Old 11-06-2013, 10:39 AM   #2671
Khoda
Khoda is an unknown quantity at this point
Originally Posted by revat619 View Post
I hope your front fenders are tubbed with that size up front. As far as where to cut on the rear quarter panel, it's just above the body line in an arch like the original fender. There's videos of it all over youtube. Its kinda hard to explain in text.
Front is not tubbed. I was going to, ( still am) BUT it is not needed for some reason. I hammered them in a little and I can make full lock turns it is a tight fit. And I am going to tubb them when I pull the motor out. But as of now it's okay.
And thanks! I'll look on YouTube.
Khoda is offline   Reply With Quote
Old 11-07-2013, 03:12 PM   #2672
killer240
killer240's Avatar
Trader Rating: (24)
killer240 is an unknown quantity at this point
Feedback Score: 24 reviews
Am I able to get away without pulling my S13 rear fenders with 18x10 -17 with S14 rear subframe and adjustable arms? I'm pretty sure I will have to pull it which I don't mind, as long as it's just a slight pull.
REVIEW
killer240 is offline   Reply With Quote
Old 11-07-2013, 03:15 PM   #2673
dudermagee
dudermagee's Avatar
dudermagee is an unknown quantity at this point
anybody know if enkei rpf1's 17x9.5 +18 clear 300zx front calipers?
Originally Posted by DC Dan MAX USA View Post
Don't wuss out on me.
dudermagee is offline   Reply With Quote
Old 11-07-2013, 05:00 PM   #2674
tougefactory
tougefactory's Avatar
tougefactory is a name known to alltougefactory is a name known to alltougefactory is a name known to alltougefactory is a name known to alltougefactory is a name known to alltougefactory is a name known to alltougefactory is a name known to alltougefactory is a name known to alltougefactory is a name known to alltougefactory is a name known to alltougefactory is a name known to all
Yes they do
Performance Parts // Track Prep // Fabrication
**Follow us on Instagram @TFWorks
For all the latest TF★ news visit our blog!!
tougefactory is offline   Reply With Quote
Old 11-07-2013, 10:09 PM   #2675
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Slight pull...no.
RPF1s will clear anything and everything you throw at it brakes wise.
CLICK HERE!!!
Old 11-08-2013, 10:30 AM   #2676
speedgod^s13
speedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond repute
Send a message via AIM to speedgod^s13
S13 hatch with 30mm front overs, and 50mm tatakidashi rear overs.
Front wheels are 18x11 -4 Rear wheels are 18x12 -17
Front and back are R disk. Will I have to run a lot of camber, front and rear? If so, I may just sell these wheels. I'm not a huge fan, of major camber, even if it's not my daily driver.
speedgod^s13 is offline   Reply With Quote
Old 11-08-2013, 11:15 AM   #2677
Jav
Jav is an unknown quantity at this point
Yes, lots and lots of camber and massively stretched tires front and rear.
For reference:
18x10 +12 in the front with 20mm front fenders and 225 tires has about -1.5 degrees of camber
18x12 -8 in the rear with a 275 tire had about -7.5 degrees of camber to fit with those fenders
If you get adjustable RLCA and tuck it in then it'll fit much better.
Jav is offline   Reply With Quote
Old 11-08-2013, 11:37 AM   #2678
speedgod^s13
For reference:
Jeez, that does sound like I'm going to have to run a lot of camber. I do have adjustable rlca. Still, I might just have to sell these wheels.
Old 11-08-2013, 06:39 PM   #2679
ryanclesi
ryanclesi is an unknown quantity at this point
I need some help. Im planning on ordering some ccw lm5 in the specs i want, i want to run around 5* to 6* camber all the way around, the car will be pretty low, im not sure exactly how much but ill say about 3 inches all the way around, i was planning on ordering 17x9.5 0 and 17x10 +6. ive tried searching all over for a 17x9.5 0 in front but i have had no luck seeing a slammed car with those specs. my fenders will only be pinched/rolled, no pull
ryanclesi is offline   Reply With Quote
Old 11-09-2013, 12:04 AM   #2680
Khoda
For reference:
This sounds wrong -7.5? I'm running 18x12.5 with -22 and I'm no where near that kind of camber. I can't even run more then 2 with the rim not hitting the inside of the car.
Old 11-09-2013, 12:57 AM   #2681
revat619
Retired General
revat619's Avatar
revat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfection
Yeah you shouldn't need that much camber with a 50mm over. I mean i know S13s aren't as wide as S14s in the rear, but that sounds way off.
www.Jspec.com
www.SpeedAlliance.com
www.PoweredByMax.net
Instagram: @rjsladerade
revat619 is offline   Reply With Quote
Old 11-09-2013, 04:24 AM   #2682
fliprayzin240sx
On what car? S13 or S14? Chassis makes a big difference since S14s are wider than S13s. On S14, those are cake. On S13s, you'll probably need to pull the fenders some depending on the tire width.
My best advice to you is look around rim tuck and find the closest width/offset setup you can find in there to what you want. Look at the pictures and get an idea how much space they have under the fenders. Jump into the wheel offset calculator and punch in their specs and compare to yours, you should get a rough idea how they'll fit based on those numbers.
CLICK HERE!!!
Old 11-09-2013, 10:28 PM   #2683
ZERTA RACING
ZERTA RACING is an unknown quantity at this point
Okay I have a question for you fitment guys, I want to pick up some Varrstoen TE37 reps for my S14. It will be a kouki front end by the time I get the wheels if that makes a difference I am currently running PBM FLA,RUCA,Toe,and traction rods for adjustability with Fortune auto 500 coils. I am not looking to pull the fenders very much and if possible just roll the lips. I am looking to get 17x9 +12mm in the front and 17x9.5 +12mm in the rears with 235/40/17 tires(with very close to stock camber settings). Would this work? I figured worse case is I could get +22 front and rear and just use spacers to get them close to the fenders but would rather not use spacers.
let me know your thoughts
Thanks!
ZERTA RACING is offline   Reply With Quote
Old 11-10-2013, 01:13 AM   #2684
VNG704
VNG704's Avatar
VNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond repute
With a 235 on a 9" +12 offset wheel, rolled lip only, and very close to stock camber, if you want those settings, you can't go very low up front. It can fit though.
VNG704 is offline   Reply With Quote
Old 11-10-2013, 01:30 AM   #2685
ZERTA RACING
Well If I get a pull front and rear it could go pretty low right? like tucking tire maybe tuck rim?
This is how my car currently sets with 17x7.5 +30 front and 17x8 +33 rear on 235/40-17 tires. With the new wheels I will go a little lower so I am tucking tire maybe one day I will be close to tucking rim lol.
Old 11-11-2013, 12:43 AM   #2686
Zenki B
Zenki B is an unknown quantity at this point
Hi I'm going to be fitting a Rocket Bunny kit on my s14 and I'm wondering what wheel size would fill the fenders nicely. Basically I'll be at this ride height:
Zenki B is offline   Reply With Quote
Old 11-11-2013, 09:04 PM   #2687
fliprayzin240sx
Why cant he go very low up front? There's enough of us running more aggressive wheels up front and low with barely any front fender work. Besides, if you roll the front fenders, you're already pretty much pulling it too since its so thin. You flatten it with the roller and you probably gained 20mm on it.
All depends on your preference. Personally, I prefer 18s, seems to fill the bigger S14 wheel arches better. Up to your preference if you want wide meaty tires or stretched/more aggressive fitment/more poke look. If I want to go wide, I'd go 17x9.5 +18 to +12 with 255/40-17s. If stretched, something similar to what I'm running now. 18x10 +12 225/40-18s and 18x10.5 +12 235/40-18s.
CLICK HERE!!!
Old 11-11-2013, 09:54 PM   #2688
Zenki B
Yeah I definitely want to go wide! The fatter the tires the better
Old 11-14-2013, 04:10 PM   #2689
Steve5405
Steve5405's Avatar
Steve5405 is an unknown quantity at this point
Will 16x7 +25 wheels clear pbm coulovers on s13? Sorry for noob question
Steve5405 is offline   Reply With Quote
Old 11-14-2013, 05:37 PM   #2690
Rich260z
Rich260z is an unknown quantity at this point
Yes, shouldn't' have any problems, unless you run like a 245 or some stupid wide tire. Even then it should be fine.
Rich260z is offline   Reply With Quote
Old 11-14-2013, 07:15 PM   #2691
killakees
killakees is an unknown quantity at this point
17x10 20mm fitment?
i just bought some XXR 526's 17x10 4-100/4-114.3 +20mm and i have a 1991 s13 hatch i just wasnt sure if the front would past my coilovers do i need spacers? and overfenders? i heard the rear will fit with camber but front needs work any opinions?
killakees is offline   Reply With Quote
Old 11-15-2013, 06:38 AM   #2692
I'm Redline
I'm Redline's Avatar
OK, I bought a 95 to use the parts to rebuild my 96 zenki. It came with a set of ICW clones of Gram Light's G-Games in 7x7.5 +42. OE SE's are 6.5 x 16 +40 and sit battle sunk on a normal car.
What size spacers will I need for the front and back to fit these +42's out to the fender lip?
I came here to ask because I *think* 20mm in back and 15mm in front MIGHT work, but n order to buy once and cry not, I defer to the expertise herein. The reason I am using these wheels is they have brand new tires on them and they also have <100 miles on them. They will get me the 4,000 miles while I save up for my Gram Lights and wider tires
My work in progress...
Old 11-15-2013, 02:10 PM   #2693
fliprayzin240sx
Put them on, get a ruler and measure how far the rim is from the fender or to where you want them to sit. Not exactly rocket science.
CLICK HERE!!!
Old 11-15-2013, 02:17 PM   #2694
VNG704
VNG704's Avatar
well, I care about care about rubbing and full use of my turning radius.
Old 11-15-2013, 08:38 PM   #2695
FriknAndre
FriknAndre's Avatar
FriknAndre is an unknown quantity at this point
Question
Originally Posted by CRPS13 View Post
Are you on stock suspension? What chassis do you have? If s13 this is fitment with the 9.75's with a 5mm spacer all around. Will require the spacer in the front to clear coilovers but i used all around because i hate when i see the front sticking out way further with too much camber like a lot of guys on here do. Looks like ass to me.
what size were the rims in this picture? i wanna say theyre 17inch but i looked em up on xxr's site and they only have 4 lugs for 15 -16... Are these 16"s?? Please reply
FriknAndre is offline   Reply With Quote
Old 11-15-2013, 08:54 PM   #2696
vJilly
vJilly's Avatar
vJilly is an unknown quantity at this point
would 17x9 +30 on an s14 clear coilovers and fit fine etc etc
vJilly is offline   Reply With Quote
Old 11-15-2013, 10:01 PM   #2697
Taylor Shinobu
Taylor Shinobu's Avatar
Taylor Shinobu is an unknown quantity at this point
it will not clear the front, you need like +18
Taylor Shinobu is offline   Reply With Quote
Old 11-15-2013, 10:30 PM   #2698
waxball88
waxball88 is an unknown quantity at this point
Hey guys tried googling/search real quick but couldnt find the answer i was looking for but i know this has to have been answered countless times.
I'm going 5 lug and getting a set of 5zigen GN+, my current wheels are 17x9+12, the 5zigens are 17x9.5 +12.
My question is do i need a 10mm(or what size?) spacer in the front to clear my megan coils on my S13? I have 20mm overs up front.
EDIT: I crunched the numbers, if im correct, the wheel should be 6.35mm closer to the coil.
a 9j with +12 offset has 126.3mm behind the hub
a 9.5j +12 has 132.65mm behind the hub
(132.65-126.3) = 6.35mm spacer to have the "same offset/wheel position"
waxball88 is offline   Reply With Quote
Old 11-16-2013, 07:15 AM   #2699
vJilly
vJilly's Avatar
so if i wanted to fit 17x9 +30 battles id need spacers?
Old 11-16-2013, 12:47 PM   #2700
fliprayzin240sx
Depending on what coils, you may or may not need spacers. At most, 5mm will be more than enough to clear most setup. Google search R33 GTR wheels on S14s to get an idea of how they'd look since those rims are that sizing/spec.
Read above...
17s...
CLICK HERE!!!
