Old 05-25-2006, 11:47 PM   #1
DRavenS13
DRavenS13's Avatar
Location: Where angels (and most pizza delivery people) fear to tread.
DRavenS13 is close to perfectionDRavenS13 is close to perfectionDRavenS13 is close to perfectionDRavenS13 is close to perfectionDRavenS13 is close to perfectionDRavenS13 is close to perfectionDRavenS13 is close to perfectionDRavenS13 is close to perfectionDRavenS13 is close to perfectionDRavenS13 is close to perfectionDRavenS13 is close to perfection
Blew The Radiator, New Problem Came Along...
Ok so about 2 Tuesdays ago, I was driving home and my radiator blew out. I kinda knew it was coming, so that was my fault. The problem is, after it blew, my RPMs dropped and the car turned off, and when I tried to turn it on again, it only cranks but the engine won't turn over. I've had a few different opinions about what happened, like maybe the starter solenoid, or worst-case senario, blown head gasket. I'm doing the compression test possibly tomorrow to make sure it wasn't that.
Any opinions on what it could be? Thanks.
Originally Posted by S14Josh View Post
seeing old people give you the finger is like winning the lottery...you still can't believe it happened 4 weeks afterwards.
DRavenS13 is offline   Reply With Quote
Old 05-26-2006, 12:16 AM   #2
drifter808
drifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of light
how did you know your radiator was gonna blow up?
drifter808 is offline   Reply With Quote
Old 05-26-2006, 01:39 AM   #3
!Zar!
!Zar!'s Avatar
You madam have a blown headgasket.
Have fun.
Old 05-26-2006, 09:42 AM   #4
drifter808
yeah i was thinking he had a blown headgasket. it doesn't sound right to have a radiator blow up.
Old 05-26-2006, 10:48 AM   #5
Neejay
Neejay's Avatar
Neejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfection
RPM's dropping and not cranking = headgasket. Damn.
Neejay is offline   Reply With Quote
Old 05-26-2006, 10:53 AM   #6
RPS1392
RPS1392's Avatar
RPS1392 has a spectacular aura aboutRPS1392 has a spectacular aura aboutRPS1392 has a spectacular aura aboutRPS1392 has a spectacular aura aboutRPS1392 has a spectacular aura aboutRPS1392 has a spectacular aura about
Blown headgaskets somtimes cause unusally high cooling system pressure. If the radiator was week to begin with, could cause a blown seam, or worse.
RPS1392 is offline   Reply With Quote
Old 05-26-2006, 08:02 PM   #7
Irukandji
yay for blown head gaskets.
Irukandji is offline   Reply With Quote
Old 05-26-2006, 08:04 PM   #8
i-love-my-s14
i-love-my-s14's Avatar
i-love-my-s14 is an unknown quantity at this point
Sounds like the headgasket, exactly what happened to me.
i-love-my-s14 is offline   Reply With Quote
Old 05-27-2006, 08:37 AM   #9
DRavenS13
DRavenS13's Avatar
I knew the radiator was gonna blow because when I bought the car, it had a teeny-tiny hole in the radiator. When I opened the hood, it was all exploded from one side where the hole was located, exploded meaning there was orange fluid crap everywhere. I checked the oil, and it still looks good, no gooey milkshake factor.
The engine does crank, but it just doesn't turn over. From what I've been told, it may just be the starter that got messed up from the fluid leaking into it. I'm hoping to GOD it's not the head gasket, but I'll find out by tomorrow.
Old 05-27-2006, 11:16 AM   #10
chrisstroud
chrisstroud's Avatar
chrisstroud is an unknown quantity at this point
Send a message via AIM to chrisstroud
If it's cranking at an adequete speed, it's not gonna be the starter.
When you say "It won't turn over", do you just mean that it won't fire over and start?
You should run a compression test, buying a compression tester at Autozone will be cheaper than having a shop diagnose it, and you can do it yourself if you know how to change plugs.
chrisstroud is offline   Reply With Quote
Old 05-27-2006, 01:02 PM   #11
Neejay
Neejay's Avatar
yeah, as chrisstroud said, do a compression and/or leakdown test.
Old 06-04-2006, 04:22 PM   #12
DRavenS13
DRavenS13's Avatar
Yep, blown head gasket. My starter was blown out too, and i fixed that already. Thanks guys.
Old 06-04-2006, 06:04 PM   #13
!Zar!
!Zar!'s Avatar
Welcome to the club.
The hg in one of my s14's is blown.
I just too lasy to do anything about it, so it's currently sitting in the driveway~
Old 06-05-2006, 03:58 AM   #14
DRavenS13
DRavenS13's Avatar
I can't afford to be lazy about it, it's my daily driver, so I gotta fix it soon as humanly possible.
Old 06-05-2006, 01:32 PM   #15
s13_gearhead
s13_gearhead's Avatar
s13_gearhead will become famous soon enoughs13_gearhead will become famous soon enoughs13_gearhead will become famous soon enough
Send a message via AIM to s13_gearhead Send a message via MSN to s13_gearhead
Y'know Zar, the longer you wait the more catastrophic damage you're going to be doing to that engine. If a few of your cylinders filled with water and the liquid inside them is currently working on etching a nice lil rust ring around your barrels, that engine is gonna be f*cked. Get off your ass and fix that HG asap dude.
s13_gearhead is offline   Reply With Quote
Old 06-05-2006, 09:43 PM   #16
Neejay
Neejay's Avatar
Yeah, Ive heard of that too.
Old 06-05-2006, 09:51 PM   #17
gotta240
dang..s13gearhead is on his ish...
DEFF wanna get that water out of the cylinder walls.... if you ABSOLUTLY must wait, you might even consider filling it with oil untill you can get around to it..... 1/2 oil 1/2 water = a little less rust...lol.
Old 08-03-2006, 02:32 PM   #18
mufasa
mufasa is an unknown quantity at this point
coolant does have or at least it should have anti corrsion additive, it should not make it rust. However old or heavily used/improperly mixed coolant will allow rust.
mufasa is offline   Reply With Quote
