy way to remember is every
.5" of bigger lip = 6.35mm of lower offset
.5 of bigger barrel = 6.35mm of higher offset
.5" smaller lip = 6.35mm of higher offset
.5" smaller barrel = 6.35mm of lower offset
3 x 6.35 = 19.05 (just say 19 or 20 to make it easy).
stock +42 - 20 = 22
and then the 10s would be 18x10 +16
offset is calculated by the centerline (half of total width of wheel including wheel beads (1" larger than listed width, so a 10" wheel is actually 11" from outside bead to outside bead)) and the position of the mounting pad of the center. You can't just simply subtract or add offset to the outer lip alone. You need to take into account the total width of the wheel to determine centerline.
Old 01-25-2012, 11:26 PM   #274
mxracerjason
mxracerjason's Avatar
mxracerjason has a spectacular aura aboutmxracerjason has a spectacular aura aboutmxracerjason has a spectacular aura aboutmxracerjason has a spectacular aura aboutmxracerjason has a spectacular aura aboutmxracerjason has a spectacular aura aboutmxracerjason has a spectacular aura about
Originally Posted by 95KA-Turbo View Post
I thought I'd add in here that VR Wheels makes replacement lips for VS-XX and Work Equips now too! I just emailed them to ask if they can make custom bolt pattern lips, hopefully they can so I can just build random pairs of wheels hahaha.
Only 195 a lip for 17X4s!!!!
Aftermarket replacement lip : VR Wheels WebStore, Presented By VR Motoring
This is fuckin awsome. I was searching with no luck for wider outer lips for my 17" VS-XX fronts. I'm gona get some 2.5 or 3". I think the fronts are 1.75 or 2" and I have enough room for 1" more and my tires will still tuck
mxracerjason is offline   Reply With Quote
Old 01-31-2012, 10:20 AM   #275
c4lvin
Faces are here. Assembling them tonight when I get home.
Old 01-31-2012, 10:44 AM   #276
moco
moco is an unknown quantity at this point
Hey nativ you still got your g20 its moesg20
moco is offline   Reply With Quote
Old 01-31-2012, 06:31 PM   #277
GabeS14
GabeS14's Avatar
GabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfection
Anyone know what other finish is similar to diamond finish, or a decent priced place that does diamond finish?
E92 M3 19" wheels for sale///JWT Cams and Springs +30whp for sale... cheap.
GabeS14 is offline   Reply With Quote
Old 01-31-2012, 09:11 PM   #278
c4lvin
Got 1 rear and 1 front done.
Front and rear:
Old 01-31-2012, 10:20 PM   #279
95KA-Turbo
95KA-Turbo's Avatar
95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of
Doesn't it suck to put them together? Hahaha, they look great though.
Instagram - SJKnoop
95KA-Turbo is offline   Reply With Quote
Old 01-31-2012, 11:00 PM   #280
c4lvin
Haha, I find it fun. I missed rebuilding wheels; haven't for a while until now.
Thanks man!
Old 02-01-2012, 08:23 AM   #281
turbo2nr
turbo2nr's Avatar
turbo2nr will become famous soon enoughturbo2nr will become famous soon enoughturbo2nr will become famous soon enoughturbo2nr will become famous soon enoughturbo2nr will become famous soon enough
Send a message via AIM to turbo2nr
Front and rear:
looks awesome man , good color choice, i cant wait to get my lips and put mine together.. did you powder coat or just paint?
s14 kouki ka-t
turbo2nr is offline   Reply With Quote
Old 02-01-2012, 08:32 AM   #282
c4lvin
Thanks man.
It's powdercoat called "Galvanized Blasted Aluminum" which tries to mimic sandblasted aluminum and has a textured finish.
Old 02-02-2012, 12:18 PM   #283
nativG20
nativG20's Avatar
Yep, still pushing the P11 around... i need my C2s finished already, im rolling on s13 SEs haha
Thanks man.
looks really nice, glad to see you didnt go with crazy lime green and purple. The texture of the powder coat you picked gives the wheels a nice depth to them, adds another deminsion to the wheel. classy
Old 02-02-2012, 12:28 PM   #284
IIIXziuR
IIIXziuR's Avatar
Trader Rating: (22)
IIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfection
Feedback Score: 22 reviews
Those XX looking amazing in that finish.
How hard is it to dismantle and then assemble those, C4lvin?
IIIXziuR is offline   Reply With Quote
Old 02-02-2012, 12:34 PM   #285
c4lvin
Thanks guys!
I've built numerous sets of multipiece wheels before so it was easy for me. Taking them apart took about an hour and a half. Assembly takes longer as you have to torque each bolt to spec and make sure everything is seated properly. I spent about 1.5-2hours on each assembling them so far.
Old 02-03-2012, 12:04 AM   #286
GabeS14
GabeS14's Avatar
anyone? plsss
Old 02-03-2012, 12:37 AM   #287
essforteen
essforteen's Avatar
Trader Rating: (50)
essforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant future
Feedback Score: 50 reviews
anyone? plsss
Diamond cut on the face?
essforteen is offline   Reply With Quote
Old 02-03-2012, 07:27 PM   #288
GabeS14
GabeS14's Avatar
yes on the face
Old 02-13-2012, 11:00 AM   #289
nativG20
nativG20's Avatar
^^my C2s are diamond cut faces too, i would imagine it would be costly to have them refinished in Diamond cut, as there is prob a lot of machining involved
Old 02-17-2012, 11:12 PM   #290
dazed
Trader Rating: (37)
dazed is a jewel in the roughdazed is a jewel in the roughdazed is a jewel in the roughdazed is a jewel in the roughdazed is a jewel in the roughdazed is a jewel in the roughdazed is a jewel in the roughdazed is a jewel in the rough
Feedback Score: 37 reviews
Thoughts on re-building older Work wheels?
Specifically Work VS-Mesh. I know it's a pretty rare wheel.
dazed is offline   Reply With Quote
Old 02-18-2012, 12:56 AM   #291
qwerth
qwerth's Avatar
Trader Rating: (25)
Feedback Score: 25 reviews
who has relipped britz O3?
Old 02-18-2012, 11:32 AM   #292
g_mac530
g_mac530's Avatar
g_mac530 is an unknown quantity at this point
Send a message via AIM to g_mac530
I think wheelflip has.
Originally Posted by RoXiE.S14 View Post
Because Jesus himself made the nissan 240, true story
g_mac530 is offline   Reply With Quote
Old 02-24-2012, 04:55 PM   #293
atutt
atutt's Avatar
atutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond repute
I forgot I made this thread.
Can anyone verify my math? lol
I tried figuring out what my offsets would be.
As I've mentioned a million times. I want my Veilsides widened.
All 4 are 17x9 +17mm.
I'll be adding 4'' to the rear, on the lip side since they're 3 piece rims.
And I'll be adding 2'' to the front.
Would this make them:
17x13 -40mm rear?
17x11 -8.5mm front?
Or did I f up my math?
atutt is offline   Reply With Quote
Old 02-24-2012, 04:56 PM   #294
qwerth
qwerth's Avatar
Trader Rating: (25)
if your taking off the old lip you should probably minus that from the 9 inches Then add the 4 and 2 inches
DarkMagician
Instagram
Old 02-24-2012, 05:26 PM   #295
atutt
atutt's Avatar
I'm not taking off the old lip.... I'm widening, not narrowing. I'm not taking anything away from the 9''.
I'm adding to the outer lip it as stated.
Old 02-24-2012, 05:27 PM   #296
qwerth
qwerth's Avatar
Trader Rating: (25)
ohhh just kidding
lol
DarkMagician
Instagram
Old 02-24-2012, 07:43 PM   #297
blueshark123
blueshark123's Avatar
Trader Rating: (55)
Feedback Score: 55 reviews
17x13 -40mm rear?
17x11 -8.5mm front?
Yea your welding is better then your math lol. jk but you messed up on the rear set
For every inch added to the lip size the offset will drop 12.7 mm on the offset so
-12.7x4=-50.8 lets say -51+17=17x13 -34 for rear
-12.7x 2= -25.4 lets say -25.5+17=17x11 -8.5 for front
Old 02-24-2012, 08:27 PM   #298
atutt
atutt's Avatar
I was 6mm off on the rear then. lol
I converted everything to mm, so that's probably how I messed up lol
Still pretty tasty wheel sizes. To me at least.
Old 02-24-2012, 09:29 PM   #299
blueshark123
Trader Rating: (55)
Yea that will still be great sizes
Old 02-27-2012, 09:53 PM   #300
CamryOnBronze
CamryOnBronze's Avatar
Trader Rating: (131)
CamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud of
Feedback Score: 131 reviews
Send a message via AIM to CamryOnBronze
For sure- Yuta seems to really know his stuff. Very helpful guy to me so far!
CamryOnBronze.com
CamryOnBronze is offline   Reply With Quote
