Old 11-11-2020, 09:39 AM   #1
PoorMans180SX
PoorMans180SX's Avatar
Tremec TKX conversions
If you aren't aware, Tremec just released it's TKX transmission, which is the evolution of the T-5/TKO500/TKO600 line. It now has triple cone synchros and a stiffer case, extending the usable shift RPM to 8000. This seems very promising as a no-compromise strong 5-speed box.
https://www.tremec.com/menu.php?m=183
Let's list some advantages here:
1. Lighter than a Z33/T56 box by 30lbs
2. Rated for 600lb-ft of torque
3. Massive aftermarket support
4. Available basically everywhere
5. Will be in production/service for years
6. Removable bellhousing
7. Mechanical or electronic speedometer drive
8. Compact
9. Shares bellhousing pattern with G-force dogboxes/others
10. Close ratio gearset
Adapting these should be relatively easy, with an adapter plate and a bellhousing from your preferred engine (auto SR/KA/RB, R154 JZ), a custom pilot bushing and a 26-spline clutch disk in your required diameter.
Here is a example of a G-force GSR to SR20 adapter:
I do believe they would need an extended shifter based on how the TKO fits in an S13:
Retail is $2,795 for the gearbox.
Anyone else think this sounds pretty good? I think it's something to talk about at least.
http://www.youtube.com/watch?v=EOqkR3K-Oz8
Old 11-12-2020, 12:51 PM   #2
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
very cool, but outside of pro/semipro level drifting, most 240 owners ain't gonna have $2800 just for a trans (and then more for the bellhousing, clutch, driveshaft, etc) when people bitch and moan about a $800 cd009 or $500 z32 trans.
always nice to have more options available in the market tho!!!
is there a listing of available gearsets? or do you just specify what ratios you want when you order?
Old 11-13-2020, 04:22 AM   #3
PoorMans180SX
Yeah that makes sense, Just seems like people are spending just as much on the conversion for those other transmissions that the cost wouldn't be so different for a proven transmission.
Yeah if you click on that first link they're under the "technical specifications" tab on the tremec website.
Old 11-13-2020, 06:24 AM   #4
jr_ss
I think the price point isn?t bad for a new trans. Most CDX or RS5R30A transmissions are in between 2-3k anyhow. However, factoring in the cost of a conversion kit, is going to put this out of reach for most S-chassis owners.
I think most guys that are using a TKO trans have them face plated anyway for the power they are making.
At the end of the day, It?s always nice to have options and I?m sure someone will product a kit for it.
jr_ss is online now   Reply With Quote
Old 11-13-2020, 12:14 PM   #5
PoorMans180SX
Yeah, that makes sense. Just seems like with the cost of all the conversion parts, it won't end up being that much different.
They don't plate them for strength, they faceplate them so they'll shift at the RPM they're running. This trans fixes those issues.
Old 11-14-2020, 03:38 PM   #6
jr_ss
I guess power and rpm go hand in hand? If they are spinning those motors up, they are churning out some power. But I hear you!
Old 10-20-2022, 07:46 PM   #7
PoorMans180SX
Bellhousing to bolt a tkx to an SR.
https://vernierbell.com/products
Old 10-21-2022, 05:07 AM   #8
tuzzio
tuzzio's Avatar
I'm going to inquire to them if they have plans for making one that'll bolt to a KA. Realistically the RB25 one is close enough.
Old 10-21-2022, 06:29 AM   #9
AKADriver
AKADriver's Avatar
Given that used T56s have been going for TKO money for years, it's great. This isn't a "for everyone" transmission, but I think it's a no brainer for LS swap cars, compared to the typical combination of used transmissions and adapter kits.
Old 10-21-2022, 11:23 AM   #10
tuzzio
tuzzio's Avatar
In all honesty, im surprised the Sr / KA market isn't all over the TKO. One offering has almost IDENTICAL gearing to the factory 5 speed.
Old 10-21-2022, 10:29 PM   #11
PoorMans180SX
I doubt most people know the bellhousing exits. It's immensely stronger than the 30A, and has an off the shelf shifter from sikky that doesn't require all the mods that a CD or JK series transmission does. People are still cheap though, and finding a cheap JK41 trans is still possible if you can wait around for a deal.
Between this and the Turbolamik ZF 8hp70, we don't have to worry about finding strong transmissions anymore.
https://pmcmotorsport-shop.com/produ...8HP50-B58.html
Old 10-25-2022, 09:27 AM   #12
splitfire
splitfire is an unknown quantity at this point
Isn't ZF 8hp70 an A/T?
splitfire is offline   Reply With Quote
Old 10-25-2022, 10:40 AM   #13
AKADriver
AKADriver's Avatar
It is. Looks like there's a healthy aftermarket for standalone controllers for it because it's such a strong, efficient, fast-shifting gearbox though.
Surprisingly people are even adapting them to go behind LS motors, is the ZF 8HP70 that much better than the GM 6L80/90 or 8L90? I guess the smaller BMW bellhousing would give you more clearance in typical import car swap applications than the huge Chevy bellhousing pattern.
Old 10-27-2022, 12:36 PM   #14
PoorMans180SX
Yes, and Yes.
The standalone controllers allow you to shift it sequentially, and even use a clutch-by-wire setup. We're getting a little off topic here, but this is a pretty cool topic too, so whatev, hah.
http://www.youtube.com/watch?v=eleIShRysVM
Old 10-28-2022, 09:41 AM   #15
TheRealSy90
TheRealSy90's Avatar
The largest issue, hurdle, and pain in the ass is getting an SR clutch with LS transmission shaft splines. Especially for people like myself who prefer to use brands like osgiken etc.
Such a good signature.
Old 11-18-2023, 03:12 PM   #16
Sr20-Vert
Sr20-Vert's Avatar
Sr20-Vert is a well-known jackass
I think a t56 to sr20 should be here I am not a fan of my cd00a to notchy and third gear is grinding we need someone to make this kit my car would be insane with a t56 already mazworx stage 3 ve head and garret g35-1050 106 ar cd00a
Sr20-Vert is offline   Reply With Quote
Old 11-19-2023, 01:26 PM   #17
silviaks2nr
silviaks2nr's Avatar
t56 magnum is unparraleled for performance and shift feel. No other choice IMO if you're going 6spd. It's worth the huge hole it burns in your wallet. I think the tko only realy make sense for upgrading older mustangs and GM's which came with T5... Not a lot of point to put it behind any import engines.
'98 240sx 5spd
kouki 2jz t56 swap build
Old 04-24-2024, 02:10 AM   #18
Rosdikolaus58
Rosdikolaus58 is an unknown quantity at this point
I suppose power cannacraftcorner and RPM go hand in hand, right? If those motors are spinning up, they're definitely generating pureplantpleasures some power. But I understand your point!
Rosdikolaus58 is offline   Reply With Quote
Old 04-28-2024, 02:21 PM   #19
StorminMatt
StorminMatt is an unknown quantity at this point
The problem with using this transmission for LS swaps is fitment. Most people doing LS swaps are going to be using one of the many available swap kits. And all of these kits are designed around the T56. Using something else (like the TKX) is going to require a custom transmission crossmember and dealing with a shifter that is in the wrong location. Given that a TKX already costs close to $3000, it just makes sense to spend just a few hundred more and get a Magnum F. This way, you get a transmission that actually fits using off the shelf part and doesn?t require hacking your transmission tunnel to deal with a shifter in the wrong location. Oh, and you also get an extra gear.
StorminMatt is offline   Reply With Quote
Old 04-28-2024, 07:18 PM   #20
PoorMans180SX
Yeah duh. The thread wasn't about using this with LS swaps, but putting it behind SRs, KAs, JZs etc.
Old 04-29-2024, 02:55 PM   #21
StorminMatt
Maybe not. But he DID say that it was a ‘no brainer’ for LS swaps. Also, there could be issues with using this transmission with other engines (such as SRs, KAs, and JZs) since upgrades using T56-based transmissions are so well-established. I couldn’t help but notice the cut transmission tunnel posted above.
This isn’t something I would want to do to MY S13. A longer transmission such as the aforementioned T56 Magnum F, would bring the shifter back and possibly align it with the factory hole.
Not to say that the TKX is a bad transmission, of course. It would be a better choice when you want a five speed (rather than six speed) and in applications that either can’t fit a T56 or where a lighter weight transmission is advantageous. However, as a T56 substitute, it is an awkward fit that isn’t a whole lot cheaper than a new Magnum.
