Old 03-01-2006, 11:14 AM   #1
d-oom
d-oom is a well-known jackass
tranny removal
hey, i searched but i didnt find anything that helped.
i bought a parts car, and am trying to drop the tranny down.
ive disconnected the sensors, and unbolted the wierd peice on the driveshaft near the tranny. ive taken the screws off the mid-joint of the driveshaft in hopes of it coming apart. grrr
do i need to unbolt the driveshaft from the differential?
plz help
d-oom is offline   Reply With Quote
Old 03-01-2006, 11:25 AM   #2
aznpoopy
aznpoopy's Avatar
whoa whoa whoa
the tranny is secured in multiple places. there are also things secured to the tranny.
you only need to take out the front half of the driveshaft, between the carrier bearing the transmission. there are four bolts to attach it to the center bearing thinger. unbolt em. then, slide it out of the tranny towards the back of the car. you do not need to unbolt it from the differential. it is a two piece driveshaft. to drop the tranny you only need to remove the front piece.
as for dropping the tranny:
- sensors unplug. goes without saying. unbolt the slave cylinder from the tranny. hang it up somewhere. unbolt the exhaust bracket from the tranny mount bracket. remove the driveshaft.
- it is bolted to the engine. you need to take those bolts off.
- it is secured by a crossmember (in which resides the transmission mount) unbolt the crossmember, while supporting the tranny with a jack.
once all of the above is loose, slide the tranny out towards the back of the car, while supporting it with a jack. be careful taking it out. if you get tired pulling, and rest it for a bit, you might accidentally put stress on the input shaft, fuxoring the input shaft bearing.
aznpoopy is offline   Reply With Quote
Old 03-01-2006, 12:04 PM   #3
d-oom
i have the slave cylinder unbolted and hanging, and the exhaust bracket. the front section of the driveshaft was also completely unbolted. hmmm i guess it just needs a little force to come out.
thanks for the quick reply
Old 03-01-2006, 01:43 PM   #4
SirWarrior
SirWarrior is an unknown quantity at this point
dont forget the shifter and all that good stuff on the inside of the cabin
92 FastBack - Project
98 SE - Daily Driver
SirWarrior is offline   Reply With Quote
Old 03-01-2006, 01:47 PM   #5
1Via!
1Via!'s Avatar
1Via! is a name known to all1Via! is a name known to all1Via! is a name known to all1Via! is a name known to all1Via! is a name known to all1Via! is a name known to all1Via! is a name known to all1Via! is a name known to all1Via! is a name known to all1Via! is a name known to all1Via! is a name known to all
Send a message via AIM to 1Via!
Yeah, shifter.
And a tranny jack is key.
1Via! is offline   Reply With Quote
Old 03-01-2006, 02:24 PM   #6
Muzzy
Muzzy's Avatar
Muzzy is an unknown quantity at this point
Send a message via AIM to Muzzy Send a message via Yahoo to Muzzy
hey..i have yet to see u mention that u removed teh tranny bolts that go into the block. if u have removed all of the tranny bolts and tranny crossmember it should slide off. if not use a pry bar in that little hole at teh bottom of teh tranny where teh tranny and motor mate. that should help it slide off.
buy my tranny jack...adapter(fits in standard floor jack)..its worthless to me.
<===muscles
lemme have a dollar
Muzzy is offline   Reply With Quote
Old 03-01-2006, 03:00 PM   #7
aznpoopy
aznpoopy's Avatar
i totally forgot about that. good call.
Old 03-01-2006, 05:42 PM   #8
d-oom
i got it out.
the mid joint in the driveshaft way rusted and BENT. lol. the only problem was getting to the top bolt on the block. the tranny was suprisingly light.
this is the first time ive ever attempted something like this, and it was a piece of cake. i cant wait to start rebuilding my engine. i love this shit
oh ya, my jackstands tipped over and i almost died, luckly i left my jack under the car haha.....ya
Old 03-02-2006, 12:40 PM   #9
Muzzy
Muzzy's Avatar
how the hell did your jackstands tip over????
lemme have a dollar
Old 03-02-2006, 01:01 PM   #10
d-oom
it was probably the fact that im having to do all this on gravel, but other than that...i dont know
Old 03-03-2006, 08:34 AM   #11
Slidin240Wayz
Slidin240Wayz's Avatar
yea, d-oom as a name does not help either.
Slidin240Wayz is offline   Reply With Quote
Old 03-08-2006, 01:41 AM   #12
180sExy
180sExy's Avatar
Location: Your mother's bedroom!!! So go tell your dad!
180sExy has a reputation beyond repute180sExy has a reputation beyond repute180sExy has a reputation beyond repute180sExy has a reputation beyond repute180sExy has a reputation beyond repute180sExy has a reputation beyond repute180sExy has a reputation beyond repute180sExy has a reputation beyond repute180sExy has a reputation beyond repute180sExy has a reputation beyond repute180sExy has a reputation beyond repute
Send a message via AIM to 180sExy
how long did it take you???? i have too take mine out too
"We have chosen hope over fear."
180sExy is offline   Reply With Quote
Old 03-08-2006, 05:48 AM   #13
pr240sx
pr240sx is an unknown quantity at this point
Engine in car, 2 hours tops!
Engine outside, 15 mins including oil drain.
pr240sx is offline   Reply With Quote
