![]() Join Date: Apr 2011
![]() Feedback Score: 19 reviews
(*)(*)sr20det help!!(*)(*)
I noticed my SR RedTop had the wrong O2 sensor
-Instead of the Titania (Skinny) o2, it had a Fat o2 ![]() So i got the correct skinny o2, but wiring looks off;;; ![]() [[[UPDATE]]]]....................................... Correct wiring for 62 ecu and skinny o2 is; harness------skinny o2 Brown--------red White---------black Black---------white
. Last edited by OutlawLui; 03-29-2013 at 10:40 AM.. |
#6 | |
yea but these are all guessing.... 1st. thread says that the White on sensor is signal 2nd thread says that the black is the sensor signal.. Thanks anyway
#7 | |
![]() Join Date: Jun 2007
![]() Feedback Score: 13 reviews
I had a hard time looking for this info as well. I'll check my wiring whenever i get a chance and post pics. |
#10 | |
On the red top sr its harness------skinny o2 Brown--------red White---------black Black---------white The brown harness wire is the 12v sourse *on the skinny o2 sensor the black wire is the signal wire and white is ground
. Last edited by OutlawLui; 03-29-2013 at 10:37 AM.. |
#11 |
![]() Join Date: Jul 2005
heres what I usually do. Go to pep boys and look through the oxygen sensor boxes until you find all the 1-wire oxygen sensors. Buy the cheapest one, usually $12 or $14.
Now, you know exactly which wire is the signal since there is only 1 wire. Install using the single signal wire and never worry about this again. If you put a voltmeter on the wire, it will flip from 0.005Volt - 0.985+Volt when working properly. |
#12 | |
02 sensor, sr20det, tech, wiring |
