Old 06-06-2006, 03:35 AM   #1
i8yourfwd
i8yourfwd's Avatar
i8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfection
Send a message via AIM to i8yourfwd
Clutch problem, help please!
Hmm so I was driving somewhere earlier today and as I press down my clutch pedal I hear a loud click and my clutch pedal feel is completely gone. Now, one would assume that my clutch finally just decided to die on me. But I have reason to believe otherwise because when I started the car up later, feel was back to normal and I could get the car into 1st gear again. Then not too far down the road, the click and lost pedal feel, clutch feels dead, doesn't engage or disengage.. So I limp her home and while trying to put hte car in reverse pedal feel randomly comes back and the clutch works. BUT as I slowly let out the clutch I hear another wierd noise, more of a spinning? or a struggling pump of some sort (clutch slave?)? But all works normally.
Somebody suggested that I replace the slave cylinder and bleed my system (bypass the dampener while I'm under there).
Part of me thinks it's my actual clutch that died, but how would I explain the feeling coming back and it working again for a short period of time?
Thanks for your help guys.
http://jaythroughglass.blogspot.com
S13SilviaGirl: Mel are you that big?
i8yourfwd is offline   Reply With Quote
Old 06-06-2006, 06:57 AM   #2
NIK90s13
NIK90s13's Avatar
NIK90s13 is making a name for him/her selfNIK90s13 is making a name for him/her self
Was the click inside the car or was it out side? I don't 100% think it's your slave. Check the linkages at the pedal first, look for the click.
Do you have fluid in the clutch master, is the slave leaking?
If it comes and goes I'd say it's the master.
NIK90s13 is offline   Reply With Quote
Old 06-06-2006, 09:15 AM   #3
Dunkee
Dunkee's Avatar
Dunkee is a glorious beacon of lightDunkee is a glorious beacon of lightDunkee is a glorious beacon of lightDunkee is a glorious beacon of lightDunkee is a glorious beacon of lightDunkee is a glorious beacon of lightDunkee is a glorious beacon of lightDunkee is a glorious beacon of lightDunkee is a glorious beacon of lightDunkee is a glorious beacon of lightDunkee is a glorious beacon of light
Can also be the clutch fork pivot but I don't think it would engage anymore if it broke.
96 SE http://www.cardomain.com/ride/255381
Dunkee is offline   Reply With Quote
Old 06-06-2006, 10:06 AM   #4
i8yourfwd
i8yourfwd's Avatar
That's a possiblity, but what would explain the system going back to normal again for a little bit.
I'll try what you told me scott, hopefully that's it.
Old 06-06-2006, 09:36 AM   #5
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
Wow, I told you like. . .last week to fix that shit, it costs like, less than $20. Buy a bottle of brake cleaner, and the rebuild kit. Get er' done. It's hella easy.
Old 06-09-2006, 01:00 AM   #6
i8yourfwd
i8yourfwd's Avatar
OK... bump.. I replaced the slave cyl, and the problem is sitll there.
If my car is completely stopped, clutch pedal feel is normal and I can shift into gear. But as soon as the car starts moving, if I press the clutch pedal, there is no pressure AND nothing happens, rpm doesn't drop, etc. I've noticed also that when I'm stopped and I'm going into 1st and letting off the clutch, there's a constant scraping noise as I let the clutch go. But the noise goes away when I fully let go of the clutch. But like I said earlier, if I'm in gear already, there's no slippage.
Any ideas?
Old 06-09-2006, 01:09 AM   #7
downshift_sideways
No Limit Soldier.
downshift_sideways's Avatar
downshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfection
Send a message via AIM to downshift_sideways
my car does the same when I engage the clutch, it makes a wierd swirling noise, as the clutch dis-engages the noise completely stops.
Has to either be the fluid in the line? fork pivot, that goes into the transmission to either engage or disengage the clutch?
Didnt you just replace your clutch master cylinder? or what that the brake?
allntrlundrgrnd: "you never really appreciate your parents fridge until you look into your own and its full of condiments only"
downshift_sideways is offline   Reply With Quote
Old 06-09-2006, 08:36 AM   #8
driftskeetka24e
driftskeetka24e's Avatar
driftskeetka24e is an unknown quantity at this point
Send a message via AIM to driftskeetka24e
that noise is probably your throw out bearing on its way out
but for it going soft have u bleed ur system?
driftskeetka24e is offline   Reply With Quote
Old 06-09-2006, 12:25 PM   #9
i8yourfwd
i8yourfwd's Avatar
I'm gonna try and replace the clutch master also today, see if that helps any. Yes I bled the system after replacing the slave.
