Old 04-02-2006, 12:50 PM   #1
JXN
JXN is an unknown quantity at this point
crazy scary pulling LCA problem?
Check this out,
Step on the brake the car pulls to the left. Let go of the brakes, it pulls to the right.
This is hella scary.
I think its the LCA bushing or tension rods. Or both.
Anyone got any insight in this problem?
JXN is offline   Reply With Quote
Old 04-02-2006, 01:00 PM   #2
CaoBoY
CaoBoY is making a name for him/her selfCaoBoY is making a name for him/her self
brake master cylinder bad. and you need an alignment.
pulling outta the game:
http://www.zilvia.net/f/showthread.p...wpost&t=119867
parting out, just let me know.
CaoBoY is offline   Reply With Quote
Old 04-02-2006, 05:53 PM   #3
JXN
::ROFL::...bad master cyl? you gotta be kinding me. You are wrong.
I have to admit that my toe is off in the rear, but that shouldnt cause the abnormal pull.
It definitely feels like the wheel is moving backwards when im braking and moving forward/back into place when brake is released.
Old 04-02-2006, 06:35 PM   #4
krustindumm
krustindumm's Avatar
krustindumm is an unknown quantity at this point
jack it up and pry on shit, replace whatever moves.
ASE Master Technician
krustindumm is offline   Reply With Quote
Old 04-02-2006, 11:16 PM   #5
JXN
haha thats a good idea! I may just try that.
Old 04-03-2006, 12:28 AM   #6
m0rex
m0rex's Avatar
m0rex is on a distinguished road
It can be your lower control arm ball joint thats loose it happen to me once and it messed the ball joint up real badly. Check if all the bolts are tight.
m0rex is offline   Reply With Quote
Old 04-03-2006, 07:11 AM   #7
Neejay
Neejay's Avatar
Neejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfection
Check your steering rack bushings.
Neejay is offline   Reply With Quote
Old 04-03-2006, 08:23 AM   #8
projectRDM
projectRDM's Avatar
If the wheel is moving fore/aft, it's the tension rod bushing. If it's pulling in/out it's either the tie rod end or the balljoint.
Old 04-03-2006, 09:02 AM   #9
Dunkee
Dunkee's Avatar
Dunkee is a glorious beacon of lightDunkee is a glorious beacon of lightDunkee is a glorious beacon of lightDunkee is a glorious beacon of lightDunkee is a glorious beacon of lightDunkee is a glorious beacon of lightDunkee is a glorious beacon of lightDunkee is a glorious beacon of lightDunkee is a glorious beacon of lightDunkee is a glorious beacon of lightDunkee is a glorious beacon of light
My car had a similar prob...was the ball joints. Maybe you got a kink in your brake lines or caliper siezed?
96 SE http://www.cardomain.com/ride/255381
Dunkee is offline   Reply With Quote
Old 04-03-2006, 09:32 AM   #10
Neejay
Neejay's Avatar
Just curious, how does bad ball joints cause the steering wheel/rack to go from side to side? (Not saying you guys are wrong, I really just dont understand)
This would be a good thing, because Im in the middle of replacing my lca AND adding urethane steering rack bushings.
Old 04-03-2006, 09:53 AM   #11
Dunkee
Dunkee's Avatar
When it's busted or worn out it wobbles which will give you sporadic steering and brake pull. I noticed it when I changed my tierods.
Old 04-03-2006, 11:04 AM   #12
JXN
thanks for the info guys! I'll let you guys know once ive checked it out.
Old 04-04-2006, 01:53 AM   #13
JXN
ok heres whats happening. The bushing is bad, mostly. Took it to an under body specialist. My assumptions were right. The bushing is bad, the wheel is moving back and forth while braking and release of brake. It moves the steeering wheel.
Its hella scary. Whats the canadian site that sells whiteline stuff and control arms?
Im trying to find them, pdm something...fergot.
Old 04-04-2006, 01:56 AM   #14
EchoOfSilence
EchoOfSilence's Avatar
EchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant future
Send a message via AIM to EchoOfSilence
http://www.pdm-racing.com/products/pdmcontrolarms.html
Petition Nissan to Make the IDx on http://IDxClub.co !
EchoOfSilence is offline   Reply With Quote
Old 04-04-2006, 11:47 AM   #15
JXN
thanks, but i was looking for 2 hours and have already found it.
I ordered it right away lol.
