08-10-2011, 02:49 PM | #7203 |
I did...i think his band or doesnt come here no more lol...but i saw this Nissan Silvia S13 SR20DET 2.5" Turbo Suction Pipe | eBay
anyone tried it? its cheap and looks pretty good...its looks better than the OEM rubber thats falling apart |
08-10-2011, 02:54 PM | #7204 |
Please point me to the right threads.
I have used the search a can't find a good thread talking about bushings. I what to know what bushing to take solid and where it is and going to replace all bushings under S14 1996 the is only used for drifting. Any help will be appreciated thanks. Geoff Hicks
Geoff Hicks |
08-10-2011, 02:56 PM | #7205 |
Just buy all solid arms and http://splparts.com/ bushings. good to go
S.P.P.S. Member #00 **CoUpe LOve** Member #00 |
08-10-2011, 04:22 PM | #7207 |
if you search SPL here
or go to the tech/faq threads you will find what you need. I assume your talking about installs?
08-10-2011, 09:57 PM | #7209 |
I need some kind of help or advice on my situation.
My car cranks but doesn't turn over.. - Once in a while it would spudder a little but wouldn't turn over -If the car sits for a couple of days and I decide to start it up it will turnover but die out asap and wouldn't turn over again. -Car is getting spark -Car is getting fuel, maybe to much dont know why -Timing is fine when I checked. I don't know what could be wrong, someone please help!!! Thanks
91 S13 Ka-t |
08-10-2011, 10:58 PM | #7210 |
so... what happened to the SPL s13 sway bar end links? Megan is the only company i can find (frsport) and fuck them.
Plus who sells quality oversized sway bar bushings, just the rubber/poly bushings for the bracket, cause all i can find is replacement from E.S. and such These are for ARC swaybar if that matters
street dancer. GLEAM |
08-11-2011, 01:01 AM | #7211 |
I currently have 18x10 +25 all around with 225/40's up front and 235/40's in the rears.
What's the most aggressive (like.. hellaflush status) offset I can run with just rolled fenders and some camber on an S14? I won't be pulling my fenders anytime soon :[ |
08-11-2011, 02:56 AM | #7212 |
I was wondering if there are any good car/drift/nissan car shows/events in the month of october? I know this probly sounds dumb.... but Im from the NW and going to be driving my s14 home from Louisiana so I wanted to see if there was any big events on this side of the states around that time I could check out on the way home
08-11-2011, 03:06 AM | #7213 | |
Starter ??? Battery ??? |
08-11-2011, 02:23 PM | #7214 |
Is it possible for a BAD fuel pump to pump the right amount of Psi when you first start the car in the morning (cause its cold) then when you rev it a few times the fuel psi drops ??
08-11-2011, 02:45 PM | #7215 | |
Trader Rating: (58)
Feedback Score: 58 reviews
Now if it looses PSI and continues to drop, then obviously look into a new pump and or an FPR
08-11-2011, 03:13 PM | #7216 | |
Also, i can feel the FPR lines like knocking, as if its pumping hard. |
08-11-2011, 03:25 PM | #7217 |
Rebuilt the starter and brand new battery
91 S13 Ka-t |
08-11-2011, 08:19 PM | #7223 |
i just got aspec blast pipes but before i put them on i wanna know what i'll need for it to not be ridiculously loud cause i live in cali and cops are assholes especially for loud exhausts. my goal is for it too sound really deep. and i want to do 2.5 in all the way through and delete the cat so my question is what kind of resonator or muffler would i need or anything of the sort. thanks
08-12-2011, 01:50 PM | #7224 |
Does anyone know if I can use hicas spindles on a non-hicas car? I've done some research on it and found that the hicas ones have a balljoint where the toe arms would connect while the non hicas ones have a bushing there. I've heard I can use them but it seems kinda weird...
08-12-2011, 01:56 PM | #7225 | |
08-12-2011, 08:47 PM | #7226 |
Trader Rating: (60)
Feedback Score: 60 reviews
Ok I gotta get a smog test for my s14 I know I can pass it runs clean I have everything stock. my friend said u cant have a check engine light on when u get a smog is that true the reason it's on cause of the knock censer is not working. My car is not knocking it's just the stupid censer, any ways I live in California
Want to roll fenders, custom gauge pod pm me |
08-12-2011, 08:50 PM | #7227 | |
08-12-2011, 09:05 PM | #7228 |
Trader Rating: (60)
Really? I had ran a test it's defenaly just the knock censer I didn't think it had anything to do with smog
08-12-2011, 11:01 PM | #7229 |
I've gotten different answers on this.
Can I just get adjustable Rucas to adjust my camber without getting toe rods As well? I mean I want my toe as close to 0 as possible. Just need to dial in a little more camber |
08-12-2011, 11:11 PM | #7230 |
I think it depends how low you are. I just bought adjustable RUCAs. I couldn't really adjust it more than a few mm's off the stock length RUCA while still making it fit, because the toe rod was holding the knuckle from being in position. You may as well buy toe rods too if you want as close to 0* of toe as possible.
Censor*
