Old 06-02-2006, 01:21 PM   #1
Mr. Camshaft
Mr. Camshaft's Avatar
Mr. Camshaft is a name known to allMr. Camshaft is a name known to allMr. Camshaft is a name known to allMr. Camshaft is a name known to allMr. Camshaft is a name known to allMr. Camshaft is a name known to allMr. Camshaft is a name known to allMr. Camshaft is a name known to allMr. Camshaft is a name known to allMr. Camshaft is a name known to allMr. Camshaft is a name known to all
Send a message via AIM to Mr. Camshaft
Brake light won't go away
I accidentally tried to go in reverse with the parking brake all the way up. Now the little brake indicator light won't go away. So, I fuxor something real bad, or is it an easy fix? Doesn't seem like a huge problem, but the little light being on all the time is kinda annoying.
Mr. Camshaft is offline   Reply With Quote
Old 06-02-2006, 01:32 PM   #2
DRIFTER-M
DRIFTER-M's Avatar
DRIFTER-M is a glorious beacon of lightDRIFTER-M is a glorious beacon of lightDRIFTER-M is a glorious beacon of lightDRIFTER-M is a glorious beacon of lightDRIFTER-M is a glorious beacon of lightDRIFTER-M is a glorious beacon of lightDRIFTER-M is a glorious beacon of lightDRIFTER-M is a glorious beacon of lightDRIFTER-M is a glorious beacon of lightDRIFTER-M is a glorious beacon of lightDRIFTER-M is a glorious beacon of light
Send a message via AIM to DRIFTER-M
Might be just a short in the wire. Leaving your brake up and driving really just wears down your brakes crazy fast, unless your pads locked up on the rotors or something and the light is picking that up. Honestly though, if you havn't noticed it driving wierd, its prob just your brake light shorted out.
Are you sure your e-brake is going down all the way? Even if its just a hair up from where it is suppose to be, the light will light up as if its engaged.
DRIFTER-M is offline   Reply With Quote
Old 06-02-2006, 01:42 PM   #3
Mr. Camshaft
yeah, pretty sure the lever goes all the way down. I even pushed down on it pretty hard just to make sure.
Old 06-02-2006, 06:12 PM   #4
SochBAT
SochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfection
Send a message via AIM to SochBAT
have you actually checked thelight sensor?
The piece that is depressed when teh Ebrake is down?
Checkk it out!
SochBAT is offline   Reply With Quote
Old 06-02-2006, 06:16 PM   #5
prymer 240
prymer 240 is an unknown quantity at this point
i had the same problem.... it was a short in my harness when i slapped it in reverse.. pop the hood, and look in the fuse box... there should b a 10 amp fuse for engine control....see if its blown... if its blown it would set ur brk lite to go on .. and if it is blown replace it, and put it in reverse.. back up and see if it blows again... if it blows again that mean u prolly have corrosion in the reverse harness and is shortin out... usually due to rott on the hatch from the spoiler... repair harness if u find it.. and should b good.. good luck
prymer 240 is offline   Reply With Quote
Old 06-04-2006, 01:13 AM   #6
g6civcx
g6civcx's Avatar
Check your brake fluid. The brake light also indicates low fluid.
Old 06-04-2006, 04:38 AM   #7
nismonster
nismonster's Avatar
nismonster is an unknown quantity at this point
I think it sounds like you might have bent the bracket where the indicator is when you pulled up too hard.
nismonster is offline   Reply With Quote
Old 06-04-2006, 08:00 AM   #8
SaintlyCharBoy
SaintlyCharBoy is making a name for him/her selfSaintlyCharBoy is making a name for him/her selfSaintlyCharBoy is making a name for him/her self
Send a message via ICQ to SaintlyCharBoy Send a message via AIM to SaintlyCharBoy Send a message via Yahoo to SaintlyCharBoy
like g6civcx said, most common issue is low brake fluid
92 vert - KADE + VH41 + GM MA5 = too many parts in the garage
95 base - retired
SaintlyCharBoy is offline   Reply With Quote
Old 06-06-2006, 12:01 AM   #9
Reiman
Reiman is an unknown quantity at this point
brake sensor
theres a button under the dash also for your brake pedal that recently broke on mine. I found little shars of plastic on my floorboard from a button that presses a sensor so that the brake light turns off with the car.
Hope this helps.
Reiman is offline   Reply With Quote
Old 06-06-2006, 11:37 AM   #10
chuy
chuy has a spectacular aura aboutchuy has a spectacular aura aboutchuy has a spectacular aura aboutchuy has a spectacular aura aboutchuy has a spectacular aura aboutchuy has a spectacular aura about
Checkk it out!
Im with this person.
Slide Happy
chuy is offline   Reply With Quote
Old 06-06-2006, 12:18 PM   #11
projekt_s13
projekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfection
Send a message via AIM to projekt_s13
hahah i got the same problem but it only turns on when i release the clutch, or accelerator.
projekt_s13 is offline   Reply With Quote
Old 06-06-2006, 12:32 PM   #12
rancid240
Trader Rating: (72)
rancid240 will become famous soon enoughrancid240 will become famous soon enoughrancid240 will become famous soon enough
Feedback Score: 72 reviews
I did not know that....good info...no wonder theres a harness on the MC, heh
rancid240 is offline   Reply With Quote
Old 06-06-2006, 04:13 PM   #13
Mr. Camshaft
Fluid levels are fine, and the fuses are fine. I think I just fubared the parking brake sensor.
Old 06-06-2006, 06:11 PM   #14
cdigity
cdigity is on a distinguished road
its most likely the parking brake switch.
go to napa or nissan parts and order one
they are cheap.
had a s13 that my shop put a remote start in and the same thing happened
swaped the switch and no more light staying on
www.soundworksinc.net
kkk k27
hks b.o.v.
jgs front mount
split-second a.i.c.
vortech s.f.m.u.
walbro 255 lph
cdigity is offline   Reply With Quote
