Old 05-08-2006, 07:17 PM   #1
Cashizslick
Cashizslick can only hope to improve
SR Removing I/M Support Brakets - is it ok??
Is it ok to pull off the intake manifold support brackets under the manifold to make oil changes easier on an SR20DET?
I was trying to change my oil yesterday but i dont have a lift and i cant get a good grip on that stupid oil filter.
Thanks in advance.
Cashizslick is offline   Reply With Quote
Old 05-08-2006, 07:18 PM   #2
SRd240sx
SRd240sx's Avatar
SRd240sx will become famous soon enoughSRd240sx will become famous soon enoughSRd240sx will become famous soon enoughSRd240sx will become famous soon enough
Send a message via AIM to SRd240sx
yep, all my friends have removed theirs, now it's way easier to take off the oil filter.
SRd240sx is offline   Reply With Quote
Old 05-08-2006, 07:24 PM   #3
Cashizslick
Nice thats what i wanted to hear.
How big are they/how many bolts? Is it possible to take em off w/out a lift?
Old 05-08-2006, 07:43 PM   #4
Cashizslick
Wait, I just found this pic from the FSM . . anybody know what bolt size these are?
Do i only have to remove the big triangular bracket?
Old 05-08-2006, 08:19 PM   #5
jdm_s14_zenki
jdm_s14_zenki is a glorious beacon of lightjdm_s14_zenki is a glorious beacon of lightjdm_s14_zenki is a glorious beacon of lightjdm_s14_zenki is a glorious beacon of lightjdm_s14_zenki is a glorious beacon of lightjdm_s14_zenki is a glorious beacon of lightjdm_s14_zenki is a glorious beacon of lightjdm_s14_zenki is a glorious beacon of lightjdm_s14_zenki is a glorious beacon of lightjdm_s14_zenki is a glorious beacon of lightjdm_s14_zenki is a glorious beacon of light
Send a message via AIM to jdm_s14_zenki
dont those supports prevent the manifold/head/block from shaking and creating gasket leaks and or broken bolts?
jdm_s14_zenki is offline   Reply With Quote
Old 05-08-2006, 09:18 PM   #6
theicecreamdan
theicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfection
Send a message via AIM to theicecreamdan
maybe in theory, but people remove them without issues.
Originally Posted by malcolm_x
Be peaceful, be courteous, obey the law, respect everyone; but if someone puts his hand on you, send him to the cemetery.
theicecreamdan is offline   Reply With Quote
Old 05-09-2006, 12:06 AM   #7
jdm_s14_zenki
wow, didnt even know that people remove them...hell, if this is absolutely true, then i'll remove mine cus those brackets are a headache
Old 05-09-2006, 07:03 AM   #8
S13Eye
S13Eye's Avatar
S13Eye will become famous soon enoughS13Eye will become famous soon enoughS13Eye will become famous soon enough
Send a message via AIM to S13Eye
What is the big problem? Your hand should fit from the top between the alternator and support brace. If you still can't get it off, its either overtightened, or you have no muscles in your arm.
S13Eye is offline   Reply With Quote
Old 05-09-2006, 08:09 AM   #9
projectRDM
projectRDM's Avatar
I leave them off every KA and SR I put in, never had an issue and makes starter/oil filter removal twice as easy, among other things.
Old 05-09-2006, 08:44 AM   #10
reccakun08
reccakun08's Avatar
reccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the rough
yup mine is off too
reccakun08 is offline   Reply With Quote
Old 08-07-2006, 07:52 AM   #11
g6civcx
g6civcx's Avatar
Sorry to bump an old thread, but I had a chance to remove this when I did the motor mount this weekend.
Just to be clear, is everybody talking about the triangular piece in the picture below? What about the two other small brackets? Do you just leave them?
And FYI, 1 and 2 are 12mm bolts. 3 is a 14mm bolt. You don't need a lift to remove them. Just use a good 6-point socket and ratchet set, PB Blaster, and maybe a breaker bar if you need it.
Old 08-07-2006, 08:59 AM   #12
DTS
DTS is a well-known jackass
mines off too
DTS is offline   Reply With Quote
Old 08-07-2006, 09:08 AM   #13
projectRDM
projectRDM's Avatar
Yes. On the KA there is two of them.
Old 08-07-2006, 09:21 AM   #14
g6civcx
g6civcx's Avatar
Thanks for the reply.
If anybody is struggling with the oil filter, consider switching to the K&N Performance Gold Oil Filter. You can put a 1" socket/wrench on it and use that to loosen the filter.
Or the next best thing is to find a filter wrench.
