Old 04-02-2013, 10:44 PM   #331
Z_Spool
Z_Spool's Avatar
Z_Spool has a spectacular aura aboutZ_Spool has a spectacular aura aboutZ_Spool has a spectacular aura aboutZ_Spool has a spectacular aura aboutZ_Spool has a spectacular aura aboutZ_Spool has a spectacular aura about
Black light you say? Hmmmmm.....
Z_Spool is offline   Reply With Quote
Old 04-02-2013, 10:53 PM   #332
tapdeznutz
tapdeznutz's Avatar
Trader Rating: (50)
tapdeznutz is an unknown quantity at this point
Feedback Score: 50 reviews
holy shit silviaks2nr, that looks great. i did the tsx projectors for pop up s13 and they are no where near that bright. is it just the projectors thats you used that gives the brightest? please enlighten me.
FS: DSS 1pc Steel Non ABS, 6bolt axles
WTB: Boost Gauge, Hatch Roof Wing
tapdeznutz is offline   Reply With Quote
Old 04-02-2013, 11:42 PM   #333
S14kouki_10
S14kouki_10's Avatar
S14kouki_10 is an unknown quantity at this point
Anyone need some bmw projectors (e90), got some laying around.
S14kouki_10 is offline   Reply With Quote
Old 04-03-2013, 08:33 AM   #334
hellion240sx
hellion240sx will become famous soon enoughhellion240sx will become famous soon enoughhellion240sx will become famous soon enoughhellion240sx will become famous soon enough
Originally Posted by silviaks2nr View Post
PM me, kinda depends on the specific setup and parts.
That setup. How much? Pm me. That's inane. Cept I have glass not plastic. And no black paint.
R.I.P. KAIN. YOU'LL ALWAYS BE BY MY SIDE!
240 addict miata addict
hellion240sx is offline   Reply With Quote
Old 04-03-2013, 09:58 AM   #335
silviaks2nr
silviaks2nr's Avatar
That cutoff photo is slightly overexposed to emphasize the cutoff color and sharpness. Having said that not all projectors are created equal. The rx330 projectors are just "okay" in factory form, but I modify them with a clear projector lens and a custom curved cutoff shield so that the distance lighting and width is immensely improved. More info on that if you go on hidplanet forums. As far as low beam projectors go they are pretty much the best. TSX projectors concentrate too much of the light to the foreground and not enough for down the road intensity so they are not a great projector to use on a low car like a 240 which needs intense distance lighting instead of foreground lighting.
'98 240sx 5spd
kouki 2jz t56 swap build
Old 04-03-2013, 10:00 AM   #336
silviaks2nr
I posted a how to a while back for people who want a little help doing their own retrofit as well. http://zilvia.net/f/s-chassis/505768...-retrofit.html This retrofit is without the clear headlight lenses, you can see the difference in the cutoff pattern and intensity.
'98 240sx 5spd
Old 04-03-2013, 10:25 AM   #337
tapdeznutz
tapdeznutz's Avatar
Trader Rating: (50)
Again, great info. so what projector do you know of is or has great "down the road" lighting. I know exactly what you mean, i get great lighting in front of me but thought the TSX projectors would be an upgrade to the 350z projectors I originally started with. Personally i think the 350z projectors are a little better then the TSX. I will have to post pictures up of both sets when i get a chance for everyone to see.
Old 04-03-2013, 11:16 AM   #338
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Feedback Score: 48 reviews
silviaks2nr - question, why plastic covers?
do they offer some kind of advantage over glass ones.
I can only see them getting yellow/foggy over time.
Old 04-03-2013, 11:33 AM   #339
tapdeznutz
tapdeznutz's Avatar
Trader Rating: (50)
Maybe he meant lexan not plastic?
Old 04-03-2013, 12:11 PM   #340
silviaks2nr
lexan is a type of plastic, a polycarbonate. The lenses from the vertex lights are probably made of polyethelene if I had to guess. The reason for using them rather than the oem glass ones is because the oem glass ones are the cause for a significant amount of glare and loss of intensity. They also really hurt the cutoff sharpness and colorband. If you leave your car outside all the time they will start to haze after a few years. You can always just wetsand and polish them at that point though.
'98 240sx 5spd
Old 04-03-2013, 12:27 PM   #341
tapdeznutz
tapdeznutz's Avatar
Trader Rating: (50)
what thickness are you using. i just bought a sheet of 1/4" from home depot for another project that i now want to use. thanks again.
Old 04-03-2013, 01:10 PM   #342
silviaks2nr
I didn't make the lenses, just took them off the vertex lights and put them on the oem housings. I have made clear kouki lenses before, before the vertex lights existed, but this is way easier.
'98 240sx 5spd
Old 04-03-2013, 01:15 PM   #343
trentjsd
trentjsd's Avatar
trentjsd is an unknown quantity at this point
Would this be the same for s13 buying the clear lens?
trentjsd is offline   Reply With Quote
Old 04-03-2013, 01:56 PM   #344
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
I see gotcha, thanks
personally I think I would keep the glass
nice work btw
Old 04-03-2013, 02:09 PM   #345
tapdeznutz
tapdeznutz's Avatar
Trader Rating: (50)
nice work btw
this is the second time i have heard the suggestion that replacing the glass with "lexan" will give a brighter beam. i will be replacing the lens.
Old 04-03-2013, 02:49 PM   #346
Edwin562
Edwin562's Avatar
a legit projector retrofit on flip up is difficult due to space and still keeping the flip up function..
here is a link i been told is a legit retrofit on a flip up..
NorCal MR2 Pegasus Headlight Conversion
Old 04-03-2013, 02:55 PM   #347
silviaks2nr
The pegasus headlights are a joke. Sure they have a correct beam pattern but the performance leaves much to be desired, that width is dreadful and the light is not distributed where it needs to be at all. They are no where near to having the performance of oem hid bixenon projectors. A 4x6 hid retrofit is not that bad... I recommend oem rx350 bixenon projectors if that's the route you take for s13.
'98 240sx 5spd
Old 04-03-2013, 03:07 PM   #348
Edwin562
Edwin562's Avatar
You have any pics or write ups on proper projector retrofit on 4x6?
Old 04-03-2013, 05:01 PM   #349
Matej
Trader Rating: (39)
Feedback Score: 39 reviews
Supposedly these are quite good.
http://www.jwspeaker.com/products/he...ectangular.pdf
Too bad they are also quite ugly.
http://www.youtube.com/watch?v=uiQdDGivFY0?rel=0&showinfo=0&autohide=1&am p;iv_load_policy=3&vq=hd1080
Old 04-04-2013, 09:52 PM   #350
Mister.E
Mister.E's Avatar
Trader Rating: (53)
Feedback Score: 53 reviews
i would fucking shoot myself before paying $550/ea for those ugly ass headlights.
that has to be one of the worst designs i've ever seen.
Old 04-04-2013, 10:20 PM   #351
Te37
Te37's Avatar
Te37 has made poor choicesTe37 has made poor choicesTe37 has made poor choicesTe37 has made poor choicesTe37 has made poor choicesTe37 has made poor choicesTe37 has made poor choicesTe37 has made poor choices
just finished...
Te37 is offline   Reply With Quote
Old 04-04-2013, 10:24 PM   #352
Juantwo3
Juantwo3's Avatar
Juantwo3 is an unknown quantity at this point
when the beat dropped i thought some inital d shit was gona go down
Juantwo3 is offline   Reply With Quote
Old 04-05-2013, 01:20 AM   #353
240sxDavid
240sxDavid is an unknown quantity at this point
Has anyone of you had the gladman projectors? Pictures seem cool but I would miss the lens look on my s13 so I'm going the Cibie headlights route at the end of may
Originally Posted by 4nmscle View Post
How much power does your shit box make there champ?
240sxDavid is offline   Reply With Quote
Old 04-05-2013, 04:22 AM   #354
mikeyee
mikeyee is an unknown quantity at this point
hey! thread is alive again!
just finished these up for a buddy
edit
some s-chassis related content
daniel posted some cool shots of his car with the led tails
mikeyee is offline   Reply With Quote
Old 04-05-2013, 10:36 AM   #355
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Originally Posted by alwaysideways14 View Post
That's the hair pomade I use! lol /coolstorybro
silviaks2nr - You deleted your how-to thread??
Old 04-05-2013, 11:56 AM   #356
silviaks2nr
Showing up fine for me? http://zilvia.net/f/s-chassis/505768...-retrofit.html
To whoever asked sorry I do not have a write up for a sealed beam retrofit.
'98 240sx 5spd
Old 04-05-2013, 12:14 PM   #357
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
apologies, I thought I had subscribed to it and couldn't find it
Got a set of lights with retrofitted projectors but needed the retrofitsource.com address to order new ballasts and harness
the ones I got with the lights were pretty janky
Old 04-05-2013, 12:19 PM   #358
silviaks2nr
What projectors do you have?
If you don't want to modify the back housing which is sometimes necessary you can get the 4300k D2H bulbs and 35watt ballasts from TRS. It's best to use oem bulbs and ballasts if you can though. I really like their wiring harnesses and supply one with almost all of my retrofits so you should pick one up too
'98 240sx 5spd
Old 04-05-2013, 12:45 PM   #359
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Waiting for friend to get back to me
I ordered their 35watt ballasts, H1 harness and 6000k bulbs to try out.
Oem ballasts and bulbs - you mean like S2000, TSX, etc projectors and phillips bulbs?
I may do that down the line, I got an extra set of usdms and another set of jdm headlights to play with.
Also Mike from clearcorners is a good friend, he may yet swindle me into buying his overpriced shit.
edit: BMW e46 single Xenon projectors with D2s bulbs is what's in the headlamps according to my friend.
Old 04-05-2013, 01:04 PM   #360
silviaks2nr
6000k bulbs are going to be considerably dimmer than oem 4300k by at least 1000 lumens per side, just a head's up. e46 singles are decent but I'd go with oem philips 85122 bulbs though, I'm sure Mike would recommend the same. You can pick up a new pair for about $75 and they can be used with the TRS ballasts. OEM ballasts can be mitsubishi, matsushita, denso, hella, etc. If you were feeling really fancy you could get osram CBI (cool blue intense) for about $195/pair. They are 5400k but just as bright as regular philips/osram 4300k.
'98 240sx 5spd
