Old 05-26-2006, 02:39 AM   #1
komedy
komedy is on the path to ruinkomedy is on the path to ruin
Help Coolant leak, is it a Major job??
got coolant leaking not from any hoses but by where the stock fan blade is mounted onto. is that my water pump?? looks like the gasket for that poped in that one corner.
please any help or info would be grateful.
komedy is offline   Reply With Quote
Old 05-26-2006, 02:47 AM   #2
komedy
by the way what is that thing that holds my engine fan and is mounted to my block? some kind of pump?
Old 05-26-2006, 02:51 AM   #3
SimpleSexy180
ding ding ding. yes sir its your water pump. Their is a small hole on the bottom of the pump which will go bad and cause the leak. AND its pretty simple job, make sure to scrape off the excess gasket off the block when u take the old pump out.
Oh and next time search this tech section, because this has been covered i am sure of it...
SimpleSexy180 is offline   Reply With Quote
Old 05-26-2006, 07:06 AM   #4
NIK90s13
NIK90s13's Avatar
NIK90s13 is making a name for him/her selfNIK90s13 is making a name for him/her self
+1^^^ It is the water pump, and you need to replace it ,even if it doesnt seem to be leaking get another one. there is nothing worse than doing the samething twice. Get a nissan pump too. check your belts wile you are at it.
NIK90s13 is offline   Reply With Quote
Old 05-26-2006, 08:03 PM   #5
Irukandji
replace water pump.. its easy.
Replace thermostat while you're at it.
Irukandji is offline   Reply With Quote
Old 05-26-2006, 09:02 PM   #6
JMixedDS13M
JMixedDS13M's Avatar
JMixedDS13M is a well-known jackass
yes thermo can be somewhat of a pain to do if u do separate. much easier to maneuver the thermostat housing without the fan clutch and fan blade.
JMixedDS13M is offline   Reply With Quote
Old 05-27-2006, 03:33 AM   #7
komedy
how do i remove the fan blade?
Old 05-27-2006, 05:10 AM   #8
Jung918
Jung918's Avatar
Jung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfection
take the 4 nuts off of it.
Jung918 is offline   Reply With Quote
Old 05-27-2006, 09:46 AM   #9
NIK90s13
NIK90s13's Avatar
Yea 4 10mm bolts on the frunt of the fan. No problem.
Old 05-27-2006, 11:21 PM   #10
komedy
kool just finished pulling the water pump. it has alot of up and down play. is that normal? wheres my thermostat at. i might as well replace that too. is the thermostat on the left of it?
Old 05-28-2006, 03:20 AM   #11
IAM_SO_sLOw
IAM_SO_sLOw has made poor choicesIAM_SO_sLOw has made poor choicesIAM_SO_sLOw has made poor choicesIAM_SO_sLOw has made poor choicesIAM_SO_sLOw has made poor choicesIAM_SO_sLOw has made poor choices
Send a message via AIM to IAM_SO_sLOw
you might beable to get away w/ just taking off the water pump and resealing it...
IAM_SO_sLOw is offline   Reply With Quote
Old 05-28-2006, 10:39 AM   #12
WickedDrift
WickedDrift's Avatar
WickedDrift is an unknown quantity at this point
Send a message via AIM to WickedDrift
that thing is what drives your oil pimp. and if your having any fluid leaks it might be a couple of things. first off the water pump as u said before the blades might be broken or just too worn, the thermostat might be sticking making too much pressure, or even that you have a hole in the radiator. do a pressure test.
WickedDrift is offline   Reply With Quote
Old 05-28-2006, 01:50 PM   #13
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
"Oil pimp" Hope thats a typo and you meant to type water pump.
But anyways, you got it pulled, swap in a fresh one. You said theres some play on the pump, so its fubar, dont go cheap and replace the damn thing with a new one.
CLICK HERE!!!
