Old 06-11-2006, 02:47 PM   #1
gotta240
Car sits UNLEVEL.. WTF....HELP!!!!
Ok... My car has Apexi WS Coilovers, and suspension tech swaybars front/rear.
NOW...wherever i park, no matter what, my car sits uneven in the rear. The DRIVERS SIDE REAR is ALWAYS lower(one finger gap) than the Passenger side REAR(two-three finger gap).
At first I thought this was due to ONE coilover spring sagging, or being adjusted higher than the rear.. SO.... I SWAPPED REAR COILOVERS.... Put the left on the right, and the right on the left. I didn't adjust them at all during the swap...
NOW...the car still does the EXACT same thing... WHATS GOING ON? thanks guys.
Old 06-11-2006, 02:56 PM   #2
R34SKYLINE
R34SKYLINE is an unknown quantity at this point
I know bad stock buhsings can cause this if some of them tore away from the metal sheel alowing it to move more like a ES buhsing or pillow ball type bearing....brand new teh stock bushing aren;t allowed to move around the metal sleeve there basically under tension the whole time which can effective aid if the supension wanting to left teh car or not if they are shot out...
Uneven camber can cause height issues
Sometimes corner balancing is need to get the car to sit even
R34SKYLINE is offline   Reply With Quote
Old 06-11-2006, 03:11 PM   #3
gotta240
But why would the car sit uneven on the SAME SIDE, when the shocks were switched side to side?
The car has all good bushings/bearings......
Old 06-11-2006, 03:23 PM   #4
R34SKYLINE
Is the camber good all around......front camber can also influence rear height and vise versa....so make sure your camber is good to go the more closer to zero camber your are for a particular wheel the higher the car will be on that corner.
Old 06-11-2006, 03:29 PM   #5
NemeGuero
No more nissan.
NemeGuero's Avatar
When did you install the Swaybars?
Did you do it with the rear completely in the air?
Old 06-11-2006, 03:33 PM   #6
Jung918
Jung918's Avatar
Jung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfection
Maybe that side has been hit and whoever did the body work did a crappy job.
Jung918 is offline   Reply With Quote
Old 06-11-2006, 03:47 PM   #7
gotta240
there is NO bondo on the car at all. I didn't install the rear sway...It came on the car.
Should i jack up the rear, and loosen the nuts that hold the bar to the car, and then retighten them? I'm not sure how that could possibly help, but i'm willing to try anything right now..
Old 06-11-2006, 04:21 PM   #8
NemeGuero
No more nissan.
NemeGuero's Avatar
Worth a shot. Sway might be bent.
Has this been a problem ever since you got the car?
If the coilovers are at the same height and the sway is tightened properly, try taking it to an alignment shop and see if they can look at it.
It'd be a good idea to go to a shop that also does corner weighting because they'll have more experience with that.
Old 06-11-2006, 05:51 PM   #9
gotta240
thanks neme....
I just raised the rear of the car completly.. Loosened all of the sway bar nuts/bolts, and retightened everything..
STILL the SAME THING!!! GRRR. I guess i'll try an allignment shop....
Is there a way to tell if i have a bent sway bar? They are Suspension techniques, but i cant even find their website... I even searched google!? Anyways, i'm wondering if i could send them to S.T. and see if they would tell me if they are good or bad?
Old 06-11-2006, 06:46 PM   #10
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
One side of my car always looks higher, but I think it's because I'm crazy.
I have more camber on one side of my car than the other in the front.
Old 06-11-2006, 06:50 PM   #11
gotta240
haha. yeah, i thought i was just crazy too.
then i busted out the tape measure, and it turns out i was right... one side is 1/2-1 inch higer...ALWAYS...
Old 06-11-2006, 08:27 PM   #12
yudalicious
yudalicious has a reputation beyond reputeyudalicious has a reputation beyond reputeyudalicious has a reputation beyond reputeyudalicious has a reputation beyond reputeyudalicious has a reputation beyond reputeyudalicious has a reputation beyond reputeyudalicious has a reputation beyond reputeyudalicious has a reputation beyond reputeyudalicious has a reputation beyond reputeyudalicious has a reputation beyond reputeyudalicious has a reputation beyond repute
corner weighing a car probably won't help w/ the gap issue because the result is not to get the ride height the same all around. it' normal for cars to sit uneven, especially old cars with older bushings. just fill up your gas tank, and keep it filled, lol. But, if you really are that concerned with the gaps being the same, just change the height of the coilovers.
yudalicious is offline   Reply With Quote
Old 07-24-2009, 09:18 AM   #13
kojiki88
kojiki88's Avatar
kojiki88 is an unknown quantity at this point
I'm having the same problem on my hatch. Just that I dont have Coilovers, I'm running KYB Gr2's with Tein springs. The passenger front sits higher then all other corners following the rear passenger sitting just a tad lower. The driver side sits even more or less. The lowest side is the driver rear making it have a Gangster lean. Its so annoying, i love looking at the driver side but hate looking at the passenger side. i wish i knew what can be done to fix this other then buying coilovers...
kojiki88 is offline   Reply With Quote
Old 07-24-2009, 10:28 AM   #14
S-Nation S13
S-Nation S13's Avatar
Trader Rating: (92)
S-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-known
Feedback Score: 92 reviews
i have the same problem went to wheelstore did alignment,corner balance,they adjusted my rear coils to make my car sit right but my coils are uneven in order to make my car sit even
S-Nation S13 is offline   Reply With Quote
Old 07-24-2009, 02:25 PM   #15
s14l0v3r
Trader Rating: (25)
s14l0v3r is an unknown quantity at this point
Feedback Score: 25 reviews
dam that blows.. well as long as its rides good. but anyways maybe your car was hit and never reported?? could be possible. jack your car up and make sure nothings bent, unfortunately i had to learn the hard way...but if it wasen't the sway bar, try an alignment shop.
s14l0v3r is offline   Reply With Quote
Old 07-24-2009, 03:09 PM   #16
singlecamslam
singlecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymore
This is like one of my most hated things about a car when its uneven, man it pisses me off. Well i had more camber on one side than the other and my fender was slightly bent so i felt stupid afterwards. Hope you figure it out.
Nothing says racecar like a stock car with no interior.
singlecamslam is offline   Reply With Quote
Old 07-24-2009, 03:13 PM   #17
Grenade180sx
Grenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfection
Send a message via AIM to Grenade180sx
our cars are 15+ years old... what do u expect from the chassis!
Grenade180sx is offline   Reply With Quote
Old 07-24-2009, 03:30 PM   #18
kuppler8
kuppler8's Avatar
kuppler8 is making his/her stupidity well-knownkuppler8 is making his/her stupidity well-knownkuppler8 is making his/her stupidity well-knownkuppler8 is making his/her stupidity well-knownkuppler8 is making his/her stupidity well-known
Send a message via AIM to kuppler8
i have the same problem, after reading all of this, ill know what to check and try out.
kuppler8 is offline   Reply With Quote
Old 07-24-2009, 03:33 PM   #19
Matej
Trader Rating: (39)
Feedback Score: 39 reviews
This thread is old, and there have also been other threads on this.
It is normal.
That is how the car was made.
The passenger side rear fender sits higher than the driver side one.
Old 07-24-2009, 08:55 PM   #20
xavier240
xavier240's Avatar
xavier240 is an unknown quantity at this point
Send a message via Yahoo to xavier240
lol 2006. car may even be long gone.
xavier240 is offline   Reply With Quote
Old 02-03-2024, 02:24 PM   #21
koukis13
koukis13 is a jewel in the roughkoukis13 is a jewel in the roughkoukis13 is a jewel in the roughkoukis13 is a jewel in the roughkoukis13 is a jewel in the roughkoukis13 is a jewel in the roughkoukis13 is a jewel in the rough
Just found out my driver side sits 1/2" lower than my passenger side on my s13. Thought it was my work but I have all new everything for suspension...
koukis13 is offline   Reply With Quote
Old 02-04-2024, 04:56 PM   #22
Kingtal0n
Kingtal0n's Avatar
Reminds me of
