4 day and 4 nights and it's finally finished! It was the hardest job I've ever done, I called tech support at least 15 times.
anyway, it doesnt work so I'm still checking the connections. Wires had to be ran from engine bay, ecu, ignition harness, radio, door pin wire, and door interior (actuator)... I hope I didn't mess up the ECU.. The wires are everywhere!
Anyone buying this alarm, I do suggest to do it yourself tho. You'll learn a lot about the eletrical systems in your car. You can rewire stuff around like cigarette liter working after key out. Just take your time and check every connection.
I'll tell you if it's a good buy after it works! It does have more functions than windows xp tho.. the manual is a fuckin text book
K. Lu
