Old 05-28-2006, 10:52 AM   #1
EvenStar
EvenStar is an unknown quantity at this point
Rebuilding a KA motor?
I have never rebuilt a car motor before and the price for rebuilding motors at a shop is insanely high. The only tools I have at home is a cherry picker and tools needed to attach/unattach bolts and nuts for now. I was wondering if there is a website where I can order rebuilding motor parts and the steps to perform the rebuild?
EvenStar is offline   Reply With Quote
Old 05-28-2006, 10:59 AM   #2
Phlip
Yes, I look like that
Phlip's Avatar
You didn't specify which year, so I aimed for the middle ground.
http://www.amazon.com/exec/obidos/tg...glance&s=books
... good luck
Weirdo
And I write too!
Old 05-28-2006, 11:31 AM   #3
EvenStar
93 240sx fastback, automatic.
Old 05-28-2006, 12:14 PM   #4
infinitexsound
infinitexsound's Avatar
infinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond repute
get a fsm, get a bin.... take the head off.......
follow the fsm i honestly say read the em section 3x over, keep all the parts numbered 1-4... get a micrometer in and out, get a engine stand.... get a parts washer...start following the fsm in taking apart the block. make sure... u keep everything numbered....would be wise to get a number punch set..
maybe ill do a write up, when i rebuild my block....
S14 TrackSlut coming to a raceway near you...
510 TimeAttack on its way...
infinitexsound is offline   Reply With Quote
Old 05-28-2006, 12:19 PM   #5
EvenStar
that'll be awesome.
any ideas on how long rebuilding a KA engine might take?
Old 05-28-2006, 12:23 PM   #6
infinitexsound
for someone whos not mechanically inclined... i say for ever, but if ur thorough clean organized... and u follow directions well and have the money for the rebuild maybe a month... me... if i have all the parts in hand maybe a few days..
Old 05-28-2006, 12:24 PM   #7
formeRiceR
formeRiceR is an unknown quantity at this point
here you go
http://www.ka-t.org/forums/viewtopic.php?t=4156
"Street racers don't need girls." -Lonely Driver
Learning about cars one FLAME at a time ... (thanks to TNORD)
formeRiceR is offline   Reply With Quote
Old 05-28-2006, 01:19 PM   #8
tre
tre's Avatar
tre will become famous soon enoughtre will become famous soon enoughtre will become famous soon enoughtre will become famous soon enoughtre will become famous soon enough
i'll be cheaper to swap a lower mileage engine. But IF you're up for a task. Which i'd HIGHLY suggest having someone who knows what they're doing by you. Go for it. Good learning experience.
I didn't buy an Audi because it is a Great Car, but for more of a reason to be an asshole.
tre is offline   Reply With Quote
Old 05-28-2006, 01:55 PM   #9
EvenStar
Originally Posted by formeRiceR
thanks a lot! ^^
now all i need is a website that sells full rebuilding kits.. x_x
Old 05-28-2006, 02:03 PM   #10
Phlip
Phlip's Avatar
Some of these can be a bit spendy, especially for a novice:
http://www.importperformanceparts.ne...ek-nissan.html
http://www.amsperformance.com/store/...roducts_id=303
http://www.rpmmachine.com/enginerebu...nissantop.html
http://www.nizzx.com/
http://www.hybridka.com/
... I searched and found those, I suggest you go that route from here forward
Weirdo
And I write too!
Old 05-28-2006, 02:08 PM   #11
EvenStar
... I searched and found that, I suggest you go that route from here forward
thanks! ^^
OK, after reading the guide, it says that I should only use OEM parts or bolts [I'm going to assume that I can use the same bolts that I took out]. Where can I get the OEM Nissan handbook guide? Or FSM.
Old 05-28-2006, 02:09 PM   #12
tre
tre's Avatar
i'd HIGHLY suggest an OEM rebuild kit aswell.
Hell one of the best Head Gaskets ont he market for the DE is OEM.
Old 05-28-2006, 02:18 PM   #13
EvenStar
Btw, can anyone list the parts that I need to rebuild the whole motor? And what specific tools do I need when taking out bolts and such? The guide did not mention it and I just want to make sure of it when I order the rebuilding kit.
Old 05-28-2006, 02:42 PM   #14
infinitexsound
just get a FSM it tells u everything u need..... search fsm, zeroyon "something that", theres a recent thread speeddreamz is hosting some fsm now....
Old 05-28-2006, 05:06 PM   #15
BigVinnie
BigVinnie's Avatar
BigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfection
Infinitexsound is a very wise man, take his advice.
You can also get a shit load of zip lock bags as well. Label the zip lock bags to describe where the bolts came from. Mark bolts using whiteout, mark it in dots to describe what number from pattern so that it would be easy to put back together.
BigVinnie is offline   Reply With Quote
Old 05-29-2006, 03:44 PM   #16
infinitexsound
organization is always the key........ big vinnie how is ur build goin...... i guess u havent heard im goin sRAwR.....
Old 05-29-2006, 09:57 PM   #17
WickedDrift
WickedDrift's Avatar
WickedDrift is an unknown quantity at this point
Send a message via AIM to WickedDrift
http://www.amsperformance.com/store/...hp?cPath=24_62
everything you need for your rebuild right there, ams is very respectible over here in Chicago
- 93' 240s13 -
NISSAN's NEVER Break
"BOOST IT"
WickedDrift is offline   Reply With Quote
Old 05-29-2006, 10:18 PM   #18
BigVinnie
BigVinnie's Avatar
BOO on the sr!!!! I've actually decided to save my money on an HRT N/A built block 10.5:1 setup. All I have to do is install it. Also install the scraper and windage tray... Don't have a garage anymore........ But ehh just kidding about the sr, if you like it it's meant for JOO!!!
Old 05-30-2006, 12:26 AM   #19
infinitexsound
theres a place in vallejo that does knife edging for 250 i believe... im going to them for this build... to get my crank serviced...
