Old 06-23-2011, 07:34 PM   #1
frsh4
frsh4's Avatar
frsh4 is an unknown quantity at this point
Wheel Fitment Question Thread
This thread is to post your question about wheel fitment and is used to HELP EACH OTHER. This is not to talk shit about someone because they want to ask a question about fitment.
Rules:
1. SEARCH! If all fails come here. We are here to help.
2. No shit talking if your not gonna help someone out DONT POST!
3. Pics are not mandatory but will obviously help.
4. The main reason for this thread is to not clutter up the OG fitment thread and stop all the chit chatter.
5. An answer like yes or no obviously wont help so by posting a response your helping to make the question work. If it is seems like an impossible setup a simple no is ok. Make you response useful.
EX: Q: Will a 18x10 +18 fit on an s13?
A: Yes with some camber and stretched tire. Suggested setup 225/40 about 2.3* of camber maybe less with small pull.
Pic:
SIMPLE! JUST SHARE YOUR KNOWLEDGE!
ANY SUGGESTIONS TO THE THREAD PLEASE PM ME. ITS MY FIRST BIG THREAD. HEHE.
frsh4 is offline   Reply With Quote
Old 06-23-2011, 07:59 PM   #2
Wake
Wake's Avatar
So i posted my car in the fitment whore thread and it seemed to confuse a lot of people so here is my contribution.
My pics have no spacer but you have to remember that when its on the ground its not going to look the same as weight will make the wheels camber in.
17x8 +33, no spacers, stock body, on springs and struts (eibachs and GR-2s if you must know)
i was told it will look like this when its on the ground. except this is 17x8 +35. So you do the math.
Im also planning on running a 215/40 which is what this cars has also
Now for all you s14 guys who may be looking at similar sizes (assuming you can do math) here is similar fitment. Goes to show how much different there is between 13's and 14's.
Originally Posted by 95KA-Turbo View Post
I thought it was common knowledge that S14s are ~25mm wider on each side then S13s...and kouki S14s are another ~10mm wider then zenkis from the factory up front.
Just a FYI, on my first set of wheels I did the test fit on lowering springs.
My 17X8 +5 looked like this with a 215/40:
Once I put the coils on and added some camber I actually had to run a 15mm spacer, haha.
Thats with about -2.5* camber.
S.P.P.S. Member #00
**CoUpe LOve** Member #00
Old 07-07-2011, 11:22 PM   #3
UGLYLOWLIFE
UGLYLOWLIFE is not welcome here anymoreUGLYLOWLIFE is not welcome here anymoreUGLYLOWLIFE is not welcome here anymoreUGLYLOWLIFE is not welcome here anymoreUGLYLOWLIFE is not welcome here anymoreUGLYLOWLIFE is not welcome here anymoreUGLYLOWLIFE is not welcome here anymoreUGLYLOWLIFE is not welcome here anymoreUGLYLOWLIFE is not welcome here anymoreUGLYLOWLIFE is not welcome here anymoreUGLYLOWLIFE is not welcome here anymore
Im trying to fit 18x11.5 +7 on my s14 stock pulled rears. what tire size and how much camber should i run to make it look flush without too much poke?
UGLYLOWLIFE is offline   Reply With Quote
Old 07-08-2011, 12:22 AM   #4
Drama
Drama is an unknown quantity at this point
Here's 17x11.5 +6 225/40 in the rears.
Drama is offline   Reply With Quote
Old 07-07-2011, 11:51 PM   #5
frsh4
frsh4's Avatar
Originally Posted by son. View Post
Front: 18x10.5 -7 Nankang NSII 225/35/18
Rear: 18x12 -5 Continential Pro Contact 265/35/18
This is the first car i can think of that has a lot of width and a good camber. Maybe he can chime in and help. But im think your gonna end of with a lot of poke depending on your aliment settings. I say go with a 255/35 for stock fender and super sweet pull.
http://thatistupid.tumblr.com/
Old 07-08-2011, 12:01 AM   #6
frsh4
frsh4's Avatar
Also found this it is the the same width and hes running 225/40 federals, so expect a lot of poke and camber without over fenders.
Forgot about this thread. Lets use it!
Old 07-08-2011, 12:23 AM   #7
kalypso123
(ノಠ益ಠ)ノ彡
this thread is a good idea.
Old 07-08-2011, 12:56 AM   #8
EhrikETFG
EhrikETFG's Avatar
EhrikETFG is an unknown quantity at this point
zenki looks kinda cool all stock metal
EhrikETFG is offline   Reply With Quote
Old 07-08-2011, 07:24 AM   #9
alexanderig
alexanderig is an unknown quantity at this point
I need tire and camber suggestions. Im going to be running a 17x9.75 +25 all around. From calculations I'll need a spacer in the front so I have 10mm spacers for te front. Now this car will be drifted so what camber should I be running up front and out back? Currently I'm at about -2 in the front and -.5 out back. And I'm planning on running a 225/45 sounds good? Lmk
alexanderig is offline   Reply With Quote
Old 07-08-2011, 11:32 AM   #10
dudermagee
dudermagee's Avatar
dudermagee is an unknown quantity at this point
how about 18x10 & 18x11 +9 all around on s14 kouki
thinking 235/35/18 and 255/35/18 for tires
how much camber do you think I'll have to run on stock metal with a good roll\pull?
Originally Posted by DC Dan MAX USA View Post
Don't wuss out on me.
dudermagee is offline   Reply With Quote
Old 07-14-2011, 06:39 PM   #11
95KA-Turbo
95KA-Turbo's Avatar
95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of
Fronts will fit no problem with the lip flattened. Rears will need ~-3 camber and a slight pull.
This is ~-2.5 camber with a 255/40/17 BFGs on a 17X11 +12.
Front shot:
The fronts in those photos are 17X10 +7 with 245/40 S-Drives and ~-2.7 camber.
Instagram - SJKnoop
95KA-Turbo is offline   Reply With Quote
Old 07-15-2011, 10:37 AM   #12
endlessboost
endlessboost is an unknown quantity at this point
Front shot:
Hey knoop, is there a reason you run such a wide front tire other than it being grippier? I have 17x10 +0 front and am thinking of running a 225/45 dz101. Couldn't you step down a size in the rear too so the pull wouldn't be to far out? I'm not critisizing just asking cause your shit looks dope as it is.
endlessboost is offline   Reply With Quote
Old 07-16-2011, 11:41 AM   #13
nathanong87
nathanong87's Avatar
run a 235/40-17 star spec. trust me on this.
natelife.tumblr.com
Old 07-16-2011, 03:59 PM   #14
95KA-Turbo
95KA-Turbo's Avatar
I ran that size because I wanted as much tire as I could fit. It was awesome drifting with 245s up front too...I wasn't runny a crazy grippy tire though. I am on 235/40s NT05s up front now which I love. They're retarded grippy compared to any other tire I've used. I've heard great things about Star Specs as well.
Either way, I'd recommend a 235/40 over a 225/45 just because it has a shorter sidewall, the tires overall height is smaller so you'll have more clearance.
Just the person I wanted to answer, your car is my inspiration
thanks dude
Thank you very much, and no problem.
Originally Posted by zooopreme View Post
Heard you can only fit 10" +18 wheels up front on the S13 with Apexi N1 coilovers along with Megans.
With that said, how much of a spacer will I need to run in order for them joints to fit stock bodied S13? And what kind of fender work will I need to make them fit?
Or should I go with a 9 or 9.5" in front. I really don't want to run staggered at all. But if a 10" +18 is not worth the effort, then what would be a better stagger 9 or 9.5"?
go with 9j in front
or add a lot of camber then you can run more spacer to clear the coilover
For sure run a 9 up front. A 9 +12 with a 215 fits just about perfect on a stock body S13 up front. You could go with a 9.5 up front, but with the limited room S13s have you'll have a much easier time with fitting the 9J.
I loved the way my S14 felt when I was running 17X9s all around...so you don't have to stagger if you don't want to. A 9/10 stagger is fine, but I'd be more inclined to do a 9/9.5 stagger if you decided to run a staggered set up.
Instagram - SJKnoop
Old 07-15-2011, 10:17 PM   #15
dudermagee
dudermagee's Avatar
[img]http://farm4.static.flickr.com/3460/3949742774_b0b4ff9db7_o.jpg[/ig]
Front shot:
[img]http://farm3.static.flickr.com/2589/3948969057_33273ba72a_o.jpg[/ig]
thanks dude
Old 09-04-2011, 09:06 PM   #16
ChucEO
ChucEO's Avatar
ChucEO is an unknown quantity at this point
hey, im new to zilvia. i had a question regarding a problem im having atm.
i've just lowered my s13, but on the front in the wheel well my tires are rubbing directly on the wheel well wall, also rubbing against the rubber stopper that the harness enters.
im running on 18 x 9 +15 w/ 225/40/zr18
i need a solution to this problem ASAP, what can i do to modify the wheel well possibly?
thanks.
ChucEO is offline   Reply With Quote
Old 09-04-2011, 09:11 PM   #17
sidewayz240
sidewayz240's Avatar
sidewayz240 is just really nicesidewayz240 is just really nicesidewayz240 is just really nicesidewayz240 is just really nicesidewayz240 is just really nicesidewayz240 is just really nicesidewayz240 is just really nicesidewayz240 is just really nicesidewayz240 is just really nicesidewayz240 is just really nice
Hammer.
msg
-Trevor
sidewayz240 is offline   Reply With Quote
Old 12-06-2011, 02:35 PM   #18
Kwolfe
Kwolfe is an unknown quantity at this point
What do you guys think of 17x9 +35 F and 17x10 +20 R on an s13 hatch, right now it's slammed on 16's so I'm sure I'll have to raise it up some. I'm looking for a pretty flush stance with maybe -2 or -3 camber. Will I need spacers? Will it fit in the first place? And what about tires? Right now my JIC's are as stiff as possible and I don't rub the 16's.
Kwolfe is offline   Reply With Quote
Old 12-06-2011, 03:00 PM   #19
95KA-Turbo
95KA-Turbo's Avatar
You'll need a 15mm spacer up front (you could run a 20mm with my tire suggestion), no spacer in the rear.
I'd recommend a 215/40 up front and a 235/40 out back.
If you only wanted to run a 15mm spacer over the 20mm up front go with a 215/45 but it will limit how low you can be because S13s are pretty limited for space and a 215/45 is just tall enough to keep you from really slamming it.
You may need a slight pull out back, but if you're going to run ~-3 camber you should be able to fit it.
Instagram - SJKnoop
Old 03-17-2012, 01:48 PM   #20
silviaNC
silviaNC's Avatar
silviaNC is an unknown quantity at this point
how many inches should I drop it
I dont want to have it slammed or rubbing everything under my fenders.
was thinking just tein 1.8, 1.5 springs will work. or should I take Eibach 2.2, 2.1springs. they are 18" wheels 205/35/18. thinking about getting some 225/40/18
still getting car together.
[IMG][/IMG]
[IMG][/IMG]
silviaNC is offline   Reply With Quote
Old 03-17-2012, 02:03 PM   #21
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
So I got a pair of 225/45/17 Dunlop Z1 star specs for a awesome price that I couldn't pass up. I always wanted a good sticky tire up front but they're a little taller than I had expected. So my question is what's a good sticky tire thats close to 225/45 but not as tall.
Here's some pics for reference.
Setup is as follows:
Stock S14 fenders
17x10 +5
10mm spacers
Stance GR+ pro coils
Originally Posted by Om1kron View Post
45 series tires are going to be tall, what kind of dumb ass question is that? why 45 series period?
225/45-17 is actually fairly spot on to the stock diameter for OEM S14 wheels.
What are you running for shocks? Stock shocks are not gonna keep up with the Eibach springs for sure. For as much money you'll spend, might as well get an entry level coilover and not slam it.
CLICK HERE!!!
Old 05-24-2012, 05:31 AM   #22
Sizzlechest
Sizzlechest's Avatar
Sizzlechest is an unknown quantity at this point
Anybody know these fitment specs?
Sizzlechest is offline   Reply With Quote
Old 05-24-2012, 10:29 PM   #23
klutchx22
klutchx22 is an unknown quantity at this point
new to wheel fitment and 240sx, i dont have to much knowledge on this stuff so your help is appreciated! anyways, i was just wondering if
1) i will need spacers, and if so roughly what size
2) if i will need to roll/pull fenders
3)will i need to buy camber kit
i have a stock s14 zenki,it is my dd. i am putting on kw v3 coilovers. rest of suspension is stock thus far.
i will be running rota p45rs, 18x9.5 +30 all around.
front tires will be 225/40/18
rears will be 225/45/18
everything is in peices right now, nothing is put on the car, im waiting for my wheels to get powdercoated to start slapping this stuff on...
i would really like to know, ahead of time, if i will maybe need spacers or start looking into fender rolling.
thanks
klutchx22 is offline   Reply With Quote
Old 08-08-2012, 06:30 PM   #24
ZenkiAlec
ZenkiAlec is an unknown quantity at this point
just wondering, does wheel width affect wheel fitment?
ZenkiAlec is offline   Reply With Quote
Old 08-22-2012, 08:19 AM   #25
aznoy
aznoy is an unknown quantity at this point
Talking
Front shot:
whats the brand of these rims? that would look great with my green kouki.
aznoy is offline   Reply With Quote
Old 10-14-2012, 06:41 AM   #26
MarkS13
MarkS13 is an unknown quantity at this point
18x9 +6 and 18x10 +11 what size tires would you get?
MarkS13 is offline   Reply With Quote
Old 02-18-2013, 07:03 PM   #27
ocn
ocn's Avatar
ocn is on a distinguished road
i cant remember the offset when i bought these for my r32 gtr, but i brought them back to the states with me i think they are 265/35 18x10+18 or +19. will they fix my coupe? i have 5 lug conversion hubs coming in the mail.
here they are on my (well not any more) gtr
ocn is offline   Reply With Quote
Old 03-05-2014, 10:39 PM   #28
Bladimir
Bladimir's Avatar
Bladimir is an unknown quantity at this point
Front shot:
Bro what wheels are those?!
Bladimir is offline   Reply With Quote
Old 03-06-2014, 05:37 AM   #29
fliprayzin240sx
Originally Posted by Rb26kouki View Post
can anyone guess whats the offset on these te37 on this s15
specs are
18x9.5 Front
18x10.5 Rear
this is my setup
square all around
18x9.5 +12
Tires 235-40-18
future tires
275 35 18 fronts
315 30 18 rears
but want the staggred set
but undecided for +22 or +15
Don't use S15s as reference for S14 fitments since S15s have narrower body lines than S14s. S15 fitments are more like S13s.
As far as fitting that much rubber on 9.5js. I think those are going to be over kill, specially those 315s are 11j-12j width territory.
Originally Posted by drgreen View Post
I tried to search and I can't find anyone with a +47 off set wheel. I bought a set of 17x8F +47..17x9R +47. Work Rezax Ver 1
Rubber is 225f 255r
Going onto a 180 with stock fenders.
Haven't had the chance to put them on because doing my 5 lug conv. in a few months when the snow melts....
So I imagine +47 will need spacers so I don't hit coilovers (Cusco Zero2) but then I will be in the fender...
My question is, do you guys think I can just get away with spacers and roll+pull?
Pic request for any 180 that has a +47 work wheel on it...
You wont, those wheels are too high of an offset. You'd need ATLEAST 25mm spacers to make them look decent without having to do much with the fenders (roll is always a good idea).
Originally Posted by 93_ProjectS13 View Post
Buying a set of 18x10 +18 for all cornors of my zenki.
Now I've read up and the back should be ok with a 8mm spacer. But the fronts would need a 10mm spacer. Also gonna run 225/40/18 on all 4.
So is the 10mm good? I've read that a 8mm barley clears, why ima grab a 10.
Flip I know you know this!!
All depends on the coilovers/suspension. 18x10 +18 were perfect for my S14 fronts on Topline Aragostas, didn't need any spacers. PM me if you got any other question...
BBS RS, custom re barrel 17x8 +50 to 17x11 +12 all around. And it's your lucky day since he's actually contemplating on selling them for $2300 + sh.
https://www.facebook.com/stephen.knoop.71?fref=ts
CLICK HERE!!!
Old 02-22-2017, 06:40 AM   #30
kong_vaj05
kong_vaj05 is an unknown quantity at this point
Hey
WHAT TIRES size to get for my s14
kong_vaj05 is offline   Reply With Quote
