Old 04-03-2006, 09:34 AM   #1
r32gtr
r32gtr is an unknown quantity at this point
300z front brakes searched
Ok I am having a slight problem here. I have an 89 non abs coupe. I upgraded my front brakes to the 300z brakes and the master cylinder last spring. They were fine when I first installed them. But then my booster went, apparently the old bmc was bad. So I replaced the booster with a new one for the car. Well since I did that, my brake pedal has had barely any travel. basically you push a half/inch and that is it, the pedal is solid. However I am able to stop the car just fine. I want to get my pedal feel back to where it is supposed to be. Does anyone know what I need to do. I bought the brakes/rotors and bmc off a kid on a local forum, so I am not sure of the size of the bmc, is there a way to measure it? Cuz I have read on some topics on hear about adjusting the booster piston, or certain sized bmc's and people have no problems whats so ever. I have also read about people putting the s14 rear calipers on their car's and that seems to help. My mechanic told to source the 300z proportioning valve, which I found out that it is built into the bmc.
r32gtr is offline   Reply With Quote
Old 04-03-2006, 10:16 AM   #2
SoSideways
SoSideways's Avatar
Uh, you try adjusting the MC travel by messing around with the rod that's attached to the brake pedal yet?
Come on man, go under there and take a peek.
Ever tried adjusting the clutch pedal travel? Same shit for your brakes.
