04-27-2007, 11:51 PM | #1 |
2 way differential whine around 45mph... Anybody else?
I've got a 2 way cusco type MZ diff that will whine from about 45-60mph.
It goes away but then makes a louder whining sound around 80mph. I put some shims around the diff bushings to make them nice and tight... but I dont think that alone will create a whine. The guy that had the diff before me claims he never had any problems with whining from the diff at all... I have dropped this diff 3 different times now and tried bolting it on different everytime with no change. I also have stock suspension besides a ST sway bar and subfame collars. Any help is appreciated. Thanks |
04-28-2007, 01:26 AM | #6 |
so you went from a thicker oil to a thinner? imo i think you might want to run the thicker stuff again, i'm no expert but process of elimination would come into play before spending a bunch on a new diff
04-28-2007, 02:00 AM | #9 |
R.I.P. Aya, always love
Trader Rating: (215)
Feedback Score: 215 reviews
if you don't fix it, it will get worse and go boom. At which point you will wind up with a possible jacked ring and pinion and chunks of metal floating in your diff case. Which is not good for the clutch pack.
"Having a lot of tracks on a song is like putting stickers on a car to get more horsepower" New Video https://www.youtube.com/watch?v=uebV1OnbRsw Buy my mounts! http://zilvia.net/f/sale-items/51531...ns-mounts.html http://zilvia.net/f/tech-talk/317539...e-mouts-6.html |
04-28-2007, 02:46 AM | #10 |
^exactly why I want to figure out what it is.... the whining itself I can take i just dont want to ruin my $800 diff.
Im gona have a chat with the mechanics at my work tomorrow and see what they say Thanks for the replys |
04-28-2007, 07:10 AM | #11 |
I had the same thing happen to mine. The tooth gap was not correct. There is supposed to be a specific amount of "play" the diff is suppose to have. You should be able to turn the input shaft (driveshaft) and the output shafts (axles) and there will be or should be some play before the teeth catch. It its off by even the smallest of margins, your diff will whine. I would check that if i were you.
Scott |
04-28-2007, 10:39 PM | #13 |
I was gona do what Dousan suggested but I talked to some mechanics today and they said more than likely it is because of what Scottie is describing.... the diff is not configured correctly inside the housing and the teeth are slightly off....
Im gona drop the diff again and put some dye on the teeth to see how the mating pattern looks.... Then Im going to try calling some off road shops to see if they can help me since the transmission guy at my work will be busy for a while. Thanks again for the help! |
04-29-2007, 10:59 AM | #14 |
So, you bought a diff, tossed it in, and didn't check your backlash?
Uuuggghhh Scottie is right. Since Scottie is right, Dousan is starting to be right being as how you are in the process of destroying your gear. You need a dial indicator and the dye to get your diff the way it needs to be. To adjust the backlash, you'll need shims. To either raise or lower the pinion untill it's where it needs to be. Being as how you are hearing a whining, it's more than likely too tight. So you might not need to buy any shims. Either way, drive the car only to the shop.
05-01-2007, 05:31 PM | #17 |
LOL.
That backlash issue will kill the diff. All you need is right sized shims and someone who understands diffs. |
