Old 07-19-2011, 07:41 PM   #811
chiboy002
Carefuk about running tires down until they explode. Wouldn't want to damage your car because the thread slaps the car or damage your wheel.
happened to my friends shitty daily while he was driving to my house
flared his fender nice and pretty
street dancer.
GLEAM
Old 07-19-2011, 07:54 PM   #812
Z33dori
Z33dori's Avatar
im still stuck on trying to figure out when front grip is too much.
Old 07-20-2011, 11:03 AM   #813
fckillerbee
fckillerbee's Avatar
I think it's different for every driver. Mine would be when you are on your line, full throttle, full angle, and your rear rotates over into a spin. The perfect drift specs in my opinion is when you are at the complete lock under full acceleration in the highest speed of the track. I don't know. I guess I would rather fight the throttle than fight the steering.
Old 07-20-2011, 05:48 PM   #814
word sux
word sux's Avatar
word sux is an unknown quantity at this point
I work at a place that does allot of tires so i get some good takeoffs. I have like 26 decent tires right now behind my shed and all of them were free.
I use good tires on the front since they don't wear that fast and I like allot of grip up front. All the events around here usually have a free tire machine so its worth it. I save $100 - 200 dollars on tires per event by using used tires. Very worth it when your poor.
word sux is offline   Reply With Quote
Old 07-21-2011, 02:15 PM   #815
One_love_silvia
One_love_silvia's Avatar
Trader Rating: (38)
Feedback Score: 38 reviews
i was told to post these here... so here you go lol
Braking/Drifting: Braking Drift Technique
this link leads you to brake drifting, but u can then click the other links at the bottom for other drifting techniques.
i also have this link, if you need them described in a different way, or if u need a short and sweet description.
Drift Session -- Drifting Techniques
2016 Nissan 370z
Old 07-23-2011, 10:46 AM   #816
Driftius_Maximus
Driftius_Maximus's Avatar
Driftius_Maximus is an unknown quantity at this point
The cars power definitely has a lot to do with how to drift your car. I have a slightly modded S14 sr and I never touch my e.brake and rarely have to clutch kick. I typically feint into a drift and then feather the throttle accordingly. Only time I clutch kick is when the car has lost momentum usually through tight transitions. To transition while still with some good speed I just release the throttle. The car will transition its self. I'm not against e brake entries or clutch kick entries, they just don't feel natural to me.
www.facebook.com/drift.militia
Driftius_Maximus is offline   Reply With Quote
Old 07-23-2011, 11:09 AM   #817
!Zar!
!Zar!'s Avatar
I suggest practicing various types of entry techniques. You can only advance so far with one particular style.
Different tracks/corners require different types of styles.
Old 07-23-2011, 05:29 PM   #818
bataangpinoy
bataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymore
im sorry if this has been covered before, but im trying to adjust my ebrake to get it to lock up half decent. ive read that new cables are a must, but what else would you guys recommend?
bataangpinoy is offline   Reply With Quote
Old 07-23-2011, 06:24 PM   #819
word sux
word sux's Avatar
adjust it so theres little to no play in the handle
get some project mu rear pads.
unless your cables are so worn that you can't adjust the slack out of your handle then getting new cables is a waste of money.
Old 07-24-2011, 07:30 AM   #820
towlie
Just tighten the shit outta that bolt under the handle (10 or 8mm iirc) until it's stiff as you desire
Save the money for tires lol
Old 07-25-2011, 03:14 AM   #821
One_love_silvia
Trader Rating: (38)
sooooooooo i need some help gais.
basic run down of my car mods so far:
DF motor mounts
cusco cf rear strut
aem intake
hks hi power exhaust
q45 front brakes
misc poly urethane bushing
kaaz 2 way lsd
stock suspension
stock ka24de engine
basically, with my new 2 way, im having problem breaking traction and locking up my diff. ive used multiple drift techniques. or atleast attempted to.
e brake- it works, and i can drift with it, but i dont like how unpredictable it is. sometimes it slides me out too much. and while i know that that is also partially my lack of skill with it, i just down right dont like how unpredictable it is.
clutch kick
- works fine as well. however, im trying not to beat the shit out of my clutch too much if its avoidable. also recently, i seem to be having a problem with over gassing the car right after clutch kicking, making my angle too much and shortening my drift. in this case, i think i just need to maybe countersteer a little more to make up for the extra gas at the beginning of the drift.
i seem to naturally countersteer tho. whenever i do it, it sorta just happens. i dont think about it when i do it, so its hard to remember to countersteer more. again, this will just take some practice to get right, but like i said i would like to avoid beating up the clutch if possible.
power over: idk if its due to my shitty stock suspension (obviously due to weak ass motor tho), but i cant seem to power through a turn and enter a drift doing so. it just ends up resulting in understeer
feint: pretty much same as power over. idk if im just not feinting hard enough, but i just cant break it loose doing this.
braking drift: my first (kinda) attempt was gunna be tnite....but i ended up heel toe-ing before the turn started. my reflexes took over and i instinctively down shifted before the turn started lol. ive been heel toeing every turn for the past 10k+ miles in my car, so it is kind of just an automatic thing for me i guess.
again this will just take more practice and mental preparation as with other techniques.
i guess what im asking is... is there a way for me to fix any of the problems ive given above with my current set up? is there a way to make powering through a drift or feinting work without causing understeer?
and with the clutch kick technique, should i just focus on thinking about countersteering more after initiating? or should i lighten up on the throttle when initiating? i just feels like i wont lose grip if i dont push it hard enough.
im starting to feel like im being caged and restricted by my car... it started a few months ago, and thats when i realized i had to get rid of the shitty open diff, and get a 2 way.
now that i have a 2 way, im starting to feel the cars power being too weak for me, and the suspension is too sloppy/loose. im going to start saving for my coils soon, i just have a little bit of other shit i have to take care of first. its hard to build a car with quality parts when ur only a pizza delivery driver lol. but im being patient and saving up slowly for each part i buy. and i hope that it will all pay off when its all said and done.
thanks for reading my essay and please help if u can
2016 Nissan 370z
Old 07-25-2011, 12:21 PM   #822
Brian
Brian's Avatar
Trader Rating: (54)
Feedback Score: 54 reviews
With a fresh 2 way LSD, you should have NO problems breaking traction.
I think all you really need is more experience and practice. As you do it more and more, you will learn how the car reacts and how to manipulate it to your desires.
http://bhworld.wordpress.com/
Old 07-25-2011, 12:25 PM   #823
towlie
Get coils next, they will help your driving
The key to drivin a weak KA is if your not scared your doing it wrong lol
Old 07-25-2011, 12:32 PM   #824
Brian
Brian's Avatar
Trader Rating: (54)
Yeah, as far as I'm concerned, if you aren't driving your KA 240 at 110%, you are going to lose.
Old 07-25-2011, 02:22 PM   #825
One_love_silvia
Trader Rating: (38)
so what u guys are sayin is i shud just come in faster? and i bought the diff with 300 miles on it btw. so its new, just not brand new lol
2016 Nissan 370z
Old 07-25-2011, 03:48 PM   #826
Z33dori
Z33dori's Avatar
KA-rry speed lol
Old 07-25-2011, 04:24 PM   #827
word sux
word sux's Avatar
welded is the way to go on stock power
Old 07-26-2011, 03:05 AM   #828
One_love_silvia
Trader Rating: (38)
^ ew no thanks lol. well i think ive perfected drifting in a circle. i was able to feel wen it needed more gas and when to change the steering.
i also properly performed a braking drift tnite. i didnt exactly drift all the way, but i executed the technique correctly. i think i need to come in faster, gas it harder, and turn in harder.
practice makes perfect tho :>
2016 Nissan 370z
Old 07-26-2011, 04:45 AM   #829
word sux
word sux's Avatar
well the if you just welded it instead of doing a clutch type you could have coilovers. but who am I to say...
Old 07-26-2011, 09:55 AM   #830
Brian
Brian's Avatar
Trader Rating: (54)
You did the right thing by getting a real differential. practice makes perfect. That's all there is to it. Once you get some coilovers, you'll notice things get easier as well.
Old 07-26-2011, 11:01 AM   #831
ILoveMyRHS13
ILoveMyRHS13's Avatar
Trader Rating: (25)
Feedback Score: 25 reviews
Faster faster faster faster faster and keep the gas pedal on the floor. I enter in the top of 2nd and sometimes that isn't enough. I need to practice 3rd gear entries but it's hard without a good ebrake.
Old 07-26-2011, 11:51 AM   #832
revcyanide
revcyanide's Avatar
revcyanide is an unknown quantity at this point
I drift my stock KA, welded diff, coils and thats about it (intake exhaust blah blah blah.
sorry for the awful kit/color, that is actually changing this very moment.
anyway i hold pretty long drifts and still have speed to finish the track. and make a decent amount of smoke for a stock engine
pic
What i do is ALWAYS enter the first turn in 3rd gear, sometimes i have to launch like im drag racing to have enough speed. helps that i used to go to the dragstrip a lot with my dad.
but dont be scared of speed (if you are on a track) im still learning a lot.
but pretty much
enter top of 3rd.
Ebrake HARD
countersteer and throttle and clutch kick like a motherfucker the whole way through
Originally Posted by Blackzenki82 View Post
bring da ruckus to dat ass with the braaaaaaaaaassssssssssssshhhhhhhhhhh
revcyanide is offline   Reply With Quote
Old 07-26-2011, 12:51 PM   #833
fckillerbee
as much as brian is right, I have noticed a big difference between a real diff, and a welded diff on a KA. It almost seems like you need power to have that diff lock up. Which you would either have to drive really hard, or get a welded.
I've driven a KA for a few years on a welded. Never had any issues, just don't drive like a retard normally.
Old 07-26-2011, 01:14 PM   #834
One_love_silvia
Trader Rating: (38)
thanks for all the help guys
ya i basically got a 2way becuz i wanted to do it right the first time. plus i only got it for 600 so i wuda still had to save another 6 bills for coils XD
its definitely going to take sometime to get used to and to learn how to use it properly. but wheres the fun if theres no challege? amirite? :P
2016 Nissan 370z
Old 07-27-2011, 11:23 AM   #835
Brian
Brian's Avatar
Trader Rating: (54)
I guess it depends on the diff as well.
My Cusco in my S14 locked super hard, super fast.
The Nismo in my s13 was less aggressive.
With the e-brake you mentioned earlier... Once you use it a lot, you will understand that it's really neat for adjusting where your car goes and how it slides. It seems unpredictable at first, but give it more and more time and you will be able to guide the car wherever you want with the hand brake.
Old 07-27-2011, 12:54 PM   #836
nismobenzo
nismobenzo's Avatar
nismobenzo is an unknown quantity at this point
yeah and you suck ass so maybe you should try some new techniques
the pros dont just use one technique
OKSTANCE.COM
FANBOY HATE MAGNET
nismobenzo is offline   Reply With Quote
Old 07-27-2011, 01:17 PM   #837
!Zar!
!Zar!'s Avatar
Too many people rely on power alone to help them drift.
Old 07-27-2011, 04:08 PM   #838
word sux
word sux's Avatar
I used to be mister clutch kick but now that I am driving faster more technical courses I have been using allot more hand brake and even left foot braking. The hand brake is such a useful tool for scrubbing speed and extending your drift. You can do anything from giving it a quick yank to get a little more angle and scrub speed or drag it to slow your wheel speed down. My e brake has become one of my favorite weapons in my arsenel.
Old 07-27-2011, 04:21 PM   #839
SlideOrDie831
SlideOrDie831 is an unknown quantity at this point
long slide...speed N e-brake.
SlideOrDie831 is offline   Reply With Quote
Old 07-27-2011, 04:24 PM   #840
ericcastro
ericcastro's Avatar
exactly what i say in every thread.
A KA is easier with a welded, and since you never are going that fast and are always full throttle, you dont need it to unlock to get traction and slow down.
When you get real HP, get a real Diff with it
