Old 03-25-2006, 09:25 AM   #1
Boostin240sx
Boostin240sx is an unknown quantity at this point
Tire size
Currently I have 17x8 +35 with 235/45 17 all the way around. I am replacing the rears with 17x9 +20 and buying all new tires. I'm considering 255/40 17 rear and 235/45 front. Any suggestions for getting different sizes?
Boostin240sx is offline   Reply With Quote
Old 03-25-2006, 10:14 AM   #2
ryangreg
ryangreg can only hope to improve
What kinda tires? Different brands will bulge more or less at the sidewalls, making it difficult to gauge what size tire you want. Your going for a nice fitment im assuming. Perhaps a tiny stretch?
ryangreg is offline   Reply With Quote
Old 03-25-2006, 11:15 AM   #3
1mns13
1mns13's Avatar
1mns13 is an unknown quantity at this point
How much torque are you making? How much understeer is acceptable to you? That will help us help you.
www.the-nissan-240sx.com
1mns13 is offline   Reply With Quote
Old 03-25-2006, 01:53 PM   #4
SRPILOT
SRPILOT is an unknown quantity at this point
Do you also want max traction or is this for drifting.
SRPILOT is offline   Reply With Quote
Old 03-26-2006, 12:01 AM   #5
Boostin240sx
As for the brand I was considering kumho spt or yoko ES100s. I would like to have good traction but not be a pig if I want to take it to the track.
Old 03-26-2006, 12:42 AM   #6
SpeedMonkeyInc
SpeedMonkeyInc's Avatar
SpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond repute
235/40s will be better. The 45s are too tall IMO
SpeedMonkeyInc is offline   Reply With Quote
Old 03-26-2006, 01:43 AM   #7
revat619
Retired General
revat619's Avatar
revat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfection
^^^ Word.
On the 9s, run a 235/40 and on the 8's, run a 225/45.
www.Jspec.com
www.SpeedAlliance.com
www.PoweredByMax.net
Instagram: @rjsladerade
revat619 is offline   Reply With Quote
Old 03-26-2006, 12:29 PM   #8
Boostin240sx
235/40 on a 9? The point of wide rims are wider tires, I think Speedy was referring to 235/40 in the front.
Old 03-26-2006, 12:47 PM   #9
SpeedMonkeyInc
You are right, wider rims for wider tires. Up to a point however. One of the benefits of a wider wheel is to be able to run a wider tire at the same time as gaining a stiffer sidewall. Too wide a tire will negate that benefit.
I run 235/40 on 9s all around. Perfect. Very square sidewall with my Cooper Zeon tires. Other brands will sit a little bit differently. Such as the ES100s I have in back right now, sit a little bit pulled.
Revat's size suggestion is SPOT on in my opinion.
Old 03-26-2006, 08:44 PM   #10
EchoOfSilence
EchoOfSilence's Avatar
EchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant future
Send a message via AIM to EchoOfSilence
245/40 wouldn't hurt. but i also don't understand 235 on the rears if you want to maximize traction.
Boostin240sx, is this on an s14?
Petition Nissan to Make the IDx on http://IDxClub.co !
EchoOfSilence is offline   Reply With Quote
Old 03-27-2006, 07:47 AM   #11
Boostin240sx
Yeah it is on an S14.
