Old 08-13-2012, 06:03 PM   #1471
JasianBlazin
Trader Rating: (24)
JasianBlazin is an unknown quantity at this point
Feedback Score: 24 reviews
Originally Posted by 2jdm4you View Post
If I could used duct tape and a can of brake cleaner and a lighter to stretch my 205 on a 10.5 then you should be able to get this.
sorry but a 205 on 10.5 is just obnoxious.
JasianBlazin is offline   Reply With Quote
Old 08-13-2012, 09:10 PM   #1472
2jdm4you
2jdm4you is an unknown quantity at this point
Sorry I got the tires for free and only had a 10.5 laying around.
2jdm4you is offline   Reply With Quote
Old 08-16-2012, 09:42 AM   #1473
truckmtrS13
truckmtrS13's Avatar
truckmtrS13 is a jewel in the roughtruckmtrS13 is a jewel in the roughtruckmtrS13 is a jewel in the roughtruckmtrS13 is a jewel in the roughtruckmtrS13 is a jewel in the roughtruckmtrS13 is a jewel in the roughtruckmtrS13 is a jewel in the rough
How does a 225/45r17 sound on a s13 hatch on Old tein coils 17x9 +12 all around?
Recommendations? Suggestions?
truckmtrS13 is offline   Reply With Quote
Old 08-16-2012, 09:53 AM   #1474
zooopreme
Trader Rating: (38)
Feedback Score: 38 reviews
Suggestions? How about giving us a little more info on what you want to do.
Do you want to slam the car to the pavement? What kind of arms do you have on the car? Are the coilovers independently hieght adjustable.
I swear, one of the first things that should be posted here is what suspension parts are on the car & what kind of fitment you want. Throwing out wheel/tire specs is so broad, it can happen plenty of ways.
And to answer your question, it's do-able. Whether the tires sit flush with the fenders or not. Roll/pull is determined by alignment specs. 45 series is too tall of a tire & 225 is a little more meaty than what a 215 does for a 9". 215/40 would fit perfectly.
For Sale #1 | For Sale #2
Old 08-16-2012, 10:10 AM   #1475
truckmtrS13
The coils are tein he's and are height adjustable but don't go that low. Isis rucas, Traction, tension and toe arms. I'm probably going to have to roll all around. Just want it to look nice with some stretch.
Old 08-16-2012, 10:21 AM   #1476
zooopreme
Trader Rating: (38)
For a 17x9 +12
Here's 215/45 with a decent amount of rear camber: http://rimtuck.com/photos/1251/1288305439.jpg
Now, imagine a 225/45. You will need more than a pull unless you want to run an unnecessary amount of camber.
225/45 up front, you ask? http://rimtuck.com/photos/1/1247935005.jpg
If semi-balloon fitment is what you're looking for, look no further.
IMO, the best way to do 9" +12's is 225/40 or 215/40 if you're in a mild stretch mood.
Example being 225/40 for the rear (18's"): http://rimtuck.com/photos/701/1250669060.jpg
215/40 up front, these are +15 but I'm sure you can visualize +12: http://rimtuck.com/photos/301/1229411345.jpg
Old 08-16-2012, 11:08 AM   #1477
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
^^^225/45-17 isnt bad fitment. Thats on point as far as overall diameter compared to the OEM wheels.
CLICK HERE!!!
Old 08-17-2012, 04:42 PM   #1478
Frankz91
Frankz91's Avatar
Frankz91 is an unknown quantity at this point
Just bought Rims for my S13 they are 17x9 +15
And going to drop it on Coils soon
Trying to get my tire to go inside my fender just a little
S13 is a DAILY DRIVER
wat tires are best were I just have to pull my fenders
That allows me the widest tires
Frankz91 is offline   Reply With Quote
Old 08-17-2012, 05:26 PM   #1479
fliprayzin240sx
All depends on how much camber you run and how much pull you do to get the widest tires possible. For 9js on S13s, I'd probably go 225/45-17s.
CLICK HERE!!!
Old 08-17-2012, 05:42 PM   #1480
Frankz91
Frankz91's Avatar
Dont want much camber since its my daily
How will my S13 sit on 225/45
Old 08-17-2012, 05:55 PM   #1481
fliprayzin240sx
RIMTUCK.com - Search Results - Thumbnails
Just to give you ideas...
CLICK HERE!!!
Old 08-17-2012, 06:07 PM   #1482
silvia240
silvia240's Avatar
silvia240 is an unknown quantity at this point
S14
PBM Pro Comp Coils, FLCA+TENROD combo, RUCA, Toe, Traction Rod
Currently fenders are rolled. Rims are 18x10.5 +15 rears running 245/40/18. I am not sure how much camber i need to run to make it driveable. Right now, camber is @ -1.2. If what I read above was true, adding almost 2 degrees would give me about 1/2 inch of more clearance. Would increasing to -3 camber + getting a SLIGHT pull on my fender be enough?
My fronts seem to be okay 18.9.5 +12 @ 225/40/18 with -1 camber.
Included my alignment report from last time, before I put on my new rims. I am heading back to the alignment shop tomorrow and any help would be greatly appreciated.
silvia240 is offline   Reply With Quote
Old 08-17-2012, 06:29 PM   #1483
fliprayzin240sx
Personally, looking at it, I'd just pull it out some more since I prefer to keep my camber as close to 0 as possible. Lip is still flat so all you have to do is to get it bowing out a bit and you should be good to go. Get a torch and warm up the fender from behind, hammer it slowly from the inside while pressing a rubber mallet on the outside, then use your hand to feel the fender and try to keep it smooth every time you hit it with the hammer from the inside. Check the clearance ever so often by mounting the wheels back on to see.
CLICK HERE!!!
Old 08-19-2012, 12:00 AM   #1484
hrdprkin180
hrdprkin180's Avatar
hrdprkin180 has much to be proud ofhrdprkin180 has much to be proud ofhrdprkin180 has much to be proud ofhrdprkin180 has much to be proud ofhrdprkin180 has much to be proud ofhrdprkin180 has much to be proud ofhrdprkin180 has much to be proud ofhrdprkin180 has much to be proud ofhrdprkin180 has much to be proud ofhrdprkin180 has much to be proud ofhrdprkin180 has much to be proud of
ok so I've been looking around but cant seem to get anywhere, so here it goes.... will 18x10.5 +12 ALL AROUND fit on an s14 with stock metal panels? if so, please post tire specs, camber needed, and the needed roll and pull... pics are a huge plus.
hrdprkin180 is offline   Reply With Quote
Old 08-19-2012, 02:09 AM   #1485
silvia240
silvia240's Avatar
Look at my post above. Stock metal, S14 w/ 18x10.5 +15. Going to need fender roll + pull and some negative camber.
Old 08-19-2012, 10:21 AM   #1486
s14silvia10
s14silvia10's Avatar
s14silvia10 is an unknown quantity at this point
I'm in the same position as both of you guy, im still trying to figure out what tire to use i was thinking about 215/35/18 for 18x9.5+12 up front and 235/35/18 for 18x10.5 +15 in the rear on stock metal just roll fenders would it work? Same suspension as silvia240, can you post pic of your car silvia240? Thanks in advance
s14silvia10 is offline   Reply With Quote
Old 08-19-2012, 10:28 AM   #1487
hrdprkin180
s14silvia10- you dont need to run a 35 series tire, you would be safe in running a 215/40 (F), and a 225/40 (R) with your set up... thats what I've been seeing lately.... as for me, i know i can runthe rears no problem, It's the front that concerns me, i need to know if I would have to pull like crazy or even flare it out.
Old 08-19-2012, 11:24 AM   #1488
fliprayzin240sx
Fronts easier than the back since its cake walk to dial in more camber up front than the rear. Pull the fenders up front as much as you can, then dial in some camber if you're slammed.
CLICK HERE!!!
Old 08-19-2012, 11:27 AM   #1489
Bushido
Bushido's Avatar
i've run 215/40/18 federals up front on S13, federals run wide so there wasn't alot of room. I would definitely go 35 series if i was you.
Old 08-19-2012, 11:33 AM   #1490
fliprayzin240sx
But you're on an S13. There is no need to run undersized wheels on S14s since we're not as restricted as you guys guys under the fender well.
CLICK HERE!!!
Old 08-19-2012, 12:10 PM   #1491
silvia240
silvia240's Avatar
Thanks flipray for the advice. I am going to get my fenders pulled first and go from there. I am with you, I would like to keep most of my tires on the asphalt.
Fronts I am running 225/40/18 on a 18x9.5 +12 wheel. That fits no problem. I an just going to roll the front fenders and I think I will be able to go pretty low. Its just the rears that will need massaging (roll + pull) to make it fit.
*pictures not the best angles, especially none from the front, but you can see there is plenty of space left.
As for hrdprkin180, from what i have read (i am probably wrong) you need a lot of work to run 18x10.5's up front. Most of the guys I have seen running wider on the front have new wider fenders. Good luck with those and post some pics when you squeeze those up there.
Old 08-19-2012, 03:23 PM   #1492
hrdprkin180
Fliprayzin240sx, ok thanks, i knew i had to pull the fronts i just didnt know how much i would have needed... i havent actually bought the wheels, but after looking around some more i think im just going to have to stick with a 18x9.5 -ish wheel for the front... silvia240, i would like to see a good side shot of your car once you dial your camber, toe, and coils in, looking good so far
Old 08-21-2012, 02:39 AM   #1493
CharCharXD
CharCharXD's Avatar
CharCharXD is an unknown quantity at this point
Can a 18x10 +26 & 18x11 +21 wheel fit on a s14 kouki?
CharCharXD is offline   Reply With Quote
Old 08-21-2012, 07:01 PM   #1494
CRPS13
CRPS13 is an unknown quantity at this point
^The thing is that pretty much any wheel will fit on any car. what you will have to figure out is what combination tire width and profile for the size wheel you have, fender modifications and alignment specifications for that particular set up.
CRPS13 is offline   Reply With Quote
Old 08-21-2012, 07:45 PM   #1495
fliprayzin240sx
Rear would be perfect on stock fenders with just a roll and some pull. Fronts, you'd need some spacers to clear whatever suspension you have. You'd probably need to get that down to +18 or so just to be on the safe side.
This is 18x10+18 225/40 and 18x11 +28 265/35
CLICK HERE!!!
Old 08-21-2012, 09:23 PM   #1496
CharCharXD
CharCharXD's Avatar
Thanks guys this really helped!
Old 08-21-2012, 09:46 PM   #1497
maxxxfly
maxxxfly is an unknown quantity at this point
Questions for a S14:
1. Can I run 245 40s on 18x9.5 +12 rim all around with just rolls and mild rear pull?
2. Will 18x9.5 +12 hit the coils up front or will I have to run a spacer. I want to try running max neg camber up front for autoX balance. Would really like -2 with no more than that out back.
maxxxfly is offline   Reply With Quote
Old 08-22-2012, 08:19 AM   #1498
aznoy
aznoy is an unknown quantity at this point
Talking
Originally Posted by 95KA-Turbo View Post
Fronts will fit no problem with the lip flattened. Rears will need ~-3 camber and a slight pull.
This is ~-2.5 camber with a 255/40/17 BFGs on a 17X11 +12.
Front shot:
The fronts in those photos are 17X10 +7 with 245/40 S-Drives and ~-2.7 camber.
whats the brand of these rims? that would look great with my green kouki.
aznoy is offline   Reply With Quote
Old 08-22-2012, 08:25 AM   #1499
Te37
Te37's Avatar
Te37 has made poor choicesTe37 has made poor choicesTe37 has made poor choicesTe37 has made poor choicesTe37 has made poor choicesTe37 has made poor choicesTe37 has made poor choicesTe37 has made poor choices
I'm pretty sure those are bbs...older model
Te37 is offline   Reply With Quote
Old 08-22-2012, 03:31 PM   #1500
fliprayzin240sx
18x9.5 +12 all around on 235/40-18s
You should be able to clear anything and everything (suspension wise) up front with this sizing.
CLICK HERE!!!
