Old 02-11-2006, 05:54 PM   #1
SlideStyle180
SlideStyle180's Avatar
SlideStyle180 is making a name for him/her selfSlideStyle180 is making a name for him/her self
Send a message via ICQ to SlideStyle180
SR 240sx ECU codes 34 & 55 on SR20DET Redtop
A while ago I had some exhaust leak problems coming from the manifold, very common . This is on an 89 240sx w/ Red Top SR20. Before sealing that bad boy up, I disconnected the positive side of the battery. As soon I was done, I reconnected the battery and everything sounded just fine. Idle'd normally. As soon as I get it going, the motor starts to shake... I know, most of you would think that this would be cause by the engine mounts. Well last time I checked, they were fine and everything bolted down tightly. This distinct smell of burning gas is circulating through the air. I tried driving it normally but it feels a lot slower than usual. When I accelerate the car sounds like a WRX to be honest =P I pulled some ECU codes just now and the numbers read 34 and 55 = "34 Detonation (Knock) sensor + 55 Normal engine management system operation is indicated" Don't know where to locate the knock sensor to be honest. This earthquake in my car sucks when I drive it to work. Any info would be appreciated.
SlideStyle180 is offline   Reply With Quote
Old 02-11-2006, 06:15 PM   #2
stevesr20
stevesr20 is an unknown quantity at this point
check and make sure the wga arm is not off the manifold... Do you have a boost gage?
------03' 400whp solar yellow srt-4 (R.I.P.)
------05' white srt-4 [email protected] (she is missed)
------04' HEMI quad cab 4x4 (daily driver)
------91' hatch (swapped sr20 det)
------Afghanistan (04'-05')
stevesr20 is offline   Reply With Quote
Old 02-11-2006, 07:42 PM   #3
SlideStyle180
To be honest the actuator isnt off the turbo so I wouldn't really consider it being the problem. I would think that most of the vibrating would start before it. Regardless, it still idles fine, doesnt die out. Unfortunately I don't have a boost gauge.... =X maybe i should get one right away
Old 02-11-2006, 08:02 PM   #4
stevesr20
not sure about the vibrating, but i know when my wga arm fell off it sounded very diffrent, kinda like a wrx... the wga arm was off the little tab conecting to the manifold it opens and closes the door inside the manifold.... Was just hopeing for a easy solution for ya. good luck.
