Old 03-07-2006, 12:41 PM   #1
sciamop
sciamop's Avatar
sciamop is making a name for him/her selfsciamop is making a name for him/her self
FICD Valve Compatibility
I'm nearing the end of a 1998 KA24DE into a 1991 S13 swap.
I swapped all of the components from the 91 onto the 98 engine. While I was dropping the engine into the car, I smashed the FICD valve sensor.
Luckily I kept the 98 KA intake manifold. The 98 FICD looks identical to the 91 FICD except for a different outer plug type. If I manage to plug the 98 FICD into the 91 harness (splice, etc), will it work the same as the 91 unit?
What's a FICD valve? Fast Idle Control Dingdong. It raises the idle when the AC is turned on. It is located at the lower back of the intake manifold. It is a 2" long hex-shaped piece of metal with a plastic plug for the harness at one end and a plunger at the other.
Todd
91 SE-R
93 Coupe
http://www.whistlehog.com/blog
sciamop is offline   Reply With Quote
