Old 04-15-2006, 11:53 AM   #1
leosr20
leosr20 is an unknown quantity at this point
sr20det non start 180sx red top
hi all
i have had a bad start to my weekend!! i drove to the shops came home no problem!! put the car in the garage opened the bonnet to remove my rocker cover to change the gasget,fitted the cover back on the engine,went to start the car to check for any leaks.the car wouldnt start,the car cranks over but doesnt fire!!fuel pump is working,fuel is getting to the fuel rail,ive got spark.
so got my m8 too turn the key for me while i was checking power supply to the injectors the car started!!
so now everytime i want to start the car i have to use my light tester on a 12v live and probe one the injector wires then i here the relay click and the car will fire up
can anyone help?
leo
leosr20 is offline   Reply With Quote
Old 04-15-2006, 06:21 PM   #2
NIK90s13
NIK90s13's Avatar
NIK90s13 is making a name for him/her selfNIK90s13 is making a name for him/her self
Wierd, Check your grounds, it sounds like the test light is grounding the injectors. It sounds like you have a bad, loose, broken or curroded ground.
NIK90s13 is offline   Reply With Quote
Old 04-19-2006, 12:47 PM   #3
leosr20
non start
thanks bud!! im still on the case,but no lock yet!!!!
