Old 03-29-2006, 10:21 PM   #1
grudge
grudge is on the path to ruingrudge is on the path to ruin
5lug swap writeup
did a search and found that the writeups are not active any longer.
can anyone, or does anyone know where else to find an active source for these instructions?
http://www.teamhpi.org/5lug.php
http://www.nissansilvia.co.nz/tech/5stud/5stud.htm
grudge is offline   Reply With Quote
Old 03-29-2006, 10:50 PM   #2
nrg
nrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud of
Send a message via AIM to nrg
http://www.tougefriends.com/media/ht...ame=News&sid=9
driftingisgay.com
nrg is offline   Reply With Quote
Old 03-30-2006, 01:09 AM   #3
mrmephistopheles
mrmephistopheles's Avatar
http://www.freewebs.com/abuseFrozen.htm
That's what I get. Looks like tougefriends was hacked.
Originally Posted by PHLIP
Old 03-30-2006, 03:19 AM   #4
BEISSEN
BEISSEN is a well-known jackass
Send a message via Yahoo to BEISSEN
What happend to the Archive's that we use to have here? I looke for several things and its gone. If we can get another Archive made like we had a few years ago then we can always have the info we need.
BEISSEN is offline   Reply With Quote
Old 03-30-2006, 10:51 AM   #5
Neejay
Neejay's Avatar
Neejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfection
I had to stop the page from loading, and I got the page to display regularly.
Neejay is offline   Reply With Quote
Old 03-30-2006, 12:42 PM   #6
projectRDM
projectRDM's Avatar
Or you could just follow this writeup:
1) Remove old hubs
2) Install new hubs
If you seriously need a writeup to install hubs then maybe you should quit eating glue for a few days.
Old 03-30-2006, 01:24 PM   #7
grudge
1) Remove old hubs
2) Install new hubs
really?
Old 03-30-2006, 09:24 PM   #8
Irukandji
Originally Posted by grudge
really?
yeah... really... Hub swap is as simple as it gets.
Irukandji is offline   Reply With Quote
Old 03-30-2006, 09:38 PM   #9
infinitexsound
infinitexsound's Avatar
infinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond repute
its alot harder to change ur spark plugs..
S14 TrackSlut coming to a raceway near you...
510 TimeAttack on its way...
infinitexsound is offline   Reply With Quote
Old 03-30-2006, 09:53 PM   #10
Neejay
Neejay's Avatar
Damn...I didnt know that LOL I was thinking it was a lot more to it than that, but then again maybe I was confusing that with a 300zx brake swap.
Maybe some day I will do a 5-lug swap with some s14 SE alloys...hmm...
Old 03-31-2006, 08:55 AM   #11
grudge
man, all i asked for was an active source. thanks to those who at least had the decency to try and help out. to the rest who were just negative,
Old 03-31-2006, 09:03 AM   #12
g6civcx
g6civcx's Avatar
Just find an FSM. If you're using replacement hubs they bolt in in place of your stock 4-lug hubs.
Old 03-31-2006, 11:39 AM   #13
grudge
thanks. i just wanted to see other peoples writeup on it, cause someone told me i need to replace my spindles. but i knew i didn't need to, but i just wanted to be 100% sure.
Old 03-31-2006, 11:45 AM   #14
g6civcx
g6civcx's Avatar
Just get Peak hubs. They bolt in just like your regular hubs. No need to swap anything else. Just get brakes and wheels and you're set.
Old 03-31-2006, 11:52 AM   #15
aznpoopy
aznpoopy's Avatar
here's another one.
http://importnut.net/300zxbrakeswap.htm#5-lug
hub swap using stock s14 parts on a s13 is not just swapping hubs. i'd also suggest you get aftermarket hubs. just to save yourself a slight headache.
aznpoopy is offline   Reply With Quote
Old 03-31-2006, 12:00 PM   #16
JesusFreakDrifter
JesusFreakDrifter's Avatar
JesusFreakDrifter has much to be proud ofJesusFreakDrifter has much to be proud ofJesusFreakDrifter has much to be proud ofJesusFreakDrifter has much to be proud ofJesusFreakDrifter has much to be proud ofJesusFreakDrifter has much to be proud ofJesusFreakDrifter has much to be proud ofJesusFreakDrifter has much to be proud ofJesusFreakDrifter has much to be proud ofJesusFreakDrifter has much to be proud ofJesusFreakDrifter has much to be proud of
hey i know that everyone does the z32 brake swap but what about the z31 does that work?
JesusFreakDrifter is offline   Reply With Quote
Old 03-31-2006, 02:20 PM   #17
importnut
importnut's Avatar
importnut is an unknown quantity at this point
I don't think it's so much an issue of a Z31 swap working, I don't think they are anything special. Plus, I think they are 4lug.
The front hub swap on an S14 is as simple as it can get. Get S14 5-lug hubs, and put them on. The rear is not as simple because you need to remove most of the links on the upright, or remove the upright altogether to get access to the 4 bolts on the back. That and you need a monster socket (36mm iirc) to get the axle out.
The S13 front conversion can be done with aftermarket units that equip it with bearings that work on the S13 spindles. In all honest, it's going to be cheaper, and easier in the long run to use aftermarket hubs. PDM racing sells them.
-Alex S.
"What about the twinkie?"
importnut is offline   Reply With Quote
Old 03-31-2006, 08:49 PM   #18
AWDtoyota
AWDtoyota is just really niceAWDtoyota is just really niceAWDtoyota is just really niceAWDtoyota is just really niceAWDtoyota is just really niceAWDtoyota is just really niceAWDtoyota is just really niceAWDtoyota is just really niceAWDtoyota is just really nice
....and if you run s14 componets up front on an s13 what modifications are needed?
I've read that you have to drill out the strut to fit the s14 spindle bolts....is this correct? And will s14 lower control arms work on an s13 in the front?
AWDtoyota is offline   Reply With Quote
Old 03-31-2006, 09:38 PM   #19
axiomatik
axiomatik's Avatar
to use s14 hubs in fron you need s14 spindle, and yes, the strut bolts are larger on the s14. s14 LCA's will work, it will widen your track slightly
Old 04-01-2006, 07:29 PM   #20
AWDtoyota
Thank you, but one last thing...
I don't have the s14 strut bolts, and I also don't want to drill out my struts. To avoid drilling and being able to use my s13 strut bolts, I can use the strut spacers that PDM sells...right? I'm pretty sure this is what I have to do, i just want to be sure...
Oh and here's a link to the spacers I was speaking of (till the bottom of page):http://www.pdm-racing.com/products/5boltconversion.html
