Old 01-31-2014, 09:19 PM   #91
PIN GIO 2
PIN GIO 2's Avatar
PIN GIO 2 is an unknown quantity at this point
Send a message via AIM to PIN GIO 2
Originally Posted by Oakville View Post
Hahaha positive spin on it...I like it man.
Another personal question if thats ok...are you 100% deaf? Like zero hearing at all?
and I followed your instagram, glad i found out about that! -oakr32
Can't hear at all but I can hear a bit like weld noise, exhuast loud, firework, and any loud
PIN GIO 2 is offline   Reply With Quote
Old 01-31-2014, 09:40 PM   #92
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
Ugh sucks I can't see any of the pics
Old 02-01-2014, 02:23 AM   #93
dnice78
dnice78's Avatar
dnice78 is an unknown quantity at this point
Same here...
dnice78 is offline   Reply With Quote
Old 02-01-2014, 08:55 AM   #94
maces13
maces13's Avatar
maces13 is an unknown quantity at this point
Me too fuck. I really wanna see this thing now
maces13 is offline   Reply With Quote
Old 02-01-2014, 02:29 PM   #95
PIN GIO 2
PIN GIO 2's Avatar
same here no show pic
I'm sorry about that guys
i have over max 10 gb pics let me fix it soon.
Old 02-01-2014, 03:26 PM   #96
PIN GIO 2
PIN GIO 2's Avatar
Old 12-26-2014, 09:31 PM   #97
PIN GIO 2
PIN GIO 2's Avatar
I know i havent update since feb 2014! i still busy with school and family but finally this time i have time work on racecar build project. I have bad news i found out CPR engine didnt good job rebuild my engine while i wanna check what inside engine then found valve hit on top piston so i have to start over buy new engine parts. One of most happy with CBM motorsport took care of everything!
Also i did disassembly and re-assembly engine but most new parts from CBM Motorsports, let start with engine issue.
I went to Pierce College Summer Performance Engine class.
I told to CPR Engine i want to refund money for damage but CPR Engine owner said you will happy with engine and valve hit on piston is nothing and no big deal. i still dont trust it for beat engine up at drift track sound like bad idea then i was move on and keep going build project to be continue.
engine got new forged connecting rod, bore over .030 forged pistons low compression, valve job, and more.
more coming update picture
Old 12-26-2014, 09:35 PM   #98
PIN GIO 2
PIN GIO 2's Avatar
no truck? no problem engine got in suv solved problem
engine finally in
Old 12-26-2014, 09:56 PM   #99
future
future's Avatar
Trader Rating: (42)
Feedback Score: 42 reviews
It's back! And almost alive
Old 12-27-2014, 04:04 PM   #100
dbeiler
dbeiler's Avatar
dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler dbeiler
Looking good! What tie rod setup will you be using with those PBM knuckles?
dbeiler is offline   Reply With Quote
Old 12-27-2014, 05:51 PM   #101
lg54
lg54 is an unknown quantity at this point
amazing. subddd
lg54 is offline   Reply With Quote
Old 12-27-2014, 07:00 PM   #102
tricky_ab
tricky_ab's Avatar
Looking good my man!
Instagram
Back for round two... 4 doors this time around...
Old 12-27-2014, 09:17 PM   #103
PIN GIO 2
PIN GIO 2's Avatar
to be honest, i still learning and noob how to set up front suspension super angle.
I plan to order VooDoo13’s S13 Front Adjustable Tension Rods, i hope my front suspension are great increased steering angle.
Front Lower Control Arm modded extended 25mm and gussted. The ball joint replaced Moog ball joint but it isn't tight as sitting on it im not sure how to explain like you know when you installed ball joint but it still loose around 2-3mm gap, is that ok? I will add mod adjustable lock stop next week. i still not sure about mod scalloped lower arm for allow knuckle to more travel because of PBM knuckle 45 of correction.
I think about keep tein tie rod inner/outer and i already put GKtechs spacing the tie rods farther forward on it.
You can see my front suspension setup kind of issue with SIkky sway bar clearance between rim but i haven't install sway bar so i believe do i need mod sway bar cut more short and weld it?
I hope you guys can help or correct me whatever i doing wrong.
Old 01-18-2015, 06:15 PM   #104
PIN GIO 2
PIN GIO 2's Avatar
small update picture nothing special
pick up new front bumper and skirt sides
custom make 3" straight y-pipe to turn down tip before rear subframe with v-band clamp
that it for now
Old 01-18-2015, 07:05 PM   #105
winter
winter's Avatar
winter is an unknown quantity at this point
Good work man...keep the dream going.
winter is offline   Reply With Quote
Old 01-22-2015, 03:11 PM   #106
PIN GIO 2
PIN GIO 2's Avatar
New ls3 valve cover instead ls1 valve cover because of rocket arm trunion upgraded hit baffle on the d/s valve cover also new color purple and red flakes. New LS2 CTSV power steering pump bracket, i will order turn one pulley next month. New oil catch can from CBM Motorsports with fitting and SS hose to -8an male on valve covers. Also i think about new water pump because i dont know used water pump miles but wait till next month.
today, i will work on radiator and oil cooler mount and custom make ducting front end.
Old 01-22-2015, 03:12 PM   #107
PIN GIO 2
PIN GIO 2's Avatar
anyone donate me rack and pinion return hardline and hose to reservior?
Old 02-01-2015, 02:06 AM   #108
PIN GIO 2
PIN GIO 2's Avatar
dont much comment on here? last post and im done with zilvia build thread
I still use f-body power steering pump with ls2 bracket so i did drill, tap, and die made a fit. i still use s14 psp reservoir with sikky power steering lines kit.
i have to cut radiator inlet tubing because try make fit hose.
done!
oil catch can completed
i dont really like autozone upper hose, i still look for silicone hose 1 1/4 to end 1 1/2.
i love custom make ducting
im not done with ducting because i have to test with air flow make sure it though all of cooling system. i havent buy electric fan because im not sure which better. i still figure out where oil cooler mount at.
Old 02-01-2015, 11:35 AM   #109
bmxer11
bmxer11's Avatar
bmxer11 is an unknown quantity at this point
The build looks awesome man, youve been working on it for quite a while and you can tell everything is being done right. Don't give up on it whatever you do cause that car is gonna be badass. wish i had some power steering stuff to give you
bmxer11 is offline   Reply With Quote
Old 03-13-2015, 01:52 PM   #110
PIN GIO 2
PIN GIO 2's Avatar
small update
Thanks to Zerek Fewell done great job custom make front bash car fit into bunny rocket bumper
custom make coolant surge tank and overflow tank
beautiful color?
right now, car is almost finish but need re do engine harness, new haltech ecu, fuel lines, get new windshield, need new tires, need new painless wiring, and few parts. that long to go and been almost 3 years now
Old 04-01-2015, 10:06 AM   #111
skimmpysb
skimmpysb is an unknown quantity at this point
yesssssssssssssssssss
skimmpysb is offline   Reply With Quote
Old 02-09-2018, 04:53 PM   #112
z31andrew
z31andrew's Avatar
z31andrew is a glorious beacon of lightz31andrew is a glorious beacon of lightz31andrew is a glorious beacon of lightz31andrew is a glorious beacon of lightz31andrew is a glorious beacon of lightz31andrew is a glorious beacon of lightz31andrew is a glorious beacon of lightz31andrew is a glorious beacon of lightz31andrew is a glorious beacon of lightz31andrew is a glorious beacon of lightz31andrew is a glorious beacon of light
Did this car ever get finished? Would love to see the final product!
z31andrew is offline   Reply With Quote
