#12961 |
S14 Engine pull
Is it possible to pull the engine out of an S14 without disconnecting any of the AC refrigerant lines? Can I simply disconnect the drive belt and remove the compressor mounting bolts then leave in place? Car can not be driven in current state so I can't get the refrigerant vacuumed out. Any advice is appreciated.
Thanks, K |
#12962 |
PIC request or pdf/instructions.
I got a CXRacing FMIC for my S13 sr. I got the four brackets that are provided with the kit. I cant seem too figure out how to mount the intercooler. i dont have the instructions, didnt come with any. In any of the pictures it doesnt show how or where to mount the brackets. I ordered the "new" style, if anyone is running this pictures would greatly help cxracing.com: FMIC Intercooler Piping Kit + BOV 240SX S14 S15 SR20DET,Tube & Fin Intercooler
#12963 | |
![]() Join Date: Sep 2004
Trader Rating: (24)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 24 reviews
^Sent you a txt Marc.
#12964 | |
AFC #1
![]() Join Date: Oct 2003
Held against the framerail it never got in the way of the pull or drop. The compressor was heavy. So, I did need someone to hold it from the top while I aligned it back up and bolted it back in from the bottom.
#12965 |
![]() Join Date: Jun 2008
![]() Feedback Score: 11 reviews
I did a 5 speed swap on my DOHC S13 KADE. Got everything from a SOHC KAE. Since the swap, my car vibrates a little loud inside the cabin. Friends have told be it sounds like I have a driveshaft issue. My car is a 93 s13 and I'm not sure if it came w/ABS (although I don't see why it wouldn't given that it's a 93). I'm wondering if getting a ABS driveshaft will solve my problem. Any suggestions?
#12966 |
Boostin,
For a car to corner safely, the outer wheel needs to turn faster than the inner wheel. This is because it has to travel a farther distance. This is the action that a differential allows…one wheel to rotate at a different speed than the other wheel. If there were no differential, both wheels are forced to rotate at the same speed. This causes one tire to skid or hop along the pavement and if the traction won’t allow the wheel to skid, the axle will twist and untwist just like a torsion bar. This is very stressful on the axles and can ultimately lead to failure of the axle…as in snap! And since you have no differential action with a spool, even following bends in the road can pitch the rearend into side-slip. Yeah, I get you, sideslip(aka drifting) is fun, however, the condition on the axles will sooner or later cause FAILURE, or the negligent state of the car's diff will cause you to hit someone(This is NOT an accident, it is negligence outright because you are forcing the situation) NismoK, I would agree that all things being equal, displacement wins, however, as one who owns a 1250cc Sportster(76ci) with a hair over 110hp, my highly tuned engine and bike smoke bikes with more displacement(things NOT being equal). State of tune is the big equalizer. Weight and lack of weight is an equalizer. Forced induction is the greatest equalizer we know here, with the case in point the Fe block KA vs the Al block SR Turbo. A KA24DE-T(KA-T) will make great power, however, it will never equal performance of the smaller displacement, highly tuned SR20 without a lot of hard work, large expense, and tons of labor(bore, stroke, deck, ITB, Turbo) Do all that work to a KA and it will smoke an SR20...until the guy with the SR does the same thing. At that point, with an Fe block, you lose the battle by having more weight and a lower hp:weight ratio
#12967 | |
Other than some tire noise while parking, control-ability isn't that bad with a welded. Esp for daily driving. Yes it will force the car to perpetually be in a mild over-steer or under-steer state, but that probably helps most drivers finally figure out just how important weight transfer is on an S-chassis.
'95 240 | @SleepySteve72 |
#12969 |
Need help identifying!
This probably isnt the right place to post this but since it will be going on a car I guess i can make a case that it is somewhat technical. Anyways my question is this. What body kit is on Matt Powers green s14, the red one, and what kit is on the other car?? Please let me know!
#12970 | |
AFC #1
If you used a stock driveshaft the wrong one would hit the flange and be to long or come up short. Single piece driveshaft would stick out of the trans or be to long. The vibration is at idle or when accelerating? Where do you hear/feel it coming from?
#12971 | |
If not, than you don't have abs. As ^^^^ mentioned make sure your drive shaft matches the diff Sent from my Nexus 7 |
#12972 |
![]() Join Date: Oct 2012
17x9 +22 tires
What tire can I run on my 17x9 + 22 with a 4 inch lip. ? All four corners same size
Ima be running megan track coilovers. Its an s14. I want to run as much tire as possible both front and rear. With as little stretch as possible |
#12975 |
There's a type of Bride seat that comes in a solid dark blue fabric. They look like an older model seat and are recline-able. Any one know which seats I'm talking about?
#12976 |
I need help choosing betwin EM blue or MSII?
Built ka-t Crower 272 cams and all valvetrain Ported head HP goal 350-400 whp I'm really looking in to MS Idk if emb would support it Plz pm post or txt me 6613019717 Thanks! V Sent from my SAMSUNG-SGH-I717 using Tapatalk 2 |
#12977 |
![]() Join Date: Sep 2010
Newb question (already searched) how can u tell the different between and sohc gauge cluster and a dohc just by looking at them out of the car. I have three I was gonna post for sale but I'm sure an obvious question would be if they're dual or single (if there is one), and wanted to figure out before I post them. Thanks in advance...
#12980 | |
#12981 |
I recently bought a set of used Toe Rods and RUCAS from a buddy.
On the joint side of them there are little cylindrical inserts. There are two on one toe rod and 1 on each of the other toe rod and both rucas. I was just curious what they are used for, if they are necessary (I am assuming they are), and if I could new ones from Megan still or have new ones made? Thank You. |
#12982 |
![]() Join Date: Aug 2012
Does anyone with energy suspension poly bushing have a squeaking/ croaking problem? They were installed by previous owner. Not sure if he didn't grease them.
WTB: zenki hood, passenger headlight!! |
#12983 |
Yes you need them. OEM bushings are wide and the rod end would just flop around in the space without the spacers
#12984 | |
Formula 5 Prelube | Energy Suspension Parts |
#12985 | |
#12986 | |
Your friend is either a dick or an idiot (or maybe both). Depending on what brand they are, you MIGHT be able to get new ones. Otherwise just get completely new parts. |
#12987 |
[QUOTE=Vadim's13;5167774]I need help choosing betwin EM blue or MSII?
Built ka-t Crower 272 cams and all valvetrain Ported head HP goal 350-400 whp I'm really looking in to MS Idk if emb would support it Plz pm post or txt me 6613019717 Thanks! V No one??? |
#12988 | ||
The light green one is the same The red car is BN Sports Quote:
those? if there isn't the gradiation pattern on the seat then the owner could have changed out the pads.
street dancer. GLEAM |
#12989 | |
Thanks you for helping me out! |
#12990 |
If the arms you have are Megan then I have misalignment spacers for the traction and toe arms from a project I did a while ago. I have no idea what size the Megan RUCA misalignment spacers are, but you are welcome to have the ones I have as I will never use them. Just PM me.
