Old 03-08-2006, 09:45 PM   #1
fcdrifer17
fcdrifer17 is an unknown quantity at this point
smoke outa dash/egn fuse keeps blowing.
hey i was messing around under the hood and painted some stuff like the valve cover and some sheet metel... i pulled some ground cable that was right infront of the radiator... thinkin it was for my se fog lights, which where already out... could this be why my ignition fuse keeps blowing? i went inside to start the car and smoke started comming from under the dash. now everytime i put the ignition on ON the fuse blows.. i dont know where the blk ground wire connected to... any imput would be appriciated thanks.
fcdrifer17 is offline   Reply With Quote
Old 03-08-2006, 09:55 PM   #2
Nizzan4u2nv
Nizzan4u2nv's Avatar
Nizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura about
Send a message via AIM to Nizzan4u2nv
Sounds like youre shorting out something. Find out what the wire you pulled was, first.
Nizzan4u2nv is offline   Reply With Quote
Old 03-08-2006, 11:39 PM   #3
OdessaS13
OdessaS13's Avatar
OdessaS13 is a jewel in the roughOdessaS13 is a jewel in the roughOdessaS13 is a jewel in the roughOdessaS13 is a jewel in the roughOdessaS13 is a jewel in the roughOdessaS13 is a jewel in the roughOdessaS13 is a jewel in the rough
Send a message via ICQ to OdessaS13
well, you know you pulled a ground cable, so did you re-attach it? and yes no ground = blown fuse. also if you re-attached the ground cable on top of the painted whatever then it will make shitty contact and maybe no ground. One end of the ground will go to chassy (unpainted metal part) the other side...well you have to remember that yourself.
btw judging by your sn do you own s chassy or a fc and i think you mispelled drifter
post some pics of the g wire and the area were you pulled it from
GL
1992 240sx 5 spd. - Sold / 02 Maxima Se
OdessaS13 is offline   Reply With Quote
Old 03-08-2006, 11:45 PM   #4
fcdrifer17
ok got it fixed... my remote wire from my stereo was touching ground... so yea.. i know i spelled drifter wrong.. alot of simular s.ns were taken so i had to make my own.. i guess that ground wire wasnt neccessary after all.. thanks for your imput guys.
