Old 05-21-2006, 07:34 PM   #1
mistaanime
mistaanime's Avatar
mistaanime is making a name for him/her selfmistaanime is making a name for him/her self
Send a message via AIM to mistaanime
HELP: After Z32 Caliper install
ok..i installed the z32 calipers on my 240sx..and then i bleed each caliper twice and still i have this problem..nothign happens until the petal is nearly almost to the ground..im using stock 5spd MC but should it have this big of a difference?
-Cherry Red 91 Silfourty-
mistaanime is offline   Reply With Quote
Old 05-21-2006, 07:44 PM   #2
sncs14
sncs14's Avatar
sncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond repute
nothing happens, or, "nealy nothing happens"?
If nothing happens and the pedal goes all the way to the floor you have the calipers on the wrong sides.
sncs14 is offline   Reply With Quote
Old 05-21-2006, 07:58 PM   #3
mistaanime
mistaanime's Avatar
well..as im stepping the petal down..its not braking until the petal almost hits the ground..
Old 05-21-2006, 08:06 PM   #4
dct223
dct223's Avatar
dct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nice
Send a message via AIM to dct223
did you bleed your ENTIRE brake system??? if you didnt then thats your problem
Rear right, rear left, front right, front left...
Sfourteen
dct223 is offline   Reply With Quote
Old 05-21-2006, 08:12 PM   #5
mistaanime
mistaanime's Avatar
did the whole thing..i was thinking of juss re bleeding again but i dunno..
Old 05-21-2006, 08:31 PM   #6
sncs14
sncs14's Avatar
Try adjusting the push rod that moves the BMC piston. It may not be contacting the BMC early enough. If the calipers are on the correct sides.
Old 05-21-2006, 08:31 PM   #7
aznpoopy
aznpoopy's Avatar
bleed it again, and bleed the m/c too.
if they are junkyard calipers they could be fucked.
alternatively, your master cylinder could have gone to shit if its an old one. wouldn't be the first time.
aznpoopy is offline   Reply With Quote
Old 05-21-2006, 08:39 PM   #8
mistaanime
mistaanime's Avatar
calipers are on the right side..and i picked them up at NAPA..im thinkin its the master cylinder..but its juss that when i had the oem brakes on before..they they were breakin fine..bleeding the MC..haven't tryed that..tho that my be a problem because i've never and don't know how to bleed it....i juss know how to bleed the clutch...btw thanx for all these quick replies
Old 05-21-2006, 08:41 PM   #9
SimpleS14
SimpleS14's Avatar
How did you bleed your brakes? Besides the order calipers your suppose to bleed in...did you build pressure on the pedal?
After I did mine, I stepped all the way on the pedal when bleeding the brakes...which was causing the brakes to work only when the pedal was almost to the ground. So second time around I stepped only half-way or where I would like the brakes to start grabbing and that solved my issue.
Goals are dreams with a deadline.
L.H.O.O.Q.
SimpleS14 is offline   Reply With Quote
Old 05-21-2006, 08:43 PM   #10
DJPimpFlex
DJPimpFlex's Avatar
Trader Rating: (115)
DJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond repute
Feedback Score: 115 reviews
Send a message via AIM to DJPimpFlex Send a message via MSN to DJPimpFlex
^correct me if I'm wrong, but isnt the order, left rear, right rear, right front left front? I think thats how it is, and thats how I've awlays done it.
DJPimpFlex is offline   Reply With Quote
Old 05-21-2006, 08:50 PM   #11
mistaanime
mistaanime's Avatar
heh i did the proper order....but stepping it half way?..i could try to see if that works..juss thoguht some air mite stay in if i did it half way..
Old 05-21-2006, 08:53 PM   #12
dct223
dct223's Avatar
im not sure of the correct order.. but i always thought it was furthest away from the MC to the closest to the MC... thats what i did on my car and it worked...
Sfourteen
Old 05-21-2006, 08:58 PM   #13
SimpleS14
SimpleS14's Avatar
Then that is what your missing...you have to do this to build resistance (or pressure) within the brake system. You won't get any air in your system given you keep your foot down half-way and whoever is underneath tightens the bleeder screw once all the air is out.
BTW....for a solo job I highly recommend speed bleeders. I have a set and I did the job faster than with two people.
L.H.O.O.Q.
Old 05-21-2006, 09:10 PM   #14
mrmephistopheles
mrmephistopheles's Avatar
your bleed valves are *up*, right?
Originally Posted by PHLIP
Old 05-21-2006, 09:55 PM   #15
khilgers
khilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond repute
that was my problem with my setup. I adjusted it and now it feels much better. BTW, I've got z32 30MM fronts and stock rears on an S14.
khilgers is offline   Reply With Quote
Old 05-21-2006, 10:02 PM   #16
nrg
nrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud of
Send a message via AIM to nrg
did you buy the right rotors for your calipers? it sounds like you have 30mm calipers with 26mm rotors.
driftingisgay.com
nrg is offline   Reply With Quote
Old 05-21-2006, 10:02 PM   #17
1Via!
1Via!'s Avatar
1Via! is a name known to all1Via! is a name known to all1Via! is a name known to all1Via! is a name known to all1Via! is a name known to all1Via! is a name known to all1Via! is a name known to all1Via! is a name known to all1Via! is a name known to all1Via! is a name known to all1Via! is a name known to all
Send a message via AIM to 1Via!
This is what I say too.
Make sure that the bleed valves are not on the bottom side of caliper. If they are, you need to switch the sides the calipers are on.
I wouldn't be suprised if this was the problem.
If thats not it, try bench bleeding the MC and use teflon tape on all of the fittings between the hard lines and flex lines.
1Via! is offline   Reply With Quote
Old 05-21-2006, 10:55 PM   #18
infinitexsound
infinitexsound's Avatar
infinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond repute
im bettin that the bleeders arent up hence the issue... calipers are on the wrong side...
S14 TrackSlut coming to a raceway near you...
510 TimeAttack on its way...
infinitexsound is offline   Reply With Quote
Old 05-21-2006, 11:40 PM   #19
mrmephistopheles
btw, it's spelled 'PEDAL' with a big fat D
Old 05-22-2006, 01:39 AM   #20
mistaanime
mistaanime's Avatar
pedal..lol..ok thanx! anyways..yes its UP...heh the calipers are on the right sides..imma try the half step and then if that doesn't work then imma try adjusting the rod tomolo...thanx..and hopefully i'll get this fixed..
btw..mephisto...great sig..yours?
Old 05-22-2006, 02:41 AM   #21
mrmephistopheles
my picture (i took it) but not my car.
It belongs to the boss of a friend of mine.
Keep an eye out for a big fat fucking pic thread coming soon.
Old 05-25-2006, 01:30 AM   #22
mistaanime
mistaanime's Avatar
i ended up buying a reverse pump with a container thing at a local kregan store..pumped out the air and got it done...i know there were the other ways..but..i had enough..and bothering some one to help me out was a pain..but with this...all it did was it sucked out the air outta the system pretty much a recycle device..anyways thanx for all your help!
Old 05-25-2006, 10:15 AM   #23
rossfashow
rossfashow's Avatar
rossfashow has a spectacular aura aboutrossfashow has a spectacular aura aboutrossfashow has a spectacular aura aboutrossfashow has a spectacular aura aboutrossfashow has a spectacular aura aboutrossfashow has a spectacular aura aboutrossfashow has a spectacular aura about
did it help out can you brake fine now?
- 1995 Mitsubishi VR4, billet 6765
- 1989 S13 FB 225whp .sold
rossfashow is offline   Reply With Quote
Old 05-25-2006, 01:41 PM   #24
theronin
theronin's Avatar
theronin is close to perfectiontheronin is close to perfectiontheronin is close to perfectiontheronin is close to perfectiontheronin is close to perfectiontheronin is close to perfectiontheronin is close to perfectiontheronin is close to perfectiontheronin is close to perfectiontheronin is close to perfectiontheronin is close to perfection
Send a message via AIM to theronin
while u are still at the bleeding stage of ur brake job be sure to get some speed bleeders they save so much time...
Originally Posted by HalveBlue View Post
That first picture is totally bad ass.
It just screams, "Hey, I'm a fucking Christmas Tree. What are you gonna do about it?"
theronin is offline   Reply With Quote
Old 05-27-2006, 08:57 AM   #25
mistaanime
mistaanime's Avatar
hah bought some..and the retard sold me the wrong ones..he sold me the 10mm x 1.25 ones..i didn't know until i got home and looked it up on the internet..thats im suppose to be using 10mm x 1.5
Old 09-09-2006, 07:59 AM   #26
PITCH
PITCH's Avatar
PITCH is a splendid one to beholdPITCH is a splendid one to beholdPITCH is a splendid one to beholdPITCH is a splendid one to beholdPITCH is a splendid one to beholdPITCH is a splendid one to beholdPITCH is a splendid one to beholdPITCH is a splendid one to beholdPITCH is a splendid one to beholdPITCH is a splendid one to beholdPITCH is a splendid one to behold
I dont have quite his problem but similar. Got the R33 GTS-T's fronts on only. (still waiting on parts for the rears) A little concerned. The pedal has some travel to it. Unforunately I had to make an emergency stop (figures, hrs after I did the install) And the pedal travel was hesitat and pretty soft. It did stop though. They stopped fine in normal crusing mode but that emergency stop took some time.
The only thing I didnt do was bleed the master cylinder should this be done? How do you do it?
Also I didnt blead the intire system. I just did the front calipers I swapped. Could this be the problem as well?
thanks..
PITCH is offline   Reply With Quote
Old 09-09-2006, 10:44 AM   #27
Tenchuu
Tenchuu's Avatar
Tenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfection
when i first bled my old Z32 calipers it was kinda soft and mushey, then i got super blue fluid, ends up it takes LONG AS HELL to do a complete flush of the system. and i found out that supposidily due to the way the lines are run the correct bleeding is cycle is lt rear, rt rear, rt front, lt front. it's all about getting massive amouts of air out of the system.
Tenchuu is offline   Reply With Quote
Old 09-09-2006, 03:11 PM   #28
sepulchral
sepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymore
u monkeys you start at the wheel furthest from the MC and work your way towards it, damn
sepulchral is offline   Reply With Quote
Old 09-09-2006, 03:28 PM   #29
NinjaGaiden
NinjaGaiden's Avatar
NinjaGaiden is an unknown quantity at this point
for s13 nonABS, u want to bleed from the left rear first as tenchuu stated because it is the farthest line from the MC.
our hard lines come down the right frame rail and then split for the rear left and rear right calipers. The rear left is farthest away from the MC (not physically, but if you follow the hard lines, it is)
NinjaGaiden is offline   Reply With Quote
Old 09-09-2006, 03:32 PM   #30
BlackZenkiS14
BlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond repute
Send a message via AIM to BlackZenkiS14
<- subscribed....
-Kyle
BlackZenkiS14 is offline   Reply With Quote
