#512 | |
![]() Join Date: Oct 2006
Trader Rating: (163)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 163 reviews
Sikky |
#513 |
![]() Join Date: Feb 2011
how do you feel about the jbl ms8? i planned on running a pdx 5 channel and rainbow germanium line components with either a carputer or ddin nav unit, and was wondering if you had any experience with the unit.
#514 |
The JBL MS8 is a joke compared to the ARC Audio PS8. But at that point the PDX 5 would be far below the quality of the PS8. What are you trying to accomplish as far as sound quality?
#515 |
well i listened to a set of fostex th-900 headphones with a schiit audio dac/amp and it ruined me, i would like to get the best sq possible without going overboard. from what i understand the rainbows i have are some of the best sounding 6.5in components. Im just wondering what to do as far as a dsp/amp. preferably something that best buy sells, i would much prefer to use my discount, and im not looking to spend thousands. basically under $1000 for an amp and dsp, with the best sound possible using the speakers i have already.
these are the speakers i have http://www.rainbowcaraudio.com/slc265-25ng.html |
#516 | |
#520 | ||
Just make some out of ABS and glue them from the backside... definitely not worth paying me to do it. |
#524 |
![]() Join Date: Nov 2010
my sr was idling earlier yesterday in my garage because i was looking for vacuum leaks. well while idling a puff of smoke came out of my engine bay on the exhaust side. i immediately turned the car off and looked at where the smoke might have come from and i couldnt find it. well i went to start the motor again to see if it would happen again. while i was cranking the motor over it locked up on me. why do you think it locked up? i need help so i can get my car on the street
#525 |
Just sent my z32 calipers out for powder coating. I saw you post on the powder coat color thread and wanted to know if you had a write up on zinc plating the hardware, or maybe just a materials list of what was used. Definitely wanna try this.
#526 |
![]() Join Date: Dec 2012
Broadfield (or anyone who has an answer really), there's a guy selling a strut/spring combo suspension and he says that everything is good "except one of the sleeves are cut". I'm new to the whole suspension side of town, so I have to ask.. what is a sleeve? What does he mean by "it's cut"? How can I fix it?
Thanks. |
#527 |
![]() Join Date: May 2008
![]() Feedback Score: 10 reviews
Just installed my 4 channel MB Quart Fx4.100 amp, and when I go to test the rear speakers which are connected to ch. 3 & 4, I immediately get cracking and static. This happens even when my head unit is off too.
Any suggestions? |
#528 |
![]() Join Date: May 2009
Broad. are you familiar with the Pioneer shallow 10 inch subs? The reason I ask is because I went to check out the West Coast Customs shop located on Camp Pendleton. I meet the head install guy and he stated the pioneer subs sound better than the JL TW13. I say bullshit but I have no friends pushing the sub. Any personal pref. between the two?
#529 | ||||
I have to find it first.
Plating Kits Electroplating Kits Aluminum Anodizing Kits Powder Coating Systems Metal Polishing And Buffing Supplies - Caswell Inc Quote:
#530 |
Hey Toby. Just installed the 3303V alarm system into the 2tone. My hatch has the 5901 alarm. I attempted to try to pair the remote using the CAR2 feature but it was not able to do it successfully. The remotes look identical, but are they compatible with each other?
#531 |
![]() Join Date: Dec 2010
Trader Rating: (42)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 42 reviews
Looking to do a full system in my car. But it's not a 240 so nothing too cheap but don't need to go all out. I want one sub, two amps of course, and four speakers I need front component 6.5 and the rears are 6x9s. With my last system I had a problem not being loud enough and staying clear in higher volume settings; I don't want that this time around. It's all going to be ran by the stock double din touch screen in efforts to keep all the features. So also I think I'd need a amp for the sub with a bass knob to adjust bass better?
What can you sell me? Sorry for the super question. Car is a 2013 corolla. I'd like a sub that doesn't require a giant box. Looking to spend no more then 1500. The less the better so I can still have cash to get it installed, wires, fuses and so on |
#532 | |
#533 | |
#535 |
![]() Join Date: Dec 2008
Trader Rating: (71)
![]() Feedback Score: 71 reviews
i have the viper 5901 wired into my s13. you actually helped me with the wirings and everything, appreciate that. sometimes it wont let me start the car using the key but remote start works? any ideas?
#536 |
ignition switch or alarm brain possibly. the remote starter is placed in between the ignition switch and the starter relay. i would double check your violet/green connections on the heavy gauge high current wires coming out of the alarm brain.
#537 |
whats your opinion on these speakers:
New Hifonics ZRX65C 6 5" 800W Component Speaker Set 6 1 2" 800 Watt 806576218487 | eBay is there a better option out there for the same price?
#538 | ||
You can easily diagnose this issue with a DMM as long as you can get the issue to occur while testing. If it is just a coincidence that it hasn't acted up yet during remote start, then it could be an issue with absolutely anything in the ignition chain. I guess I should of asked this first: when you say it doesn't allow you to start the car, that's a very loose description. Does it not crank at all, does it crank and not fire, does it make any noise at all when you turn the key to crank? Quote:
But in all honesty, those are VERY bad speakers. Those would not really be an upgrade over your common OEM speaker. If you have no money then you gotta do what you gotta do I guess. |
#540 |
Yeah, I have been installing them for 20 years... pretty much ever since they were invented. So needless to say I have installed a mind boggling amount in those 20 years.
broadfield, toby |
