Old 06-03-2002, 01:24 AM   #1
BadBoy
BadBoy is an unknown quantity at this point
Has anyone done this with them what do they do.Is it worth the $100. to spend.
BadBoy
BadBoy is offline   Reply With Quote
Old 06-04-2002, 03:56 AM   #2
tristarx
tristarx is an unknown quantity at this point
They take plugs off the KA harness and integrate into your SR harness, so when you get the harness back for the SR swap everything is plug and play.
Good service if you are not electronically inclined and can save alot of headaches.
Wayne
Phase 2
tristarx is offline   Reply With Quote
Old 06-04-2002, 04:10 AM   #3
sheepdin
sheepdin is an unknown quantity at this point
Is this wiring service required if I am getting a full S15 front clip??
sheepdin is offline   Reply With Quote
Old 06-04-2002, 06:18 AM   #4
uuninja
uuninja is an unknown quantity at this point
Send a message via AIM to uuninja Send a message via Yahoo to uuninja
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (sheepdin @ June 03 2002,06:10)</td></tr><tr><td id="QUOTE">Is this wiring service required if I am getting a full S15 front clip??</td></tr></table><span id='postcolor'>
Connsidering there was never a s15 240sx it is safe to assume that the wiring for what ever year 240 you have will not be the same as the ecu from your s15 clip. So in a work yes...
Lurker Supreme!
www.midatlantic240sx.com
  • 91 Coupe
  • 97 KA24DE+T SOLD
uuninja is offline   Reply With Quote
Old 06-04-2002, 06:24 AM   #5
thewholefnshow
thewholefnshow is an unknown quantity at this point
Send a message via ICQ to thewholefnshow
A word to the wise, I don't think that the tach and the spedometer work right if you do the s15 swap unless you get the tranny, and the dif too, seems to me the speed sensor and the tach sensors are both mechanical and in the diferential. I have heard of more than a 1 person having this problem over on FA.
thewholefnshow is offline   Reply With Quote
Old 06-04-2002, 06:56 AM   #6
HippoSleek
HippoSleek's Avatar
HippoSleek is an unknown quantity at this point
Full service for s13 & 14's is totally worthwhile if you ask me. &nbsp;I know a member here that sent his away and it ran right from start up. &nbsp;I know several DIY'ers who's cars still aren't running right... 6 mos later! <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/sad.gif" border="0" valign="absmiddle" alt=''>
As for the s15 - that is a very complicated swap. &nbsp;I also recall the speedo issue. &nbsp;I think there is a problem w/ the abs circuit changing the diff signal. &nbsp;That one is NOT easy and not for the feint of heart.
HippoSleek is offline   Reply With Quote
