Old 03-12-2006, 10:12 PM   #1
Dante319
Dante319 is an unknown quantity at this point
Intake Manifold Secondary Butterflies
I am going through the process of removing all my emissions from the intake manifold, when I came across these. Now should I remove the actuator and leave the plates inside the runners, because I am guessing as long as they dont have a vacum line they'll stay open right. Please correct me if I'm wrong and tell me what I should do.
Thanks people
I'm gonna show you that a mobile suit has its limits my friend, especially when you are up against the Red Comet
Dante319 is offline   Reply With Quote
Old 03-12-2006, 10:14 PM   #2
projectRDM
projectRDM's Avatar
Remove the plates too, or even better remove the actuator rod as well. It's simple, and there's plenty of info on it if you use the search function.
Old 03-12-2006, 10:34 PM   #3
ledzeppelin240
ledzeppelin240's Avatar
ledzeppelin240 is a well-known jackass
If I remember right they are closed untill vacuum is applied. All you need is some anaerobic sealer and a small oil gallery plug to plug the hole left when the actuator is removed. You take off the screws holding the plates onto the rod and a screw in the center then pull the rod out.
Anyway, no drug, not even alcohol, causes the fundamental ills of society. If we're looking for the source of our troubles, we shouldn't test people for drugs, we should test them for stupidity, ignorance, greed and love of power.
Looking for: JDM S13 OEM Sideskirts
ledzeppelin240 is offline   Reply With Quote
Old 03-14-2006, 07:19 PM   #4
Dante319
KA
Let me explain myself again. I know how to remove them, I just forgot to do so and now it's kinda late. I did remove the rest of the emissions stuff, now the question is if I plug a vacum source to the actuator of these butterflies from the Intake Plenum is it gonna operate normal?
Thanks
Old 03-15-2006, 05:49 AM   #5
pr240sx
pr240sx is an unknown quantity at this point
They are normally open.
Just remove the plug or the vac source and thats it.
pr240sx is offline   Reply With Quote
Old 03-15-2006, 06:29 AM   #6
neverlift
neverlift is not welcome here anymoreneverlift is not welcome here anymoreneverlift is not welcome here anymoreneverlift is not welcome here anymoreneverlift is not welcome here anymoreneverlift is not welcome here anymoreneverlift is not welcome here anymoreneverlift is not welcome here anymoreneverlift is not welcome here anymoreneverlift is not welcome here anymoreneverlift is not welcome here anymore
pr240sx said it best, its what I did,work's fine
derp derp
neverlift is offline   Reply With Quote
Old 03-15-2006, 04:44 PM   #7
Dante319
Many Thanks guys
