Old 03-05-2006, 03:36 PM   #1
Realnez
Realnez's Avatar
Realnez is an unknown quantity at this point
Send a message via MSN to Realnez
Wiring DOHC to SOHC dash plug
Ok im doing a SOHC to DOHC swap and I have never done this before lol. Ok so I got the harness all wired up and ready to go but Im having a problem. The DOHC dash plug does not fit the SOHC one. Someone on here told me I need to cut the SOHC plug and plug that in then cut the DOHC and wire it up. What I need to know now is which wires do I need to wire up? Do I need to splice wires? there will be wires left, so those are for nothing? Let me know ASAP
"You have a SOHC chassis receiving a DOHC engine, correct?
The DOHC dash plug does not plug into the SOHC dash harness, that's probably why they cut it off since it's not needed. Tahe the SOHC harness, cut the dash plug off of it and wire it into the DOHC harness, that's what you'd have to do anyway for the swap, same as an SR, RB, CA, etc. Use the colors as written up in any wiring guide for the above engines. You don't need the rest.
orange- start signal
yellow/green- VSS
yellow/red- tach
blue/black- water temp
blue/green- A/C
black- ground?
Realnez is offline   Reply With Quote
Old 03-06-2006, 08:57 AM   #2
projectRDM
projectRDM's Avatar
Bingo. Everything else are dead leads.
Old 03-06-2006, 02:54 PM   #3
Realnez
Realnez's Avatar
so 10 wires are for nothing?
Old 03-06-2006, 03:28 PM   #4
projectRDM
projectRDM's Avatar
If you're going to keep questioning it, why do you even bother to ask in the first place? Do you want to hear a different answer?
Old 03-06-2006, 03:56 PM   #5
Realnez
Realnez's Avatar
haha sorry man. It just seems weird that theres 10 wires there for nothing lol
Old 03-06-2006, 03:59 PM   #6
mrmephistopheles
mrmephistopheles's Avatar
It's for Consult shit which you don't NEED.
Originally Posted by PHLIP
Old 03-06-2006, 07:12 PM   #7
NIK90s13
NIK90s13's Avatar
NIK90s13 is making a name for him/her selfNIK90s13 is making a name for him/her self
I made a pig tail of the sohc male end to the female dohc, so not to HACK up anything! Good luck on the swap!
NIK90s13 is offline   Reply With Quote
