Old 04-02-2006, 04:02 AM   #1
project_240sx
project_240sx is an unknown quantity at this point
power steering?
hey so this is what happend i was driving taking soem corners. then after a while i had no more power steering. my car is a 92. i looked under my hood and there was power steering fluid all over around the exhaust mani. what does this mean? bad lines? broken pump? or belt? thanks.
project_240sx is offline   Reply With Quote
Old 04-02-2006, 04:03 AM   #2
project_240sx
sorry btw its a s13 black top.
Old 04-02-2006, 09:09 AM   #3
NIK90s13
NIK90s13's Avatar
NIK90s13 is making a name for him/her selfNIK90s13 is making a name for him/her self
Best case, check the low pressure line from the resevour, It may have blown off. You could have blown the high pressire line, Most likely you did'nt blow the pump(guessing) It can go bad, even loose a seal, but I havent heard of one rupsuring, Ect. Can you pinpoint the leak? Clean the oil off, and check where it is leaking from, then we can figure out what the problem is!! Good luck!
NIK90s13 is offline   Reply With Quote
Old 04-02-2006, 09:44 AM   #4
krustindumm
krustindumm's Avatar
krustindumm is an unknown quantity at this point
you can see it better than we can
ASE Master Technician
krustindumm is offline   Reply With Quote
Old 04-02-2006, 06:44 PM   #5
mjjstang
mjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to behold
Send a message via AIM to mjjstang
for real!! clean it up really good get all the excess fluids cleaned up, then a leak will most likely start to form, around the area of crackage.
mjjstang is offline   Reply With Quote
Old 04-02-2006, 08:07 PM   #6
project_240sx
the leak is coming from the top of the pump. that big bolt that is ontop is leaking pretty badly, can this be fixed by tightening it?
Old 04-02-2006, 08:34 PM   #7
SimpleSexy180
probably going to have to replace some lines.
SimpleSexy180 is offline   Reply With Quote
Old 04-02-2006, 08:45 PM   #8
g2ic02
g2ic02 is an unknown quantity at this point
Send a message via AIM to g2ic02 Send a message via MSN to g2ic02
there are 2 copper crush washers on that banjo bolt. One between the head of the bolt and the fitting on the line, the other between the fitting and the pump. It sounds to me like one of these is either missing or that bolt may need to tightened up. It is also possible that there is a leak in the line close to the pump. That particular line is the high pressure line. You will have to clean it up, add more power steering fluid( i believe in the 240's it is actually auto transmission fluid) *wear safety glasses* Start the vehicle and inspect the fitting and line. It is under a lot of pressure so you should notice exactly where it is leaking from. If you don't notice it right away have some one turn the wheels side to side. Once you fix the problem. Add power steering fluid. Lift the car and turn the wheels slowly full lock to full lock. Do this until all the air is out of the system.
g2ic02 is offline   Reply With Quote
