Old 02-21-2006, 01:06 AM   #1
dog3gtr
dog3gtr is an unknown quantity at this point
Has anyone have changed Rack and Pinion BUSHING?
My S14's rack and pinion bushings are gone...
So i've ordered them from Nissan..
There are two bushings for it.
So, has anyone have done it b4?
Is it hard to change? i'm getting scared..
If you've done in b4, u have any tips?
Hope it's like changing sway bar bushings..
dog3gtr is offline   Reply With Quote
Old 02-21-2006, 09:17 AM   #2
red240
red240 is a jewel in the roughred240 is a jewel in the roughred240 is a jewel in the roughred240 is a jewel in the roughred240 is a jewel in the roughred240 is a jewel in the roughred240 is a jewel in the rough
I did on my s13 but I had the engine out=no problem, not sure about with it in
Shouldn't be to bad.
red240 is offline   Reply With Quote
Old 02-21-2006, 09:22 AM   #3
Dousan_PG
Dousan_PG's Avatar
super easy to do
i hvae ES ones in now
but i have some rad YANACK solid ones going in when i pull the motor next month
Aaron
Pink GodziRa
Old 02-21-2006, 09:35 AM   #4
1Via!
1Via!'s Avatar
1Via! is a name known to all1Via! is a name known to all1Via! is a name known to all1Via! is a name known to all1Via! is a name known to all1Via! is a name known to all1Via! is a name known to all1Via! is a name known to all1Via! is a name known to all1Via! is a name known to all1Via! is a name known to all
Send a message via AIM to 1Via!
I have ES rack bushings as well. I replaced them with the engine in the car with old, low, stock engine mounts. It sucked. Ass. All in all it took me about an hour, give or take 15 minutes. Its fairly easy to do, just don't do it with the engine in the car, or be prepared to have a friend to lend a helping hand.
These bushings tighten up steering and help turn in a bit, especially noticable at higher speeds.
1Via! is offline   Reply With Quote
Old 02-21-2006, 10:46 AM   #5
dog3gtr
Are you guys saying I should lift the engine up?
That doesn't sound easy..
Also, where can I get Energy Suspension steering rack bushings?
I can't find it in some of websites that I usually go..
Old 02-21-2006, 10:50 AM   #6
1Via!
1Via!'s Avatar
i think splparts.com has them and a shitload of other places. Google "energy suspension."
you could use a jack with a block of wood under the oilpan to help give you some clearance. Its not that hard, just takes a while to get the top collar on the steering column input side down to a point where you can thread the bolt on correctly. I believe i used some c-clamps for this.
Old 02-21-2006, 11:10 AM   #7
sdtouge
sdtouge can only hope to improve
Originally Posted by Dousan_PG
super easy to do
details on these solid ones?
sdtouge is offline   Reply With Quote
Old 02-21-2006, 11:38 AM   #8
aznpoopy
aznpoopy's Avatar
doing it that way is a good way to develop an oil pan leak. (ask me how i know)
if you're going to use a jack to raise the engine, jack it from the tranny bellhousing area.
aznpoopy is offline   Reply With Quote
Old 02-21-2006, 11:45 AM   #9
Shawn_of_the_Dead
Shawn_of_the_Dead's Avatar
Shawn_of_the_Dead is on a distinguished road
I second that. Never jack from under your oil pan....even a dent can cause a major decrease in oil pressure.
I will need to do this soon too. I was looking at getting the ones from spl. I think I need a new rack too...mine is leaking and steering wheel shakes at certain speeds.
'93 Coupe BlkTp-SR
'07 Chevy HHR - DD
Shawn_of_the_Dead is offline   Reply With Quote
Old 02-21-2006, 12:55 PM   #10
SirWarrior
SirWarrior is an unknown quantity at this point
i got the bushings and will be doing it later this year (when its warm) along with rest of my suspension.
92 FastBack - Project
98 SE - Daily Driver
SirWarrior is offline   Reply With Quote
Old 02-21-2006, 06:06 PM   #11
DJPimpFlex
DJPimpFlex's Avatar
Trader Rating: (115)
DJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond repute
Feedback Score: 115 reviews
Send a message via AIM to DJPimpFlex Send a message via MSN to DJPimpFlex
you dont need to lift the engine. Just unbolt the rack from the crossmember and the steering shaft. You dont even really need to unbolt the steering shaft, but it makes it easier. Took me and citizen about 30min.
DJPimpFlex is offline   Reply With Quote
Old 02-21-2006, 07:23 PM   #12
projectRDM
projectRDM's Avatar
18 minutes from start to finish. It's stupid easy to do.
And if you can't find ES bushings, maybe you should try www.energysuspension.com. I bet they have some. Just note that they're made for the S13 rack and the round one is too thin to secure the S14 rack. You'll either need a Nismo unit or a piece of garden hose, split open and laid around it to secure it.
Old 02-22-2006, 12:30 AM   #13
Dousan_PG
Dousan_PG's Avatar
they arent rubber
they are aluminum?
solid. no flex at all. no play.
straight from jland.
Aaron
Pink GodziRa
Old 02-22-2006, 12:45 AM   #14
FRpilot
FRpilot's Avatar
the energy suspension bushings i got are insanely hard to install. i gave up. i think you have to cut/trim them when installing.
FRpilot is offline   Reply With Quote
Old 02-22-2006, 01:31 AM   #15
1Via!
1Via!'s Avatar
No cutting is required... Keep at it and use some C-clamps or vise grips to help getting the top collars down over the bushings. Thats where I ran into trouble.
Old 02-22-2006, 10:34 PM   #16
sdtouge
they arent rubber
they are aluminum?
ya i ment where can i get some? that seems sick. im trying to have the only bushings on my car the sway bar d ones. lol. how much wrere they?
