02-15-2012, 07:44 PM | #1 |
Trader Rating: (163)
Feedback Score: 163 reviews
*Ask Broadfield*
I spend a LOT of time answering the same questions over and over again... and some of these answers are not short. I simply don't have the time to constantly answer the same questions. I also like helping others out and encourage them to ask questions. So that's what this thread is for. If you have questions about any product I sell, any product I fabricate, my build, my life or what I think of this-or-that, then this is the place. Feel free to ask anything, but I obviously reserve the right to not answer if it's too personal or just plain weird. My goal is to be able to re-route users back to this thread if they ask me a previously answered question in another thread, PM etc. I can just link to the particular post # that has the answer.... done! We can also talk about fabrication techniques and whatnot. Keep in mind, if you have a specific question about a product that I currently have in a vendor for sale thread, then obviously feel free to ask the question in the appropriate thread. Lets do this!
02-15-2012, 11:13 PM | #3 | |
Yes, especially back in the very early 90's. They will never perform as well as a subwoofer in a conventional enclosure setup, but there are obviously several advantages. The big one is no enclosure taking up space... and along with that the price of said enclosure. If you want a free-air sub I would recommend either FI or maybe some of the JL Audio free-air marine subs. The FI stuff is really good for a very reasonable amount of money. No matter which sub is chosen it's very important to make the mounting area is as rigid as possible. Basically you would be making a baffle out of 3/4" MDF and then screwed to the underside of the rear deck if possible. The subs would then mount to the underside of the MDF. You would also want to sound deaden the top of the rear deck and underside before you screw the MDF on. Then use as much power as the sub(s) will handle. |
02-15-2012, 08:19 PM | #4 |
AFC #1
To keep this thread alive and not locked due to being a post whore thread. Lets keep it to his area's of expertise.
Any Random or Off-Topic questions will be deleted. If you aren't asking a question don't post unless you are Broadfield. Abuse will result in punishment. Back to the thread: Have you used any of the free-air subs that are designed to be used in the rear deck? Like the Kicker 10CVT654 for example.
Comments should be taken as Opinions not as Statements of Fact |
02-16-2012, 10:03 AM | #6 | |
My father always taught me to do everything myself. If I didn't know how to do something I would simply teach myself. I believe people are just naturally good at things. For me it's anything to do with cars.... I'm also a pretty good artist. I have won many awards for various pieces of art in my earlier years. I have three bachelors degrees in physics, mathematics and applied computer science. However, I rarely use those in my line of work. So when it comes down to it, I believe I'm naturally good at what I do. On the flip side I'm a horrible cook.
Absolutely not.... track car yes. |
02-16-2012, 08:29 PM | #7 | |
I bought a head unit from you but debating to get another one with Bluetooth. Currently have new infinity kappas in front. But willing to buy new set up.
straights are for fast cars, corners are for fast drivers. |
04-04-2013, 07:26 AM | #8 | |
Sorry, I do not. You could ask Chase. |
02-16-2012, 04:59 AM | #11 |
Do you believe that the weight of a properly installed sound system (trunk-mounted subwoofer included) would make any noticeable difference in the performance of a road car?
02-16-2012, 09:54 AM | #12 |
What are the possibilities to cut down on electric noise/motor noise through audio, for example a CarPC set-up. When the PC is OFF there is high frequencies coming from the speakers in relation to the amount of RPMs the motor is at.
02-16-2012, 05:57 PM | #13 | |||||
Get back to me and we'll go from there. Quote:
Do the doors lock correctly when you hit the lock button on the Python? Quote:
Polishing the cluster glass is a lot more work. I wet sand it inside and out with 1200 grit, then 1500 and finally 2000. I then polish both sides with an air polisher with four different stages of Pinnacle product... #4, #3, #2 and finishing with #1. I charge $50 to polish the glass. Quote:
I use the SEM Color Coat line... mainly Satin Black and Landau Black. They are very close to each other... the Landau Black is a tad bit richer. |
02-16-2012, 07:19 PM | #14 | |
The CarPC itself is a "Net-top" unit. Which for example here's a link to one just for reference. ViewSonic - VOT132 - 2 GB RAM - 1.6 GHz The unit I do not have a separate ground on, only ground I could think of is the ground that runs through the power adapter. [Looks like a laptop adapter] Which I have running to a cigarette lighter power source mounted under the dash. The RCA's I have not attempted to unplug and see. I did run a switch in-between the remote signal wire of the amps so I can turn them off when the PC is off. That was the only thing I could think of to do to get rid of the noise while the PC is off. Would that kind of be my only route to go? |
02-16-2012, 08:08 PM | #15 | ||
PAC SNI-1 - Ground loop isolator Quote:
For the Norton I use the 1 minute and the 5 minute depending on how much working time I need with the product. You will need a special applicator gun that isn't cheap. However, I also used this gun when I did the seam sealer in my engine bay... so it can be used for the dispensing of various types of products. Pictured here if you need the part # of the gun: I actually bought the smoked plexi from Menards... otherwise if your local super hardware store doesn't have it, you can buy it online. Last edited by Broadfield; 02-24-2012 at 05:53 PM.. |
02-16-2012, 08:22 PM | #16 | |
02-16-2012, 08:29 PM | #17 | |
02-17-2012, 07:27 AM | #18 | |
Was just thinking there was some kind of check on a P/N switch and that would cause the issue. Though in the 5spd swap the main P/N switch under the hood is jumped.
'11 M56S '12 QX56 (wife's) |
02-16-2012, 10:07 AM | #19 |
Since I've heard you have alarm knowledge.
A Circuit City installed alarm (Python I believe). Worked fine, then 5speed swap happened. Ever since the doors lock themselves when the car is turned off, as well as locking back 1 second after you hit the unlock button on the key fob. Would assume it was a wire going to the AT shifter or something, but I suck at wiring/electronics.
02-16-2012, 10:47 AM | #20 |
You built a 240sx in the "post your interior thread" I have always wondered about the popup speedometer you had on there. have you ever come across one of the windshield units?
Can't Follow the Rules STATEMENTS make me a Dumb-ass |
02-16-2012, 11:23 AM | #21 |
Trader Rating: (18)
Feedback Score: 18 reviews
I have seen you "refinish" oem hard plastic interior pieces like door handles and stuff. Do you use some kind of polish for that? Mine are beat up and don't look nice at all anymore.
How about polishing the oem plastic cover for the gauge clusters? Do you perform these tasks for money?
WTB: S13 Silvia front pieces Need: Hood, Fenders, Bumper, Headlights + brackets. Have decent pop-up front to trade with oem hood + vis racing carbon fiber hood if interested. |
02-16-2012, 11:46 AM | #22 |
Do you think you can post some pictures of your notched RLCA setup to fit your 11j VSKFs on stock body? And what would be a good sound system setup (4 speakers, a sub and amplifier) for under 300?
02-16-2012, 06:12 PM | #24 |
I PM'd you this yesterday but I'll post it here so there won't be a repeat question...
I was browsing through the interior thread and noticed a digital fuel gauge you did for somebody... http://tehl33tsite.com/240sxdd/help/digifuel.jpg My first question to you is, where can I find a gauge like this that will display fuel in either % remaining or gallons remaining? I tried looking online and can't really find anything. Question #2. I plan on locating it here... http://tehl33tsite.com/240sxdd/help/fuelloc.jpg But I'm not sure if there is enough space on the top region to place a circular gauge since I only want to expose the digital number through that section in form of a rectangle. Any tips or tricks to go about this little project would be much appreciated. Thanks.
02-16-2012, 06:49 PM | #25 | |
Auto Meter I like to mount them behind smoked plexi. I also disassemble the gauge and paint the inside all black. Otherwise you may see some of the white text though the plexi. I have done several setups with various techniques: This first setup is the easiest: This method is much more difficult because I first had to fill in the spot where the OEM switch was: Build pics here: Josh's S13 Cluster, HUD, Center Vent and Cluster Shroud album | Broadfield | Fotki.com, photo and video sharing made easy. Then an AEM air/fuel gauge I did in an STi: Build pics here: Mike Defalco's Vent Gauge STi album | Broadfield | Fotki.com, photo and video sharing made easy. That's entirely up to you.... but good luck |
02-16-2012, 07:52 PM | #26 | |
More questions... What products are you using the fill in the stock bezel? And where can I buy smoked plexiglass?
02-29-2012, 09:19 AM | #27 |
so i am in the process of aquiring an 06-07 sti. want to do the same thing u did to this one. would you be able to do this without the car, just the gauge and vent? or is it nessecary to test fit during the process? if this is possible ill send you a pm for a quote after i actually pick one up. thanks in advance. love your work always impressive!!!
07 ugm STi-07 titan se-99 civic si sold-92 sil coupe-89 240 hatch |
03-01-2012, 08:36 PM | #28 | |||
You know I got your back! Quote:
07-22-2013, 12:24 PM | #29 | |
Thanks. |
07-22-2013, 02:15 PM | #30 |
The duct tape is just an easy way to hold the gauge items together since for that type of install I do away with the bezel.... which holds all of the gauge parts together. In the install I'm posting pictures of below, you can see how the duct tape was used to hold the smoked piece of plexi on there also:
The finished results: i don't have a writeup, but I do have a nice set of pictures that you can follow and see how I did it. In this particular setup I did for a friend's STi, I ground the gauge bezel down so I didn't need to use duct tape. But this install is completely different since I made a "housing" for the AEM wideband gauge to sit in and then attached the housing to the back of the vent trim: |
Tags |
broadfield, toby |
