Old 04-26-2006, 10:46 AM   #1
RedSuns
RedSuns's Avatar
RedSuns is an unknown quantity at this point
Send a message via AIM to RedSuns
Has anybody worked with the XFC fuel controller from Powertrain Control Solutions
I have a car that the customer wants this fuel controller installed on and it seems like a very flexible unit from the brief research that I have done. For the Price I could get an Enthalpy tune and be done, but, I am always up for trying something new. Here is some info about the unit.
Product Description:
The average street car tuner today faces a dilemma. What do you do when you add a stroker kit, supercharger or turbocharger to a modern streetcar? You want to keep all of the amenities offered by the car and you expect performance at least as good as the stock systems. What do you do with electronic throttle? How do you tune it? Solutions do exist but they are incomplete, erratic, require disabling of critical vehicle functions or cost far too much. The XFC is the solution. Designed for the modified street car, a properly tuned XFC can deliver the added fuel required by your high performance parts while keeping your stock powertrain management systems functioning as if no changes had occurred. Competing units offer MAF skew or O2 skew but have severe limitations. Many new vehicles learn to eliminate the changes caused by MAF skew devices through O2 feedback. Competing O2 skew systems cause the vehicle to enter open loop but can often cause vehicles to trigger trouble codes and enter a debilitating limp or failsafe mode. Fuel pump control systems exist but operate on insufficient information. Fuel pump control based on too little information forms a dangerous situation in which a vehicle can be easily provided with far too much or too little fuel based on dynamic weather, battery and fuel delivery system conditions.
Product Specifications:
· Engine RPM Input
· Frequency MAF/Vehicle Speed Input
· 2 Narrow Band O2 Inputs
· 2 Wide Band (from WBO2 controller) Inputs
· 2 MAF Sensor Inputs
· 1 MAP Sensor Input
· 1 TPS Sensor Input
· 1 Fuel Pressure Sensor Input
· 2 MAF Output Skews based on 3D 16x16 tables
· 1 Frequency MAF Output Skew based on 3D 16x16 tables
· 2 O2 Output Skews based on 3D 16x16 tables
· 2 Programmable PWM Output Skews based on 3D 16x16 tables
· High Power Direct Fuel Pump Control
· Future Ignition Control Capability
· In-Field Flash Upgradable
· RS 232, CAN (2.0b) communications
· Durable weather sealed connectors built into case.
· All components specified for automotive conditions.
· Easy to use windows software interface
· Realtime Datalogging & Monitor Screens
Johnathan
2005 Titan
1996 240SX
1991 240SX
1974 260Z
1996 Honda CBR 600 F3
RedSuns is offline   Reply With Quote
