Old 03-25-2006, 01:06 AM   #1
SiI40sx
SiI40sx is close to perfectionSiI40sx is close to perfectionSiI40sx is close to perfectionSiI40sx is close to perfectionSiI40sx is close to perfectionSiI40sx is close to perfectionSiI40sx is close to perfectionSiI40sx is close to perfectionSiI40sx is close to perfectionSiI40sx is close to perfectionSiI40sx is close to perfection
Send a message via AIM to SiI40sx
Basic S13 Wiring for SR Harness ONLY
Ok I dont know if anyone else is in the same boat with me but this is going to be my first time doing a SR harness for a 240sx S13 swapping a SR20DET Redtop. Im planning on using heavythrottle for reference on doing the harness but I keep hearing from other sources that Heavythrottle has incomplete information. This is what I know
KA Harness has 2 plugs at the end
SR Harness has 3 plugs at the end
Re-wire the SR Harness so it matches the KA's two plugs (make the male "sr" match the female "stock plugs")
Extend the P/S Wires and the MAF Wires
In the SR FAQ theres also this as reference:
Originally Posted by SequenceGarage
Just posting some things I did not see in this thread, however it may be in the links. Plz delete if overlapping.
SR = Block
20 = 2.0L Displacement
D = DOHC
E = Fuel Injected
T = Single Turbocharger
2.0L DOHC Turbo
Turbo Type: T25G
Compressor A/R: 0.80
Injector Size: 370cc
Bore x Stroke: 86.0mm x 86.0mm
Displacement: 1998cc
Performance: SR20DET:
Power (ps): 205@ 6000 rpm
Torque (kgm): 28.0@ 4000 rpm
Compression Ratio: 8.5:1
Speed Limiter:180 Kmh -112 mph
Stock Boost: 7 psi
ECU: 62 (redtop) OR E5 (blacktop). 63 (automatic) will also work.
MAFS: 89-90 240sx mafs works.
Rev Limit: 7500rpm (no need to really go over 7200)
Gear Ratios:
Gear Ratios - Manual Transmission
1st 3.321
2nd 1.902
3rd 1.308
4th 1.000
5th 0.759
Reverse 3.382
Final 4.083
S13 ECU Pinout (thanks to CM510.com)
Classic battery area wiring diagram from heavy throttle:
BTW whats F10 F8 E10 E9??
From my understanding thats all I know. Is this how you guys did your harness? Everywhere on zilvia and zilvia affliates have incomplete information about doing the harness. Mods can you please sticky this thread and have it for reference for all zilvians doing basic DIY S13 SR Swaps. Hope this thread has a future. Thanks
SiI40sx is offline   Reply With Quote
