Motorsports and Skilled Driving Discussion for Organized Racing and motorsports and tips and techniques at becoming a better driver. |
03-08-2012, 05:09 PM | #1 |
I really liked them. I probably prefer those over the Star Specs for drifting. the Star specs had to be heated up a little before getting good front grip. Reminded me of the Hankook RS-2's.
I'm actually buying my first Azenis 615k's here shortly. Pretty excited to run them on the front. Heard great things from the Falken bros. |
03-08-2012, 10:11 PM | #2 | |
Yeah that's what I read. The Auto-X guys like the RS's cause there sticky from the get go. Hows the Treadlife?
I would go with the Z1's or 615's but I wanted specifically a 205/50/17 so that only left me with the AD08's being affordable.
* PigNose SMIC Grille/Vent P# 62697-44F00 * LMK What you guys got |
03-12-2012, 03:32 PM | #6 |
Alrighty guys, I'm having trouble clutch kicking my POS.
I'm always successful whenever I use my e-brake, although whenever I clutch kick it's always a 50% chance I'll spin. I never spin when I use my handbrake. Clutch kicking is so odd to me for some reason. Unpredictable in a sense. But like I said, it's always 50/50. Sometimes I can make the turn, other times not. E-braking, you can control your angle/speed and it's way more smoother. Anyone else catch my drift? <---- (pun intended. lol.) Really though, does anyone else feel the same way? I don't think it's my setup, I think it's just my technique. Idk. Someone wanna shed some light? Here's what I'm working with: |
03-12-2012, 03:36 PM | #7 | |
although my psi's are moderate, 42 in rear, it still takes a couple kicks ebrake, well thats a sure fire way unless you have crappy shoes/pads i do prefer the clutch kick there
street dancer. GLEAM |
03-12-2012, 03:45 PM | #8 | |
You like clutch kicking over e braking? Or only when your e brake sucks? I wish I could clutch kick. Thanks for the info so far guys. |
03-13-2012, 11:29 AM | #9 | |
you are kicking the clutch too late. You are already turning in when you kick the clutch, alowing for a violent oversteer. Try kicking it right as you turn in, but more like a shallow straight line drift. so instead of getting the same angle when you e-brake, try less angle. Not as violent of a turn in. May help. |
03-13-2012, 04:18 PM | #10 | |
Username Monster!
Just kidding Hammy hammer-son... |
03-13-2012, 07:03 PM | #12 | |
Thanks for your help. So should I clutch kick right when I turn the wheel instead? Anyhow, I think you're right about the less angle thing. I believe I'm expecting too much out of a clutch kick. |
03-14-2012, 01:15 AM | #13 | |
At PGP I use a pretty solid mix of techniques. For those of you who haven't been here, this is the track, turn 1 is at the top right of the picture. Follow the picture as I outline the track. I'm getting anxious in case you can't tell haha. http://www.westcoastkarters.com/imag...ial%20view.jpg Here's a break-down Turn #s 1. Ride the inside, swing wide, ebrake turn in pin clutch and gas, drop clutch 2. Clutch kick let the car steer itself 3. Depends on power, either just floor it to connect or ebrake in 4. Stay wide on entry, looooong ebrake, clutch kick 5. Pin it then clutch kick on exit and ride the rumble strip / dirt drop to make 6 6. Pin it 7. Clutch kick let the car steer itself 8. Pin it, jump the inside rumble 9. Still pinned 10. Clutch kick 11. Pin it 12. Ebrake to bleed speed 13. Clutch kick And you pretty much just modulate throttle with appropriate clutchwork where needed till the end from there (little snakey part). *This is just what I do. Car was SR s13, basic drift suspension stuff. My point is PGP is a grab bag styles. Don't shy away from using ebrake because you really need it to do some pretty key corners properly. More seat time is all you'll need to figure out the clutch, just remember to try something different every lap until you narrow it down. You have a really unique car so i'm willing to bet it's a little interesting to slide.
03-17-2012, 01:06 PM | #14 | |
03-12-2012, 03:54 PM | #16 |
my ebrake has always worked, thank god lol
but yeah i prefer clutch kicking over ebrake, sounds more intense. or ebrake and keep the revs high so it sounds just as cool and you get that wheel lock at least to initiate. sometimes ill do an early entry ebrake, but like i said, keep them revs up i dont use a spin knob thing though, i dont like the look, so that might add to my dislike
03-12-2012, 09:46 PM | #17 |
Trader Rating: (81)
Feedback Score: 81 reviews
Spin knob is nice b/c you can easily pull out the lil button to park or w/e. Have fun diggin that knob out.
^ CLutch kick and then counter asap. Once you feel the car sliding out then start to countersteer. How much countersteer depends alot on the severity of the clutch kick (speed/revs/etc). What kind of clutch also helps as well. Think of it like a stock replacement vs a singleplate clutch. The single will grab harder and easier. If you are still on a stock clutch, I would limit the use of the clutch kick technique until you can afford to upgrade. E-brake for initiating is ok, but slows you down too much. I recently been initiating consistently at about 120km and if I use the clutchkick, it slows me down about 10-20km. Try and keep the E-brake for oh shit moments or to adjust angle or to prolong a drift.
03-13-2012, 02:21 AM | #18 |
i can afford to upgrade
just dont feel like it. i know that a better clutch would make it easier, but i like it being more challenging, keeps me busy while drifting
03-13-2012, 10:36 AM | #20 |
I'm switching from Hankooks V12's to Star Specs this year. Hopefully I can get used to them pretty quick.
You ran a 215 on a 9.5 right? Have any pictures?
Nagasaki Motors Friends help you move. Real friends help you move bodies. |
03-13-2012, 10:57 AM | #21 |
215/40-17 on a 9 inch Blitz 03
http://bhworld.wordpress.com/ |
03-13-2012, 11:18 AM | #22 |
Flybert could do that trick, but I don't think I've done it. Not sure.
03-13-2012, 07:26 PM | #23 |
I suck but I can try to help haha, when I clutch kick, say you're coming into a left hand turn. You jerk the wheel right first to get the weight going one way, and then you turn it back left to use all that weight/induce the slide. The clutch kick should be at the same time when you swing back left to aid in breaking traction. Then feather the throttle and catch the wheel in the right place.
03-13-2012, 11:08 PM | #25 |
I like to clutch kick before I get to the turn in point, that way the car has a chance to settle and I'm countersteered towards the turn. Then you can use small controllable inputs to guide the car through the turn.
03-14-2012, 01:13 AM | #26 |
Another point to consider when clutch kicking is RPM and wheel speed difference.Even If you have low horsepower and clutch kick at low RPM, the rear tires are going to have a greater amount of rotational speed difference between the front and are going to want to rotate around the front. Think of speed difference between front and rear as a ratio, the greater speed difference, the greater the angle your car is going to want. Over rotating at low RPM's can be overcome by clutching in and slowing down the rear tires, allowing them to catch up with the front tires, thus regaining grip and straightening out. Not clutching in will do one of two things: it will keep the tires in a rotation that is faster than the front wheel speed, causing a spin, or after your tires have broken loose, they can actually slow down slower than your front tires(like an e-brake initiation) and cause you to spin. Watch any Team Burst video on youtube and you will see every single driver clutch kick within probably 1-2 thousand RPM of Redline. Also keeping the RPM's up after a e-brake initiation will help greatly also, because when you get don't, the wheelspeed will be much lower in the rear compared than the front and can cause you to straighten and or spin depending on the angle your drifting at.
03-14-2012, 01:26 AM | #27 | |
I lol when I watch a car ebrake in then just bog-down and putt away. Its like FWD drifting hahaha
03-14-2012, 01:10 PM | #29 |
this is something i need to start doing, i always forget to raise rpm when i ebrake initiate. right now i prefer clutch kicking because the car feels way more predictable to me. i learned in order to connect something like an s-turn or something, when initiating by kicking, things like timing, line, speed and not fighting the steering wheel are all important. anyone run summit point?
03-14-2012, 03:26 PM | #30 |
the only thing i do not like about clutch kicking is it also pushes you out more
ebrake you can initiate right then and there and follow that line clutch kick, the line you wanna follow gets pushed back but idgaf really, im no pro
