Old 04-02-2006, 09:34 PM   #1
d-oom
d-oom is a well-known jackass
Clutch problem!!
well im having a problem with my clutch. i just put a new pressure plate, t/o bearing/ and disk in. i did not replace the pilot bearing like an idiot.
anyways. it drove fine for 2 days, then i started getting this loud whining noise whenever the clutch started to engage. sometimes it does it, sometimes it doesnt.
i can tell when its going to do it. when i press the clutch in, i hear a grinding sound exactly like a throwout bearing. i dont know....
let me rephrase myself so theres no confusion. sometimes when i press the clutch down, no noise, and it drives good.
usually when i press the clutch down, and there is a grinding sound like a t/o bearing. when the clutch engages, it whines and doesnt drive so good.
please help!
d-oom is offline   Reply With Quote
Old 04-03-2006, 07:58 PM   #2
NIK90s13
NIK90s13's Avatar
NIK90s13 is making a name for him/her selfNIK90s13 is making a name for him/her self
Try bleeding the slave cylinder, If that does not clear it up, I hate to say you may have to pull the tranny and inspect your work. But try bleeding it first.
NIK90s13 is offline   Reply With Quote
Old 04-05-2006, 12:12 PM   #3
d-oom
ok sounds good. well not really
i was looking at a diagram of the transmission and clutch, and i noticed that i didnt have a retainer spring. odd
ill drop the tranny down and check it out
Old 04-05-2006, 09:47 PM   #4
d-oom
i dropped the tranny down
the flywheel looks smooth, although there was a lot of red dust everywhere. looks like something overheated. the clutch after only 700 miles looks worn on one side more than the other, and i took it easy on it.
im going to have the flywheel resufaced, replace the pilot bearing, and hopefully get a new clutch kit since its under warrenty.
Old 04-06-2006, 06:54 AM   #5
NIK90s13
NIK90s13's Avatar
In all honesty, it sounds lik it was'nt disengageing properly. When you get it back on be sure to bleed it really good!! Good luck
Old 04-06-2006, 10:10 AM   #6
ZlElNlKlI S14
ZlElNlKlI S14 is an unknown quantity at this point
i know you dropped yer tranny a couple times...do you have the torque specs?
if u do know them..can i have the specs for:
fly wheel
transmission to the block
drive shaft..
basically anything and everything to replace a clutch..thanks!!
ZlElNlKlI S14 is offline   Reply With Quote
Old 04-06-2006, 12:26 PM   #7
d-oom
flywheel is 105ft lb
transmission to block are all around 30ft lb. you can get away with that. they are all different tho
drvieshaft... hmmm i really dont know
Old 04-06-2006, 12:28 PM   #8
d-oom
oh ya, the clutch disk was litterally warped. i really dont know what to think other than it was put on there sideways or something
ill do it all myself and make sure everything is right. last time i had a friend helping me... you know how that can go sometimes
Old 04-06-2006, 01:53 PM   #9
ZlElNlKlI S14
thanks for the helpp man..
Old 04-11-2006, 05:24 PM   #10
BlackZenkiS14
BlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond repute
Send a message via AIM to BlackZenkiS14
What pilot bearing are you using? Can i use a KA24 pilot bearing on my redtop? IF not, what is the part number that i need? i am doing a clutch on my car Friday. Thanks in advance.
-Kyle
BlackZenkiS14 is offline   Reply With Quote
