Old 03-06-2006, 12:07 AM   #1
sr20player
sr20player's Avatar
sr20player is an unknown quantity at this point
Power Steering sensor
Just wondering what will happen if I dont hook up the power steering sensor. will it hurt at all? does it regulate fluid flow?
sr20player is offline   Reply With Quote
Old 03-06-2006, 12:12 AM   #2
nrg
nrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud of
Send a message via AIM to nrg
it wont do much. it's just to tell the ecu the pressure to keep the idle up. something like that.
driftingisgay.com
nrg is offline   Reply With Quote
Old 03-06-2006, 01:29 AM   #3
sblack13
sblack13's Avatar
sblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud of
at idle your idle will flucuate with the plug in when you turn the wheel. Without it plugged in it won't do anything. It's just a pressure sensor. It won't hurt at all, most sr swaps don't have them plugged in.
sblack13 is offline   Reply With Quote
Old 03-06-2006, 08:54 AM   #4
projectRDM
projectRDM's Avatar
Close. It idles up the engine at full lock only. If you never turn the wheel to full lock you'll never notice it. If you do, you'll see the idle dip about 100rpm. Either way it's nothing, don't worry about it.
