Old 03-29-2006, 02:56 PM   #1
Sirk
Sirk is an unknown quantity at this point
Dyno tune results, tell me what you think!
Dynoed 229whp 250ftlb's @ 15psi.
Mods:
Stock T25 Redtop
3"in exhaust
Blitz ECU
HKS acutuator
Safc-2
FMIC, Walbro, etc
That's all I can think of that would have any affect on performance. Car holds 15lbs from 4-6k then by 7.5 its down to 8lbs. I've checked all my vacuum lines, moved the wastegate line from the throttlebody to the compressor housing. Felt much better, but boost still falls off. Going to replace the coupler on the compressor housing and tap it with an agpturbo quicktap for my signal. Is the rapid boost loss normal on stock turbos? Anyone experienced this and fixed it? Should I just get an MBC and will everything be fine?
Sirk is offline   Reply With Quote
Old 03-29-2006, 04:05 PM   #2
BEISSEN
BEISSEN is a well-known jackass
Send a message via Yahoo to BEISSEN
Mods:
Stock turbo
3"in exhaust
Blitz ECU
HKS acutuator
Safc-2
FMIC, Walbro, etc
That's all I can think of that would have any affect on performance. Car holds 15lbs from 4-6k then by 7.5 its down to 8lbs. I've check all my vac lines, moved the waste line from the throttlebody to the compressor housing. Felt much better, but boost still falls off. Going to replace the coupler on the compressor housing and tap it with an agpturbo quicktap for my signal. Is the rapid boost loss normal on stock turbos? Anyone experienced this and fixed it? Should I just get an MBC and will everything be fine?
Uhh is this a SR I assume if you say stock turbo.But what motor redtop s13/s14 or black top s14 etc.We need a bit more info but if stock S14 Notch top Is say not bad.
BEISSEN is offline   Reply With Quote
Old 03-29-2006, 05:53 PM   #3
Sirk
Sorry its a 93 Redtop SR.
Old 03-29-2006, 10:33 PM   #4
SpeedMonkeyInc
SpeedMonkeyInc's Avatar
SpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond repute
From what I have read stock T25s can't hold higher boost pressures at higher rpms. Thats pretty normal I think. I don't know what that happens though.
SpeedMonkeyInc is offline   Reply With Quote
Old 03-30-2006, 10:28 AM   #5
boosteds13
boosteds13's Avatar
boosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really nice
You are right. They can't hold boost til redline. And yeah, its normal for a T25 to do that.
"A CA? WTF is that? You shoulda got an SR yo."
View my vBPicGallery!
boosteds13 is offline   Reply With Quote
Old 03-30-2006, 12:08 AM   #6
<3MyRiceRocKet
<3MyRiceRocKet is an unknown quantity at this point
thats just about right...whats the highest grade gas you guys get in Georgia? Pee water hurts in Cali.
<3MyRiceRocKet is offline   Reply With Quote
Old 03-30-2006, 07:03 AM   #7
Sirk
93 octane, ohhh yeah. lol
Old 03-30-2006, 10:47 AM   #8
Neejay
Neejay's Avatar
Neejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfection
Nice. Where did you get your engine and where did you get the swap done? (I'm in Clayton county).
Neejay is offline   Reply With Quote
Old 03-30-2006, 11:59 AM   #9
Sirk
Motor from jarco, swap and tune by turbo dave
Old 03-31-2006, 06:53 PM   #10
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Get an AVCR and its possible to hit 250whp with wut you have.
CLICK HERE!!!
Old 03-31-2006, 08:17 PM   #11
koukidough
koukidough's Avatar
koukidough is an unknown quantity at this point
thats pretty decent...get a better turbo, mafs and injector that way you can take advantage of that fmic =)
1997 Nissan S14 SE Redtop SR20DET @12psi
1999 Honda Civic Hatch EK9 N/A b16a2 (SOLD)
koukidough is offline   Reply With Quote
Old 04-01-2006, 06:22 PM   #12
Sirk
I need to track down why my car feels so slow now, lol. It feels like its dead now. I can't figure it out. Car felt amazing the day after it was dynoed and now it just seems like it gets slower each day. It is sooo aggravating.
Old 04-01-2006, 08:48 PM   #13
Edgar
Edgar's Avatar
Edgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfection
Send a message via AIM to Edgar
leaking any boost somewhere?
Drift Indy
Edgar is offline   Reply With Quote
Old 04-02-2006, 06:53 AM   #14
BEISSEN
Like Edgar said check for Boost leaks.Also check and see if everything is connected still you might have knocked something loose or fried never know.
