Old 02-12-2006, 11:20 PM   #1
dasalnt
dasalnt is a well-known jackass
sr20det problem - no power from 3-5k rpm
I've recently started having a problem with my redtop sr20det. When it first started, the car would drive fine until around 3k rpm and then it would feel like it wasn't gaining anymore power but my boost would continue to go up to 7lbs. I just changed out my spark plugs today and it helped a little bit. Instead of not feeling a power increase after 3k rpm, i dont feel any power increase after 3k rpm but once it reaches around 5k rpm i can feel the power come on again. Hopefully someone has experienced a problem like this before. If anyone lives in the la/oc area and is willing to help diagnose/fix the problem i would also be willing to pay, thanks!
dasalnt is offline   Reply With Quote
Old 02-13-2006, 08:08 PM   #2
dasalnt
hopefully someone can chime in and help out!
Old 02-13-2006, 09:02 PM   #3
xeros
xeros is an unknown quantity at this point
Sounds like a vacuum hose problem. Maybe even a sensor? But it definitely sounds like a vacuum hose leak some where. That or a coupler came loose. Did you hear nay odd noises fromunder the hood? Like an unusually loud swooshing sound?
xeros is offline   Reply With Quote
Old 02-16-2006, 12:52 AM   #4
SR20d2fourT
SR20d2fourT's Avatar
SR20d2fourT has a spectacular aura aboutSR20d2fourT has a spectacular aura aboutSR20d2fourT has a spectacular aura aboutSR20d2fourT has a spectacular aura aboutSR20d2fourT has a spectacular aura aboutSR20d2fourT has a spectacular aura about
vacuum, boost leaks, crap ass coil packs....my car was exactly the same way. It would loose around 3k and get back at around 5k...deja vu! haha well yea those were the problems...
SR20d2fourT is offline   Reply With Quote
Old 02-16-2006, 09:40 AM   #5
dasalnt
i'll definitely go thru the leaks again, i've checked and tightened down all the clamps but i'll check again. I haven't checked the coil packs so i'll have to find a faq on how to do it. Thanks
Old 02-16-2006, 10:40 AM   #6
spdfreek0o
spdfreek0o will become famous soon enoughspdfreek0o will become famous soon enoughspdfreek0o will become famous soon enough
Send a message via AIM to spdfreek0o
kinda thread stealing... but, my friend works at a dealership and someone brought in a turbo pt cruiser. It kinda has the same problem, turbo spools fine but no power. The boost gauge is also reading an insane amount of boost(24psi) for an OEM turbo. I was thinking boost leak but would a boost leak cause a boost gauge to read inaccurate? Any one got any ideas?
spdfreek0o is offline   Reply With Quote
Old 02-20-2006, 05:58 PM   #7
jalam321
jalam321 is an unknown quantity at this point
i have a similiar problem also. Mine hesitates a little between 2000-3000 rpm. I'm not sure what the problem is either.
jalam321 is offline   Reply With Quote
Old 02-21-2006, 01:33 AM   #8
daryl337
daryl337's Avatar
daryl337 has a spectacular aura aboutdaryl337 has a spectacular aura aboutdaryl337 has a spectacular aura aboutdaryl337 has a spectacular aura aboutdaryl337 has a spectacular aura aboutdaryl337 has a spectacular aura about
Send a message via MSN to daryl337
CAS maybe? Sometimes they crap out at higher rpm's.
daryl337 is offline   Reply With Quote
Old 02-21-2006, 02:25 AM   #9
Slip&Sliden 240
Slip&Sliden 240's Avatar
Slip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfection
Did you check for codes yet? My buddies sr was running crappy.We checked codes, and got a knock sensor code. We swapped it with my spare SR and it runs like a champ now.
Slip&Sliden 240 is offline   Reply With Quote
