06-03-2013, 01:24 AM | #13862 |
here's one:
I just upgraded my s13 sr t25 to s15 spec-r bb turbo, and now when I shut down the engine I hear the bearings/turbo spin for about 20 seconds before coming to a stop.. The sound isnt particularly bad, I dont think.. But its loud and definitely there. Is this normal? Is it being starved of oil? Am I over-thinking and overreacting? Never owned any turbo other than the original t25 thanks |
06-03-2013, 04:42 AM | #13864 |
I thought it was a big hole in the bottom of my transmission, so Ifixed it
06-03-2013, 04:44 AM | #13865 | |
hole on tranny. is it normal? : SR20DET Forum (rear-drive)
06-03-2013, 07:04 AM | #13866 | |
as a matter of fact, don't jb weld ANYTHING on your car.
street dancer. GLEAM |
06-03-2013, 07:05 AM | #13867 | |
At least research stuff FIRST so you MIGHT know what you are about to screw up, this case in point!
06-03-2013, 07:24 AM | #13868 |
Ok thankyou
06-03-2013, 07:27 AM | #13869 |
I do a lot of work without messing things up, im think im doing pretty well considering all the work I do and the only problems I have are this and the problem in the other thread I have open. I searched for this but I guess I used the wrong keywords? Idk. But will it be ok temporarily until I get a chance to fix it?
06-03-2013, 08:04 AM | #13870 | |
Yes it will be ok, just drill a hole in that jb weld.
* S14SR22 * 9.0 c/r * GT3071R * |
06-03-2013, 08:10 AM | #13871 |
Alrighty, I think it's a pretty thin layer because I had to take it somewhere and the jb weld was just a temp fix until I got more of a chance to fix it. And I just got my car tuned and made 284 hp so it's fine, I just have to fix the noise and learn a little throttle control and im golden
06-03-2013, 12:00 PM | #13872 |
Does anyone know if it is ok to remove the banjo assembly off the power steering pump and go straight off of it with a -AN fitting? The reason I ask is because the FSM shows a spring and a pressure valve inside the pump pressing against the bolt (which I would be removing). I know it wont be the same, but I just need to make sure it isn't gonna blow my pump out or give me zero steering feel.
06-03-2013, 01:54 PM | #13874 |
Just bought a s13 coupe and noticed that under the the headliner all the roof support has been cut out and discarded. Non sunroof model, my question how important are those bars to the cars structural rigidity? Should i be thinking about welding in some kind of support bars there? or just leave it alone, the roof doesnt bow or anything like that. THanks.
Nothing says racecar like a stock car with no interior. |
06-03-2013, 08:35 PM | #13878 |
negatory, unless its a high temp acrylic or something. the power steering gets hot
06-03-2013, 08:36 PM | #13879 |
does anyone know what the black liner is that is glued to the carpet insulation on s13 front floor areas?
it isn't the tar shit that dryice removes, this stuff is like sandwiched between the carpet and the floor pan. it breaks off and is brittle as fuck, wanna know if its worth replacing for road noise/insulation when doing a carpet swap
06-03-2013, 08:39 PM | #13880 |
Twin cam and sohc oil filters the same?
Sent from my SGH-M919 using Tapatalk 4 Beta |
06-04-2013, 09:54 AM | #13881 | |
06-04-2013, 10:45 AM | #13882 | |
THEORY on Powersteering pumps: The pump pressurizes the steering ram which assists the steering movement. Fluid is pumped out of the pump, pressurized to the mechanisms, works through te mechanisms, then is pushed back into the pump. WAG(Wild Ass Guess): Removing that assy would not do anything dewtrimental as it appears it only stops large particles from entering the pump, and not fluid if it is the return. If the project is simple enough, put the AN fitting on it, run it it up and see what happens in the driveway. If it doesn't work, modify the AN fitting to work with the valve
06-04-2013, 10:48 AM | #13883 | |
06-04-2013, 10:54 AM | #13884 | |
MANY PEOPLE HERE TO READ IT AS WELL For every good natural mechanic, there are six schooled mechanics that are worth a shit, and 20 shadetree/home garage mechanics that just plain FSU. I'm schooled, so I know theory and principles that apply to all engines, but for silvia engines, dude, I am a straight newb, but at least I don't break shit or FSU
06-04-2013, 11:14 AM | #13885 |
What kind of engine does a stock 1992 Nissan 240sx have?
Also would you buy a Nissan 240sx that has a blown head gasket? (I want to see other people's responses to this) |
06-04-2013, 11:27 AM | #13886 |
wanting to get chrome inside door handles for my S14 I know Q45 door handles fit but not sure exactly what year? anybody have more info on this by any chance? thanks
06-04-2013, 12:03 PM | #13888 | |
And I'll do you a solid and answer your second question as politely as possible. Simply put it doesn't matter if I would buy it, what matters if you would or better yet should buy it. Just by your first question it doesn't seem that you have much experience with 240s, so I don't suggest its a good idea to pick that up. |
06-04-2013, 01:51 PM | #13889 | |
isn't that heavy stuff? I mean this carpet liner shit is hardly heavy, much rather just put a new liner in and keep the weight relatively the same
06-04-2013, 04:09 PM | #13890 | |
Trader Rating: (26)
Feedback Score: 26 reviews
I mean, your question is answered by a previous member but really? What kind of motor does a stock 240SX have? Google can answer retarded simple questions like that. As for buying a motor with a blown head gasket, if the price is cheap, there is no internal issue, and you don't mind rebuilding it, then go for it but maybe you should state WHICH motor you plan on buying that has a blown head gasket? The OEM KA24[D]E - depending on year - or a swap? |
