Old 03-24-2015, 12:50 AM   #39691
deolio
deolio's Avatar
fd car styling, when executed so poorly, is timeless
Old 03-24-2015, 10:43 AM   #39692
DenkiMan!
DenkiMan!'s Avatar
DenkiMan! is an unknown quantity at this point
neon (underglow) is somehow making a comeback
Originally Posted by PSI240SX View Post
Although the 97 Maxima was aesthetical perfection, I thought the factory body lines could use some expert "tweaking" so I ran it into a couple of things at low speed.
Looking for another pair of 17x9 Veilside Andrew Racing V's
DenkiMan! is offline   Reply With Quote
Old 03-24-2015, 11:26 AM   #39693
Mister.E
Mister.E's Avatar
Trader Rating: (53)
Feedback Score: 53 reviews
Truth, everything about that car is ugly.
Old 03-24-2015, 01:21 PM   #39694
Corbic
Corbic's Avatar
Thank God.
LED lighting is sooo cheap today.
Old 03-24-2015, 02:13 PM   #39695
Driftin Tre
Driftin Tre is an unknown quantity at this point
Driftin Tre is offline   Reply With Quote
Old 03-24-2015, 06:48 PM   #39696
sonomadrifter
sonomadrifter's Avatar
sonomadrifter is a jewel in the roughsonomadrifter is a jewel in the roughsonomadrifter is a jewel in the roughsonomadrifter is a jewel in the roughsonomadrifter is a jewel in the roughsonomadrifter is a jewel in the roughsonomadrifter is a jewel in the rough
sonomadrifter is offline   Reply With Quote
Old 03-24-2015, 08:01 PM   #39697
justin240s14
justin240s14 is an unknown quantity at this point
Anyone got any info on the wiring for the r33 headlights fitted in a s14 ?
Plz help got the fender cut right and got the custom mounts made and got them in...
Just need the wiring for it got it where low beam is on by its self but when high beam on low goes out or other way where low and high is on ? Need help
justin240s14 is offline   Reply With Quote
Old 03-25-2015, 09:46 PM   #39698
gobackwards
gobackwards's Avatar
gobackwards is an unknown quantity at this point
gobackwards is offline   Reply With Quote
Old 03-26-2015, 08:06 AM   #39699
Irresistible
Irresistible's Avatar
Irresistible is an unknown quantity at this point
My low beams turn off when my high beams get turned on. However I think that has to do with my HIDs and I hate it.
GLEAM//★☆Street Dancer☆★
IG: streetdncr // tumblr: steve-strtdncr
Irresistible is offline   Reply With Quote
Old 03-26-2015, 08:36 AM   #39700
justin240s14
Angry
Yeah its aggravating the hell out of me cuz I can't figure it out lol
Old 03-26-2015, 08:46 AM   #39701
Corbic
Corbic's Avatar
Uh, isn't that how it's suppose to be?
In the vintage Porsche world, you have the two bulbs, running lights (low) and driving (high). US market cars you're switch gives you off, low, high. There is then the "euro mod" in which you do some wiring so your switch is off, low and low/high.
Old 03-26-2015, 09:44 AM   #39702
Nissansota240
Nissansota240's Avatar
Nissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really nice
I think when I turn on my high beams both bulbs are on, it was the fog lights that turn off when the high beams come on.
DLG - DIRTYLOVE
Nissansota240 is offline   Reply With Quote
Old 03-26-2015, 09:47 AM   #39703
justin240s14
Well on my stock s14 headlights the lows would be on while in low, and when the high beam was on the high and low beam would be on while highs was on...now since ive put the R33 headlights in its just low with low and high with high....
Im starting to think it has something to do with H1 bulbs since they only have one prong and the ground.....and when the stock headlight bulbs had three....
Old 03-26-2015, 10:13 AM   #39704
STEEZxIT
STEEZxIT's Avatar
STEEZxIT is on the path to ruinSTEEZxIT is on the path to ruin
mine have always been either low, or high. you don't get both.
but then i've always had HID's since 2009 and i don't remember before that.
@dangerdamian
STEEZxIT is offline   Reply With Quote
Old 03-26-2015, 10:37 AM   #39705
dbeiler
dbeiler's Avatar
dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler
If your HID lights turn off when you hit the high beams, it's because the circuit hasn't been wired completely.
The stock 240sx low beam bulb has 3 terminals. Terminal 1 is high beam power. Terminal 2 is ground. Terminal 3 is low beam power. When your lighting stalk is set to low beam, the light bulb receives 12v power on Terminal 3. When you switch to high beam, the lighting stalk CUTS power to Terminal 3 and sends 12v power to Terminal 1 instead, along with 12v power to the high beam bulb. On high beam setting, both high and low beams should be illuminated.
This is why HIDs will cut off when you hit the high beam. Because HIDs have only 1 power wire, most people will connect that wire to the low beam side only (Terminal 3)
To function correctly, the HIDs power wire must be connected to both high and low beam power wires (Terminal 1 and 3)
It is important to use a diode when connecting to the high beam side. Otherwise, the 12v power would backfeed and the high beams would be illuminated when the lighting switch is set to low beam. High beams and HIDs would both always been on regardless of switch position.
Hopefully I explained that in an understandable way. Long story short; to get your HIDs to stay on when you switch to high beam, add a wire jumper from the HIDs power wire to your high beam side (Terminal 1) using a diode in the circuit. It's actually a lot more simple than it sounds.
dbeiler is offline   Reply With Quote
Old 03-26-2015, 10:41 AM   #39706
Corbic
Corbic's Avatar
^ excellent write up.
Old 03-26-2015, 10:43 AM   #39707
justin240s14
Hopefully I explained that in an understandable way. Long story short; to get your HIDs to stay on when you switch to high beam, connect the HIDs power wire to your high beam side (Terminal 1) using a diode in the circuit. It's actually a lot more simple than it sounds.
Good info......but im not using hids im just using H1s that goes into the light socket.....
Old 03-26-2015, 10:53 AM   #39708
dbeiler
dbeiler's Avatar
This applies to your situation as well. Any bulb with only 2 terminals must have a wire jumper and diode to the third terminal as stated above.
Old 03-26-2015, 10:57 AM   #39709
justin240s14
Oh ok, well thank you very much for the help and info..
Old 03-26-2015, 11:41 AM   #39710
STEEZxIT
STEEZxIT's Avatar
wow, totally unexpected and very awesome info.
thanks for putting that out there dbeiler!
@dangerdamian
Old 03-26-2015, 11:52 AM   #39711
justin240s14
So to get the low beam and high beams to work at the same time on high beam...I would have to .....
Hook up a diode to terminal #1 thats feeding the high beam and the other side of the diode would go to terminal #3 for low beam ?
Old 03-26-2015, 01:15 PM   #39712
ka-titties
ka-titties is an unknown quantity at this point
Originally Posted by simmode1 View Post
^^^Are you talking about the colormatched ITR lip on the bottom?
nah, i was mentioning the wheel arch section of the front bumper. it looks like it was swept forward more so that it would match the lip instead of the lip ending up a little bit short.
ka-titties is offline   Reply With Quote
Old 03-26-2015, 01:26 PM   #39713
derek.owens.980
derek.owens.980's Avatar
derek.owens.980 is an unknown quantity at this point
The car was done in 99 and hasn't seen the light of day until recently
derek.owens.980 is offline   Reply With Quote
Old 03-26-2015, 01:29 PM   #39714
justin240s14
So to get the low beam and high beams to work at the same time on high beam...I would have to .....Hook up a diode to terminal #1 thats feeding the high beam and the other side of the diode would go to terminal #3 for low beam ?******
Old 03-26-2015, 01:42 PM   #39715
derek.owens.980
Considering what i paid for it and the fact that it only has 38,000 miles on it i can deal with the way it looks for now it will get changed soon enough
Old 03-26-2015, 02:34 PM   #39716
Irresistible
Zenki's Unite
You can also wire in a relay, there's a write up of that online somewhere. I've been meaning to do it but for some reason I haven't.
Unless a diode is a relay then never mind. Wiring terminology is foreign to me
Old 03-26-2015, 04:02 PM   #39717
hellaslows13
hellaslows13's Avatar
Trader Rating: (28)
hellaslows13 will become famous soon enoughhellaslows13 will become famous soon enoughhellaslows13 will become famous soon enoughhellaslows13 will become famous soon enough
Feedback Score: 28 reviews
happy 326
wavybert / zenki / build thread
hellaslows13 is offline   Reply With Quote
Old 03-26-2015, 04:19 PM   #39718
Corbic
Corbic's Avatar
^ silver one.... Dem wheelz
Old 03-26-2015, 05:10 PM   #39719
justin240s14
Wonder if you can use this or if it has to be a diode. ...
Old 03-26-2015, 09:57 PM   #39720
YOSHIKOUKI
YOSHIKOUKI's Avatar
YOSHIKOUKI is an unknown quantity at this point
Send a message via Yahoo to YOSHIKOUKI
Originally Posted by hellaslows13 View Post
happy 326
Wat front is that on the Burgundy one
YOSHIKOUKI is offline   Reply With Quote
