Old 07-12-2015, 05:41 PM   #1
Broadfield
Broadfield's Avatar
Trader Rating: (163)
Broadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to all
Feedback Score: 163 reviews
Originally Posted by Konster View Post
What are your thoughts on the gauges below?
http://www.shopdrift.co.za/products_...ium_series.php
I have never seen/used them in person... but they look too busy and cheap for my taste. I know that's not a very good review of them, but that's all I got.
Follow Along For My Latest Work
My Portfolio
Please Share
Check Out My Builds
Broadfield is offline   Reply With Quote
Old 07-12-2015, 05:54 PM   #2
Konster
Konster's Avatar
Konster is an unknown quantity at this point
Thanks. I think they look pretty cool. Apparently a good amount of 300zx's use them in Austrailia.
Hyer.
Konster is offline   Reply With Quote
Old 09-11-2015, 11:04 PM   #3
Razi
Razi is an unknown quantity at this point
Hey Broadfield,
So I redid some of my speaker wiring and put sound deadening around my speaker (I only did the adapter panel and like a 3 inch area around it. Do I really need to cover the entire door?), and now I'm getting better sound and more bass (Yay!). Well, the problem is, I'm getting a ridiculous amount of buzzing from around the speaker grille. Did your S13 ever have this issue?
I applied some felt tape where the grille and door panel meet, wrapped some of the door wiring harness in foam and put more sound deadening on the door, but I'm still getting a crap load of buzz/rattle. I'm losing my mind.
Should I put some sound deadening on the door panel, around the speaker grille?
Razi is offline   Reply With Quote
Old 10-25-2015, 10:24 PM   #4
gbaby2089
gbaby2089's Avatar
gbaby2089 is close to perfectiongbaby2089 is close to perfectiongbaby2089 is close to perfectiongbaby2089 is close to perfectiongbaby2089 is close to perfectiongbaby2089 is close to perfectiongbaby2089 is close to perfectiongbaby2089 is close to perfectiongbaby2089 is close to perfectiongbaby2089 is close to perfectiongbaby2089 is close to perfection
Do you know of any good places to get a pre-purchase inspection done in Bloomington/Normal?
Thanks in advance!
gbaby2089 is offline   Reply With Quote
Old 10-25-2015, 10:37 PM   #5
Broadfield
Broadfield's Avatar
Thanks in advance!
Yep, a real good friend of mine recently opened his own business. Like me, he has been into the import scene for a couple of decades. His name is Doug and you can find the # on the Facebook page. Tell him Toby referred you.
https://www.facebook.com/DTTRLLC?fref=ts
My Portfolio
Please Share
Check Out My Builds
Old 10-25-2015, 10:54 PM   #6
gbaby2089
gbaby2089's Avatar
Perfect, thanks Toby!
Old 10-25-2015, 11:11 PM   #7
godrifttoday
godrifttoday's Avatar
Trader Rating: (82)
godrifttoday is an unknown quantity at this point
Feedback Score: 82 reviews
do you know where i can purchase termial pins for nissan 240sx ecus?
NEED Bolt kits for your car?
http://i48.tinypic.com/6gx5e0.jpg
godrifttoday is offline   Reply With Quote
Old 11-14-2015, 12:31 PM   #8
S13stockness
S13stockness is an unknown quantity at this point
I have a 93 240sx. It has some cheap aftermarket Sony head unit. I want to put in a double din stereo with removable faceplate. I think a friend of mine had a JVC unit that had the detachable face. Could you recommend a HU for me along with a set of front and rear speakers. Maybe you can do a bundle deal so I can buy it from you
S13stockness is offline   Reply With Quote
Old 11-14-2015, 01:01 PM   #9
Broadfield
Broadfield's Avatar
I would check with Wiring Specialities or Chase Bays
Send me a PM with vehicle info i.e hatch, coupe etc.
My Portfolio
Please Share
Check Out My Builds
Old 01-02-2016, 04:03 PM   #10
Razi
Hey Broadfield,
I'm getting noise whenever my AEM wideband is turned on. I moved all my grounds to a spot on the dash support, to the left of the A/C unit. Thankfully this fixed the noise I had when I used the AUX and phone charger at the same time. But I still get a high pitched whine through the speakers when the wideband is turned on. This happens even with the headunit off, and the key in the off position.
All my AEM has for wires are for power, ground, and 2 wires for ECU logging.
I've jumped both the power and negative to the battery, and I still get that whine. I'm so confused.
Have you ever come across a problem like this?
Thanks!
Old 01-02-2016, 06:46 PM   #11
exitspeed
aWingThing.com
exitspeed's Avatar
How do you feel about the Pack going past the first round of the playoffs? Still can't believe we lost to the Bears. On a scale of 1-10 how bad do you want Cutler gone?
Old 07-11-2016, 04:53 PM   #12
dudermagee
dudermagee's Avatar
dudermagee is an unknown quantity at this point
Any body know what's up with Toby? I've been trying to get a hold of him for two weeks now....
Originally Posted by DC Dan MAX USA View Post
Don't wuss out on me.
dudermagee is offline   Reply With Quote
Old 07-02-2017, 12:05 PM   #13
relix oner
relix oner is an unknown quantity at this point
SUBWOOFERs in my 240 hatch
i want to put a subwoofer in my hatch. something that sounds clear and can get loud. while saving the most trunk space possible. Any really awesome shallow mounts subs you would reccomend? im ok with a 10" or a 12"...budget under $500 for the sub
relix oner is offline   Reply With Quote
Old 07-02-2017, 12:20 PM   #14
kingJurzy
kingJurzy is an unknown quantity at this point
I had a 12 that needed the airspace of a 10. Hit all the point you talked about. Stereo Integrity BM mkIV
kingJurzy is offline   Reply With Quote
Old 06-28-2016, 08:33 PM   #15
chandler_bing
chandler_bing is an unknown quantity at this point
Hey Broadfield,
What is your method for pulling speaker wires through the front doors of an s13? Also, where's the best spot to run the power wire for an amplifier?
chandler_bing is offline   Reply With Quote
Old 06-29-2016, 01:44 PM   #16
chandler_bing
Hello,
What do you recommend to use to pull speaker wire through the front doors on an s13 and to run amp power wire through the firewall?
broadfield, toby
