Old 02-21-2006, 12:30 AM   #1
sw20>>s14
sw20>>s14's Avatar
nothing inside works!!! electrical advice needed!!!
so, i havent driven my car in about two weeks total and it always had a tendency to drain the battery...after the first week of sitting, i pulled my car from my space across the street, into my driveway; about 25 feet...no jump needed...idled for about one minute and shut it off...
since then, i havent turned it over for about another week...finally today, i wanted to get an alignment so i jumped it...started fine, but nothing inside the car worked! meaning the whole cluster, interior dome light, moonroof, map lights, radio, windows...everything, except for the hvac didnt work...i also noticed that after being jumped, it idled as if it was warmed up (low idle indicated by sound; the tach was out)...it hasnt been started in over a week, the idle should have been a lot higher or at least in open loop...
my car keeps on dying, thats the alternator, but what is causing nothing inside to work properly? i checked all the fuses and they seem to be fine...the only thing i can think of is that when i was jumping it, i wasnt paying attention and reversed the + and - on the source (my camry)...would reverse polarity mess anything up on my car? sorry, but i suck at electrical diagnostics...any help would be greatly appreciated...
sw20>>s14 is offline   Reply With Quote
Old 02-21-2006, 01:06 AM   #2
daryl337
daryl337's Avatar
daryl337 has a spectacular aura aboutdaryl337 has a spectacular aura aboutdaryl337 has a spectacular aura aboutdaryl337 has a spectacular aura aboutdaryl337 has a spectacular aura aboutdaryl337 has a spectacular aura about
Send a message via MSN to daryl337
reversing polarities is always bad... but you said that your fuses were fine? Check for a short in the wiring... or maybe there is a fuse you forgot to check. Also, try ecu.
daryl337 is offline   Reply With Quote
Old 02-21-2006, 01:15 AM   #3
Maeda
Maeda's Avatar
Maeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura about
Relays son.
Inside the car means it's either a fuse or a relay, or else you did something reallllly bad and have to go smelling wires.
Jumping the car does a number on your fuses. Some might not break but be weak and not conducting well.
Theres another scenario.
If you aren't driving the car around you aint charging that battery for SHIT.
Idling doesn't count.
Throttle until you're at 2000 RPMs.
Hold for 10 minutes.
Interior electronics crap out at about 9v.
Weak battery
No REAL charging taking place
= bing bing low voltage.
You win!
NEXT time you jump the car, drive it for a good half hour and then when you park it...
Take off the negative!
Maeda is offline   Reply With Quote
Old 03-08-2006, 04:37 PM   #4
sw20>>s14
sw20>>s14's Avatar
i realize that you have to drive in order to charge...i may want to add that i didnt crank it while it had swapped terminals...i just saw a spark and took it off...
now, i talked to a few nissan techs and they said it definitely wasnt the relays...they suggested that it may be the "link fuse" on the positive terminal...but i cant seem to i.d. what they were describing...does anyone have experience testing or replacing this "link fuse"...
i have no problem driving w/o the ammenities of interior options for a while, but i definitely do not want to mess the odometer reading...is the odometer electrical or mechanical? because if it still ticks, ill drive it...im assuming its electrical due to the sensors...just checking...
my car still isnt operating up to par and the moral of the story is: DO NOT ATTEMPT TO JUMP A CAR WHILE VERBALLY FENDING OFF AN ERRATIC MOTHER!
Old 03-08-2006, 07:14 PM   #5
RedtopTech
RedtopTech's Avatar
RedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud of
dude your an idiot. lots of weird things happen when your battery voltage is low_ you asked for help and you got the right answer then you ignore it
RedtopTech is offline   Reply With Quote
Old 03-09-2006, 02:08 AM   #6
slider2828
slider2828's Avatar
Ok man... check your main fuse box. Fusible links are the large SQUARE fuses. Check them very closely cause they can have a hair line break. Secondly, there is a fuse box inside your car and a huge one in fact. It is in the kick panel of the driver side. IMHO nissan techs suck sorry if I am offending anyone.
Old 03-09-2006, 02:54 PM   #7
sw20>>s14
sw20>>s14's Avatar
it may sound like it, but i did not rule out maeda's suggestion...i just havent had time to charge the battery so i havent tried it...but please excuse me for not living life dependent on what is obviously the easiest solution...i like to be prepared, hence asking for further info on what else it could be...what the hell is wrong with gathering all the possible solutions and then executing? people have different ways of doing things, deal with it you douche
yeah, i realize that there is a fuse box inside the car...i just wasnt familiar with the term fusible links and couldnt find them...now i have a better understanding of where they are, thanks
Old 03-09-2006, 05:00 PM   #8
NemeGuero
No more nissan.
NemeGuero's Avatar
You're pink. And it shows why.
Old 03-09-2006, 05:30 PM   #9
BoNyG515
BoNyG515's Avatar
BoNyG515 is an unknown quantity at this point
Send a message via AIM to BoNyG515
I can probably swing by and check it out...if you need the help
"Sugar we're going down swinging..."
BoNyG515 is offline   Reply With Quote
Old 03-09-2006, 05:40 PM   #10
Nizzan4u2nv
Nizzan4u2nv's Avatar
Nizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura about
Send a message via AIM to Nizzan4u2nv
Ive done that once. Turns out the ALT fuse was blown.
Nizzan4u2nv is offline   Reply With Quote
