#5941 | |
sand blasting can leave pits if done wrong
street dancer. GLEAM |
#5942 |
![]() Join Date: Aug 2010
stupid question i know, i blame it on the previous owner.
If my egr tube is plugged how will this effect my car? 95 ka24de with aftermarket header.
#5943 | |
I've been running without one for a year now, as well as many other people in the country, and my engine is fine. If you have a california model you might as well leave it blocked and not remove it completely
#5945 |
![]() Join Date: Aug 2009
![]() Feedback Score: 27 reviews
my brake lights aren't turning off! they killed my battery and then after i jumped it i realized my brake lights were on and they don't turn off when i turn the car off either. help!
#5946 | |
![]() Join Date: Apr 2009
![]() Feedback Score: 11 reviews
u can tape a penny up there for a temp. nissan carries them in stock there lik 99 cents |
#5947 |
I made this account for the sole purpose of answering this question, which has been a 4 day headache for me, my dad and another mechanic.
Heres the deal: we swapped two ka24 engines (my old one was due to blow any second) and we wired everything correctly, electrical, vacuum, belts, etc. Now the engine won't start, it cranks but doesn't fire (it's backfired about 4 times but thats it) we tested all the basic stuff...checked for fuel, spark and compression. It's all good, but the damn car Won't start! Does anyone know what we could be missing? It's got 3 mechanics stumped...the only thing which MIGHT be wrong is the vacuum lines (small chance they're connected wrong,but we doubt that) any help is greatly appreciated. Also if anyone has a vacuum line diagram, not the horrible Nissan one, but one with real life pics would help to double check, thanks. |
#5948 | |
Clean it, just dunk it in a shit ton of cleaner and then try and get everything out with a small wire brush and compressed air If you're back firing then its no good. Hell, i have a working one minus the EGR tube and the squid thing, pay me shipping and i'll send it to you for free The reason i said if you have a california model is because it has so much more emissions related stuff compared to non-ca models. For instance, there is an EGR temp solenoid that you have to splice in some resistance bullshit or you will throw CELs... not worth the hassle for such minute gain. Either fix or leave alone
#5949 | |
For na there should be a vacuum line to the fpr to the port coming off the back outside nipple and your main line for the brake booster and a t in the small line to the egr ( if running it ) But to me it sound like you have your dizzy set 180degrees off Which will cause it to backfire and u would still have spark just not in the right timing |
#5950 |
Its actually a single cam, and we've double checked the timing over and over, it's right on the mark...I'll check out the lines to see what you mean, I just need an image of one with the vacuum lines correctly connected so I can compare it to my setup.
#5951 | |
#5952 |
![]() Join Date: Nov 2005
Anybody? Help me out Zilvians!
http://www.nissanroadracing.com/ |
#5953 |
Hello everybody,
I'm looking to do a 5 lug conversion on my S13. My question is, does anybody makes rotors so i can use my stock S13 calipers and pads until I figure out which route I want to go. I have seen picture but couldn't find any info about them. Thanks |
#5954 |
s14 se rotors.
Im still waiting on someone to answer my question please!
#5955 | |
![]() Join Date: Jul 2008
#5956 | |
lmk if you need mine, it's just sitting here and i don't wanna throw it to waste
#5957 |
I forgot to mention. IDK if it makes a difference but my car is non-abs so I would need non-abs 5 lug S14 rotors?
#5958 | |
if you don't have abs, dont buy abs brakes
#5959 | |
already tried that. the centers used to be gold i think but now its silver like the side of the mesh and the face is polish. when i tried teh aircraft stuff it didnt do nothin. |
#5960 | |
i used klean strip paste on work eurolines to remove the paint/clearcoat... it took about 3 applications to completely remove everything, and #000 steel wool or a scrubbing pad for dishes having someone media blast it would be better than sand
#5961 |
![]() Join Date: Sep 2007
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 8 reviews
I got a quick question,
For some reason my car feels like it pulls harder on partial throttle rather than at WOT. I have NO idea what it could be. I thought it was my MAFS so I upgraded to a Z32 and AFC Neo, Plugs, CTS, Ignitor, o2, etc. but same story. Any ideas? Mods; S14 SR S15 Turbo (8 PSI via ProFec Spec II) Z32 MAF AFC Neo ( Proper MAF setup and thats it) Usual bolt ons. Thanks guys, Tan
#5969 |
this may be too much to ask but.........
I can't find a bolt that will fit the seat belt nut on the S13 Buddy Club Side Mount seat rails. Would anyone have the original paperwork or happen to know which bolt I need for this? Thanks.
'89 Sil80, SR20DET, GT2871r .64 |
#5970 |
LOL a red flag that covers the post
Question Anybody know the torque spec for the idler sprocket bolt? I feel like that is something that i shouldn't just tighten I checked the fsm 3 times already and can't find anything in Lower Timing Chain Installation/surrounding areas
