#631 |
http://www.ebay.com/itm/Nissan-240SX...10995996318%26
This one doesn't look near as good but thats a 52mm. Looks like theres a good bit of room left in that one |
#634 | |
![]() Join Date: Oct 2006
Trader Rating: (163)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 163 reviews
It would not be a shitty fiberglass piece like the one from Ebay. I would retrofit/mod your OEM piece. So it would bolt back in just like it came out of the door card. The fit and finish would obviously be OEM grade. |
#635 |
![]() Join Date: Dec 2009
![]() Feedback Score: 21 reviews
What is your take on XRP vs. Earl's fittings? From what I remember, you carry XRP fittings.
GLEAM//★☆Street Dancer☆★ IG: streetdncr // tumblr: steve-strtdncr |
#636 | |
I had all Earls product on my SR20... very good stuff of course. The finish seems to be a little nicer on the XRP product. The weave in the braided nylon hose is also tighter than the Earls. Not sure if that really affects performance or not... like bend radius. But it looks nicer. Also, on the braided nylon hose, the XRP comes standard with the inner stainless braid. Whereas you have to step up to the Earls Pro-Lite Ultra to get that. The XRP product is generally cheaper in price across the board. XRP has some unique product that others don't and most of their product is NHRA approved. |
#637 | |
#639 |
![]() Join Date: Apr 2006
Trader Rating: (55)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 55 reviews
I was looking into getting a dash cam in case I ever got into a accident to cover my ass, since people around here don't know how to drive. I was just curious if you knew any decent cheap ones by any chance before I started doing more research.
#642 |
The premium DEI actuators I sell are the best I have run across. They also have the most mounting options and are the slimmest. There's really not much to write-up.
#645 |
can you let me know what size rim and offset you are running for rear wheels...wanna get an idea for when i get your overfenders as to what size wheel i should be looking to get
#646 | |
I finally had a box come in that's big enough for those overs... so I'll be shipping them out soon! |
#647 | |
ahh sweet man thanks...cant wait |
#650 |
![]() Join Date: Jun 2011
hey broadfield, i managed to get an entire s13 manual seatbelt conversion (A-pillar, B-pillar, seatbelts, and headliner) for free from a canadian 240, but my only problem is that the driver side A-pillar had a gauge pod screwed in to it (which I hate). how would you recommend sealing the holes? I can get pics of them if you like to show the size, but id say small enough to barely get a pinky in.
BustedS13: anything you can hide on your person is free. junkyard law. |
#651 | |
Anyway, how I would do it... which is the right way, is to fill the holes with 3M 34240 or Norton 5 minute Speed Grip. Prep the openings on the inside edge of the holes and backside of the panel with 80 grit or harsher. Use masking tape to tape over the front of the holes. Then use the glue on the backside to fill the holes and let it spill over around the holes to give it more area to bond. Let it dry then pull the tape off. You can now sand the front side if the glue sticks up at all past the front of the panel. If it sags for some reason you can use some body filler and sand it to level it off. Once you are happy with that use some aerosol 39813 SEM Chip Guard to texture the entire panel. Then paint to match your OEM color. |
#652 |
![]() Join Date: May 2010
![]() Feedback Score: 17 reviews
Any thoughts on a honda s2000? Ever worked on one of them before?
http://upsidedownsideway.tumblr.com/ |
#654 |
![]() Join Date: Jan 2004
Trader Rating: (82)
![]() Feedback Score: 82 reviews
I'm looking for good speakers for my car budget 500 I have 05 altima, what u recommend? What head unit , nothing too fancy but that does the job well
NEED Bolt kits for your car? |
#656 | |||
On my setup for example, the two radiator hoses would cost you around $600... and that's at jobber pricing. That would include:
There isn't one... no one has ever made one. You could be the first... I would be grateful! Just click on the link below: http://zilvia.net/f/businesses/ |
#658 |
^^ just a general opinion. I know you'be worked on a shit ton of different cars, so thought maybe you would be a good person to ask lol. Like anything, even an opinion on the interior or electronics lol.
#659 |
What materials would you recommend to refinish my interior pieces. Just how you did for this customer. I also want to do my center console and shifter/radio trim. Will I use the same stuff?
#660 |
![]() Join Date: Apr 2011
![]() Feedback Score: 19 reviews
On a Oxygen sensor, is it normal to have continuity between the Ground wire and 12v wire?
*just the sensor, not connected to the harness that is.
broadfield, toby |
